Question about Electrolux Kitchen Ranges
Oven coil broke and ignited - Electrolux Kitchen Ranges
  • 294 Answers
A broken or cracked coil can arc and burn. This is usually caused by age. The part can usually be replaced easily and inexpensively purcahed on line from sources such as www.repairclinic.com
j
Posted on Oct 22, 2013
Why did my maytag gemini double oven coil caught on fire and break in half?
Because it failed
Ask an appliance parts store how
many times they see that
Jul 18, 2014 | Maytag Gemini 30" Self-Cleaning...
What if the ignition coil is broke
If the coil case is cracked, replace it. Yes, if it is broke, it may be shorting to ground there, causing mis-fire. So buy another coil.
Jun 17, 2012 | 1999 Ford Explorer
On my whirlpool gas range only 1 burner out of 5 will ignite. oven light works, oven ignites. only 3 months old and worked fine until now.
Most often when cleaning, soapis left behind and obstructs the flow of ignition gas normally directed at the exact point of the spark. Check this area and use a small wire brush to clean these area of the burners that do nto work. Let us know if this helps. Eric Campion
May 19, 2012 | Whirlpool GFG461LVS Stainless Steel Gas...
Oven not baking.
Sounds like the flame failure device is not working . or heat probe is out of position
Aug 07, 2017 | Frigidaire FGF337 Dual Fuel (Electric and...
The igniter was bad i replaced it with a new one (seemed simple enough) but when i put it on broil or bake the igniter doesn't turn red, is there something i'm not doing?
The igniter is in 'series' with the gas coil that operates the gas valve. The gas coil is probably bad. You can replace the coil not the whole valve. Go to repair clinic.com and put in the model number and they will have it.
Nov 06, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
Broiler coil sparked and broke, stopped working; 1 1/2 weeks later bake coil burnt out. I got new coils from the manufacturing, and had someone install. They don't work. The surface cooking area works...
Installer either did not do the job right OR when the coils broke they shorted in a manner that fried the oven control. The installer SHOULD have verified proper operation before they left your premises.
Jul 29, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Ignitor problem with gas oven
The spark ignition coil is failing. As this is an oven, it can be dangerous not to have a strong ignition spark. A gas buildup in the oven could cause an explosion.
You should replace the spark generator coil which is located at the back of the oven and is usually orange/black or blue in color. Ariston usually use ITW Ispracontrols ignition coils.
Mar 26, 2009 | Ovens
Dacor oven heating coil broke on one side
no it wont work and it would probablr run between 200 to 300 dolars give or take a little
Mar 17, 2009 | Kitchen Ranges
Oven not heating
Gas or electric. For Gas the Igniter is probably faulty. Remove the bottom plate inside the oven and look where the pilot light would normally be. There is a coil of wire that is suppose to get white hot when you turn on the oven. It conrols the gas flow and ignites the gas.
If it is electric check to make sure the heating coil is in one piece. You can also measure the resistance of the coil (with mutimeter). The oven tempature can be contolled by a dial or digitally. If digitally controlled you may have a faulty relay. Be careful moving the oven due to possible gas leaks and for the electric type ovens electic shock can kill. Be careful and good luck.
nssms
Jul 21, 2008 | Maytag Kitchen Ranges
Oven burner
hi thanks for the question. you saw the element burn its self out . its burnt out know don't worry go to bed . replace the element tomorrow . thanks the appliance doc
Jul 03, 2008 | GE Profile JTP18 Electric Single Oven
Kitchen Ranges Logo
Top Electrolux Kitchen Ranges Experts
Craig Butler
Craig Butler
Robert Plante
Andrew Taylor
Andrew Taylor
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
