I turn on the Electralog CS1205, and it will stay on for 2-3 minutes then it will turn off. If I wait for about ten minutes and turn it on again, it will do the same thing. Is it overheating, and if so, why?
4 Suggested Answers
SOURCE: i have a cs1205 electralog
I have an electralog cs1205, when i turn it on, although it works , after about 10 seconds it makes a strange noise. It never did this before. Any ideas on whats wrong?
Posted on Jan 06, 2011
  • 4736 Answers
SOURCE: I have a Dimplex Small
More than likely, the interior of the unit needs to be cleaned. When it's in operation, it sucks dust and link into the fan and heater elements. When it's not, spiders love to go into and build nests. If badly clogged, it can cause the heating element to over heat and shut off. Carefully, removing the back panel of the stove will give you access to just about everything. As far as the flame is concerned, the bulbs may need replacing. Although, it's unusual for all of them to go bad at one time. You or your nephew can replace them after the unit is cleaned. A vacuum that has a hose, brush attachment and crevice tool, will work well in the cleaning of the interior. Be sure to turn the Master ON/Off Switch to OFF & Unplug the unit, before attempting and maintenance on it.
If after performing all of the above, the unit still doesn't work properly, contact Dimplex USA, Technical Service 888-346-7539, for further advice.
Hope this helps to solve your problem. Please let me know.
Posted on Mar 17, 2011
1999 gmc savanna 3500 van, reprogram ignigtion key
place the key in the ignition and turn on.leave on for ten minutes.once ten minutes is up security light will either flash or go out.then turn off and then on again.repeat 3 times.this is a 30 minute relearn.remember just turn the key to run not start.good luck
Dec 14, 2011 | GMC Vehicle Parts & Accessories
Changed battery and replaced lost key. Now it won't start
nitabelle57, It sounds like your security system will not recognize the new key you purchased. Keys have a chip in them which has to be recognized by the security system in order to work. The new key has to be programmed by your security system before it will start your vehicle. You will need a battery charger to program the key as this procedure takes thirty minutes to do. Put the charger on the battery. Be sure everything else is turned off. Place the new key in the ignition and turn it to the run position. The security light should come on. After ten minutes the security light should be out, if not proceed anyway. Turn the key to the off position but do not remove it. Wait five seconds and turn it to the run position once again. Wait another ten minutes and turn it off again. Wait five seconds and turn it to the run position once again. After the final ten minutes turn the key off (do not remove it) Wait thirty seconds and then the key should be programmed. If you have any other keys they will not work now as the security system is now programmed for the one key. If you have another key and need it for another driver then start the vehicle with the newly programmed key and let it run for about a minute. Place the extra key in the ignition and turn it to the run position and wait sixty seconds. This should solve that problem. Good luck with this.
Aug 10, 2011 | 1997 Pontiac Grand Prix
I have a electralog fireplace model #cs 3311. It doesn't stay on very long. Even if i turn the thermostat up it doesn't turn on
It's probably the Temperature Cut Off Switch. It turns the heater off if it's overheating. To reset the switch turn the Main On/Off Switch to OFF . Wait 5 minutes and turn it back ON.
If you need to continuously reset the heater, unplug the unit and call Dimplex North
America Limited at 1-800-668-6663.
Hope this helped to solve your problem.
Mar 08, 2011 | Heating & Cooling
This morning when I attempted to start my 2006 Hummer H3, nothing happened. I thought I may have a dead battery but the lights and radio work fine. I then noticed the Passlock security lock light was on...
Hello:Try this procedure: turn key on, turn to start, let key come back to on wait ten minutes, turn key off wait 10 seconds turn key back on wait 10 minutes. turn key off wait 10 seconds turn key back on wait 10 minutes turn key off wait 10 seconds NOW try and start. In addition you might try tapping on switch assembly while trying to start. There is not any way to disable passlock. You might try having the engine control system codes read
Feb 01, 2011 | 2006 Hummer H3
I have a cs1205 electralog heater. after 5 minutes we hear a pop and the heater stops working. we shut it off and will hear a pop then turn it back on. it will work again for about 5 minutes. what is wrong...
Nov 27, 2010 | Dimplex Compact Electric Flame Stove...
My car anti-theft seems to have kicked in and I can't get it to start. What do I do next?
hi, you can perform the reset with just your key and a battery charger to see if this will allow for restart. what you do is, hook up a battery charger to start with, low amperage setting like 15 amp, or maybe 2 amp, and leave it on the battery, you will be leaving the key on for up to an hour and the battery must not die during this time. turn the key on and try to start once for about 1-2 seconds, then let go and let key rest in run position for fifteen minutes at minimum. then turn off the key, wait ten seconds, and turn on again to run position only, leave on for another fifiteen minutes, then again, turn off for ten seconds, turn back on to run position for fifteen minutes. after this time, turn the key off, wait ten seconds, and try to start the car. if it starts, check to see if the check engine light is illuminated, or the security light is on, if one or the other is on, take to a shop and have codes checked and diagnosed, if no lights on, you should be able to drive on. if the vehicle does not start after three reset key cycles, try the process one more time. it may have been interupted somehow. if you try twice and still no start, you have to have diagnosed further, maybe in the key, maybe in the lock cylinder, maybe in the theft module.
Jun 30, 2010 | 2000 Buick Regal
My sunfire theft light stays on all the time. I can't start the darn thing, what do I need to do to start it. The bump and wait ten min isn't working
tery turning the key on for two minutes, than shut it off, than turn the key on for ten more minutes. This is suppose to work no promises.
Feb 10, 2010 | 1998 Pontiac Sunfire
RCA HDTV model#HD52W59. When I turn the power on it stays on for a few seconds and then goes off by itself.
TV turns off unexpectedly
• Sleep timer may have been activated.
• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then turn on again. If this
happens frequently, the voltage in your house may be abnormally high or low.
• Unplug the TV. Wait ten minutes. Then, plug the TV in again.
Jan 05, 2009 | Televison & Video
2 wire Router is not working
I had a similar problem when the power went out and the router got hooped, the solution was to UNPLUG the power CONVERTER from the wall and wait ten minutes before plugging it in again.
Dec 09, 2008 | 2wire (1000-400108-001) Router
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
