Question about Moen & One Handle Tub & Shower Faucet
Just installed a one handle tub & sheower faucet. It appears that there is an excessively large space between the back of the handle and the escutcheon plate - it's about 9/16" and looks like it could allow water to leak in behind the escutcheon. Does that sound too much? Is there a solution? We had the plastic plaster ground plate lined up precisely with the front of the tiled wall so don't know where we went wrong.
    Top Expert:
  • Moen Master
  • 34,743 Answers
If the faucet is the pull-on, push-off type, there has to be sufficient clearance to allow lateral movement from one extreme to the other.
Posted on Oct 22, 2013
  • 49 Answers
SOURCE: Moen shower/tub faucet
hi... yes that's a very common issue with moen "cartridges" -- it's very simple to fix..... grasp the handle and give it a gentle tug upwards when the water is on... if it retracts again, pull the handle out again and tug again but this time a bit harder. Not sure what causes this on new cartridges but it will fix your issue.
Posted on Sep 03, 2009
radar001
  • 1051 Answers
SOURCE: How do I repair a leaky Moen faucet handle. When I
It needs a new cartridge. Moen gaurantees most of their products for life, so if you have the original instructions check for contact info. They'll send you a new cartridge for $0.00
Posted on Jan 14, 2010
  • 81 Answers
SOURCE: The faucet leaks, behind the wall when the shower
The most common reason for basement leakage is from the seal at the drain or the seal behind the overflow. With the overflow, the water trickles down after bouncing off your body and back onto the tub. This possibility MUST be eliminated first before determining the next step, Turn on the cold water and fill the tub and let the water go into the overflow for about 5 minutes. This will simulate someone in and using the shower. Check for leaks in the basement.
This test, as simple as it is, will also implicate bad plumbing connections at the valve itself behind the wall as well as eliminate backsplash from the showerer bouncing back onto your control valve(s).
If you have a leakage, wait a day and, with the drain open, turn on the hot/cold valve(s). and waste some water for another 5 minute test. This test eliminates the overflow as a suspect, and with the drain open almost always eliminates the drain as well. Hey..in plumbing there are no perfect answers.
If you still have leakage and no one is showering you have pretty well isolated the valve or connections to the valve. If you don't have leakage, it points to water bouncing off the body and onto the control valve(s) at which point resealing would be in order.
You can get leakage also if the caulking around the tub where the tub meets the wall has gone south. Stamped out steel tubs (common in rental apartments) have open corners so if the wall-to tub caulking is poor then the shower bounce off the body will easily trickle to the basement. This is not an issue with cast iron or fiberglass/plastic tubs.
If these tests truely point to the valve(s), repost your ? and refer to the drain tests completed, and supply as much information as you can about the brand and age of your valve(s)
Posted on Jun 02, 2010
radar001
  • 1051 Answers
SOURCE: have the moen 82300 2300 series positemp tub and
Temperature regulating faucet, aka anti-scald, are fast becomring a requirement under local building codes making it, technically speaking, a building code violation to alter the faucets function (assuming someone reported it the loccal buildings dept. That said the function of the anti-scald faucet cannot be altered. You should contact whomever installed the faucet to come back and adjust it so the temperature is more suited to your needs.
Posted on Jun 20, 2010
  • 4340 Answers
SOURCE: leaking shower/tub faucet, looking for replacement
Call Moen directly. They will ship what you need to your door, for free.
Posted on Sep 18, 2010
I would like information on steps to remove bathtub and install pre fab shower
This is a fairly big job but can be done if you have the right tools and a little bit of time....... Depending on the existing tub material (cast iron,fiberglass, tin type ). You will want to remove faucet trim(handles,spout) first. Then the over flow plate on tub,as well as drain in the bottom (this will require a drain removal wrench or pair of needle nose pliers and screw driver, and some strong arms).After this is done remove tub unit , if the unit is a cast iron unit a good sledge hammer will work as you will need to break into halves to remove unless your trying to save tub and provided you can then get the unit out the door in one piece...... Caution, protect body and eyes in this process, flying pieces of cast iron can do some damage to body......cutting tub will take several blades and take quite a while to do......The next step depends on the location of faucet and if you are replacing the tub faucet or going to use the existing faucet.... I would recommend a new faucet because if this is going to be a shower only you may want to raise the faucets so they will be easy to operate without having to bend..Depending on the model pre-fab (two piece,three piece) unit you wish to install you may need to prep the drain to make sure it will fit your new installation. Let me explain... most tubs have the drain located at the right/left end of tub and the showers are located in the center of the unit thus leaving you to relocate the drain. If house is on slab it means a little jack hammering the concrete to provide this, if the floor is a conventional it means re-routing the drain to the center.......once all this is accomplished you are ready to install unit base,connecting drain. Next you need to get the faucet located to the right height or be able to get to the back side of the shower and remove the existing faucets and replace them after you install surround.....turn off water supply before removing faucet..... A sturdy surround will make for a less involved support system around shower area.Be sure to leave enough space between studs for faucet attachment. Sounds like a lot of work and it is but after its done you will have a great bath shower..... hope this was helpful.... sorry this only dealt with the plumbing aspects of the job......
