Question about Westinghouse TX-47F430S 47 in. LCD TV
Orange light is on but does not turn on - Westinghouse TX-47F430S 47 in. LCD TV
  • privera380 Oct 22, 2013
    I've check the power supply and caps look great. I've loaded the latest filmware on a flashdrive and connect to service port. Got no results. Green light back inside
    Top Expert:
  • Westinghouse Master
  • 75,462 Answers
Check and replace the main digital processor board. Contact any service technician. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Posted on Oct 22, 2013
Orange light trying charge
I would try this:
take the battery out
unplug the charger
turn upside down
hold power button down for 1 min
keep holding power button down as you turn over the laptop
while still holding power button down plug in charger and try to power on
Jan 26, 2014 | HP Computers & Internet
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
The power bar orange light is on but the console won't turn on
The power bar light is supposed to be green, not orange. If it's orange than that means the power supply has gone bad. SOrry :(
Jan 31, 2010 | Microsoft Xbox 360 Console
Will not turn on. orange light onlt. was using
I belive the notebook wont turn on. and Orange ligh is the LCD light. If Yes, take out the battery and the Power Cord. Press and hold the power button for 20 seconds and Then Try. further , try reseating the Memoty card if that does not work.
Regards
Nick
Oct 11, 2009 | HP Compaq nc8000 Notebook
Open Questions:
My Westy 47 TV has a very strange power-up problem! First, I found that the power supply was bad, I couldn't repair it, so I bought a replacement from ShopJimmy. The replacement seems to be working fine, and sometimes the TV works fine. The little green LED near the bottom edge of the controller board lights up when you connect the AC power, as it should. There is also a small green LED near the upper edge of the controller board that apparently lights only up when the controller is working properly. I've replaced the 470 mFd, 16 V. 'Lytic on the controller board, as everyone says to do. I still observed about 0.8 Vp-p of digital signals on the 5 Volt buss with the replacement capacitor these signals looked kind of like a 300 kHz clock and some other misc. digital stuff, so I added a couple of 0.1 mFd disc ceramics directly across it on the bottom side of the board. That reduced these signals to about 0.4 Vp-p, but the TV still won't turn on. The orange pilot light on the front is lit, but neither the buttons nor the remote will turn it on. The only way I can get the TV to turn on is to do the following: 1. disconnect the two power cables going to the two lamp inverter boards; 2. plug the AC power cable in. The 2nd green LED on the upper portion of the controller board now lights up when AC power is applied. 3. plug in both power cables to the two inverter boards while the power is on. The TV now works fine - all of the lamps light up, good picture, blue LED on the front panel, the remote works, etc. However, if I turn the TV off, and try to turn it back on, the small green LED on the upper controller board goes off, and the set won't come on! I've tried holding the on/off button down for over 10 seconds I read that this might re-boot the controller to no avail. The only way to get it back on is to go thru the 3 above steps again. I've read that there appear to be several versions of the firmware, and I wonder if this might be a firmware problem. If so, how/where can I get the proper firmware to install? Any suggestions? HELP! Please If someone would like to call me, please do at ************. Thanks, Gary W3DTN
Dec 28, 2015 | Westinghouse TX-47F430S 47 in. LCD TV
See all Westinghouse TX-47F430S 47 in. LCD TV Questions
Westinghouse TX-47F430S 47 in. LCD TV Logo
107 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