Sep 05, 2011 | Home
I have a whining problem when the faucet is filling the tub. It appears only to be the cold water or with warm water. If we run scalding hot the noise goes away..
You have a feed back sound from the faucet cartridge. I hope when you turn the faucet off that there is no leak. If there is a leak then your cartridge is misalined. It will eventually leak and that is an easy fix.
Turn off the main water coming into the house
Remove the cap and handle of the faucet
There is a retaining pin on top, first by using a pointed instrument remove the retainer and it looks like an upside down U
Remove the cartridge and replace with a new.
Insert the new cartridge the same way you removed the old one
Install everything on reverse order.
Good Luck
Jan 07, 2011 | Delta & Single Handle Shower Faucet
We recently installed a Moen single handle faucet in a refinished shower after having a plumber replumb the front of our house. Handle appears to be properly installed. Now there is no hot water or even...
u need to adjust the scald protector all single handle units are shipped in cold position for safety reasons if have paper work for handle it explains how to adjust if not unscrew handle and remove on handle / valve stem will see a red and a blue plastic clips pull back clips and turn slightly and push back do this till desired hot and cold setting are to your liking replace handle and your done
Dec 17, 2010 | Moen & One Handle Tub & Shower Faucet
Have the moen 82300 2300 series positemp tub and shower faucet. can i make this a nonpositemp by replacing the cartridge? We are unable to regulate cold or hot temp. no matter where the handle is the...
Jun 20, 2010 | Moen & One Handle Tub & Shower Faucet
I am haveing a problem putting my tub and shower faucet back need a daigram of it can find one online it is a delta tub and shower faucet can you help me james
The only thing that comes to my mind, go back where you bough them and
ask them to make some copies of the installation instruccions.
I know...the pride will get hurt a bit....but you will install this bath in NO time.
Hope this help
Mar 26, 2010 | Delta Faucet Peerless& Single Handle...
All in one tub and shower has a leaking tub faucet, how do i take the whole all in one tub and shoer out, and how do i fix the faucet to the tub then put shower and tub back in(all in one piece).
When I went to take mine out I had to cut it in half. Before doing anything drastic are you sure there's no way you can excess the plumbing from the other side of the wall? Its a lot easier to patch drywall than pull a tub. The faucet and pipes should be attached to the studs in the wall and not really attached to your tub. I don't really know what part of your faucet is leaking.. Some parts you should be able to excess from the front without pulling your tub. If its from the down spout you could probably loosen a screw or allen head that's on the bottom pull it off replace it or replace the O'ring inside. I hope I have help out.
Mar 04, 2010 | Moen & One Handle Tub & Shower Faucet
Trying to remove cowell from Roman tub faucet
The Price Phister Roman tub spout needs to be tightened from beneath.
If you do not have a removable skirt on the tub it will be a bit difficult to tighten.
Should you have crawl space under the tub and are careful to locate the dead space between the tub and the skirt you can cut a hole beneath the valve and spout location and reach up from below to tighten the spout.
If you have tile as a surround and no access from below you will have to remove some of the tile in order to gain access.
You may want to call in a proffessional plumber to handle this.
Hope this helps,
sanray
Dec 27, 2008 | Danze D302521 Antioch Roman Tub Faucet...
American Standard Cadet 2-handle tub & shower set-Model#3275 - low pressure output
When you installed the new tub faucet you probably turned off the water to that faucet of even the whole house. IF IT IS AN OLDER HOUSE, TURNING THE WATER OFF AND BACK ON CAN LOOSEN SOME DEBRIS IN THE WATER LINES THAT CAN FIND THEIR WAY TO YOUR NEW FAUCET. If there is a screen at the end of the water outlet it can be clogged with gunk. Uncrew the screen on the water outlet and clean. You may also want to flush out the hot and cold outlets by turning the water off, removing the cartigages and slowly let water flush them out. Then reassemble. Also when you have the tub handles out you can turn the hot and cold supply valves off and on a few times to loosen more debris if it exsists........Joe
Oct 24, 2008 | American Standard Colony 3275.505 099...
Moen & One Handle Tub & Shower Faucet  Logo
59 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
