Question about Garden
How to replace chemical injector on husky hu80709 pressure washer?
3 Suggested Answers
  • 553 Answers
SOURCE: Owner's manual for Husky #HU80432 pressure washer
If you can't find it under Tech Support, Manuals & Guides on this site you could go to: http://huskypowerwasher.com/manuals_specs.php
You can also call Husky at: 1-888-550-1606 from 8:00 AM to 4:30 PM Central time.
I hope this helps.
Posted on Mar 28, 2010
Testimonial: "thanks for the info. the # that I was referred to for manuals is - 866-340-3912."
SOURCE: troy-bilt 2200 psi pressure washer
I have a Troybilt Model 2200 PSI Pressure Washer in which I have used only 2 times in the past 2 1/2 years. Went to use it this past weekend and the pump in not working. Water shoots out of the side. I bought this brand and model as I thought Troybilt was suppose to be so good. Went back to where it was purchased and had no success but to say I could buy another pump or take it in to be repaired. I believe that this power washer should be replaced at no charge. 2 uses does not constitute a few hundreds of dollars.
Have you to heard anything concerning pump problems on this particular model? Thanks for any advice. .
Posted on Jun 08, 2010
No pressure on my husky power washer 1650
Basic Issues As an electric-powered washer, a circuit overload may cause your Husky 1600 to shut down or prevent it from starting. In this case, check your home's electrical service panel for a tripped breaker or a blown fuse -- the 1600 requires a dedicated circuit rated at a minimum of 15 amps. To prevent a blown fuse, avoid using other large devices on the same circuit as your washer. If you use an extension cord, it must be rated at 15 amps as well. Before moving on to more complex troubleshooting measures, check the gun safety trigger and release the lock if your 1600's trigger will not move. Water Woes Releasing air from the pump serves as a simple fix for low-pressure water output; remove the wand and allow the washer to run as you depress the gun's trigger until the water output normalizes. If your water output seems to lack detergent, ensure that the clear tube is securely connected to the detergent nozzle. Likewise, check the connected water supply and make sure the faucet is fully open and that there are no kinks in the hose to ensure optimal pressure. Using a shorter garden hose makes for stronger pressure, as well -- Husky recommends a hose with a maximum length of 50 feet for a city water supply. Clearing Clogs If your Husky 1600's pressure seems lacking or its water flow is obstructed, clean the nozzle by removing the wand from the gun, clearing the nozzle hole of obstructions with a stiff wire and flushing the nozzle with clean water. Similarly, clean the washer's inner water screen, located behind the garden hose connector, by removing the screen and flushing it with water. This also corrects low or irregular pressure and may remedy a unit that does not stop releasing water when the trigger is released. Model HD1600 features a chemical solution reservoir with a similar screen; clean this screen in the same fashion if you experience chemical intake issues. More to Consider If your power washer issues go beyond troubleshooting basics, contact Husky's customer service department at 800-381-0999. Husky recommends contacting customer service when your 1600 has problems with its pump, bypass valve, discharge valve or manifold assembly, for instance. Because this series of powerwashers was originally offered around 2001 through 2008, Husky's one-year limited warranty no longer covers the cost of replacement parts or repairs.
Sponsored Links
Sep 29, 2016 | Garden
What is causing water to leak out of the resovior when the power washer is running?
I am assuming you mean the chemical resovoir tank? If water is running out of it then water is coming back up your chemical injector. This usually means at some point the ball and spring in your injector got stuck...typically people take them apart at the nipple to ry and fix it. not realizing there is a small ball and spring in that nipple. This is actually a ball valve to prevent water from coming out of the chemical injector nipple. Replace the ball and spring if needed as well as the oring seat in the nipple. This will stop your tank from filling up. Good luck
Sep 06, 2014 | Honda GCV160 5.5HP 2300PSI GAS-POWERED...
Husky HU 80522 pressure washer - some pressure to the spray gun. water coming from the pump goes straight to the sifon hose used for detergent. Can this line be clamped of if not used?
This unit has a Faip pump on the unit, no water should come out the chemical injector. The chemical injector can be closed off with no problem by installing a plug where the chemical injector hose bard is currently located.
You can also replace the chemical injector, here is a link to view the part.
www.allpartsinc.com/ProductDesc.aspx?code=KTRI91351
Mar 29, 2012 | Garden
Craftsman Pressure Washer 580.752160 reagent/chemical not being dispensed when wand in low pressure position.
It is very common for the chemical injector valve on these to get gummed up from residual soap sitting in the valve. To clean it follow the chemical hose back to where it attaches to the pump. There will be a hex headed hose barb attached to it. Remove the barb from the pump. Underneath it you will find a spring and a ball bearing. Rinse the parts thoroughly and reassemble. You should also check the chemical strainer that goes into your chemical bucket. They can also become clogged and should periodically be cleaned.
Sincerely,
Aron Kerr
Landa Northwest, Inc.
www.landanw.com
Mar 07, 2011 | Craftsman 2700 Max Psi Pressure Washer 23...
Where can you purchase replacement parts for Husky HU80709A power washer purchased from Home Depot? Called Husky, who said they do not manufacture this pump and given 800 number for Ryobi. However, Home...
You use www.homelite.com part lookup for the HU80709. Homelite site doesn't list the a version but parts should be the same. www.jackssmallengine.com is excellent source for parts and is very reasonable on the parts.
Dec 21, 2010 | Garden
Why want my pressure washer suction the solution while pressure washing the house?
The first problem might be that you are trying to use the wrong nozzle, see this link to read more about what nozzle to use for detergents
If you still have an issue the problem is going to be in the chemical valve on the pump, there are two different styles they have on this type of machine, look at the links below on directions on how to repair your chemical valve.
Chemical Injector 1
Chemical Injector 2
Nov 11, 2010 | Karcher 2500 PSI Pressure Washer
I recently purchased a northstar 4000 psi pressure washer. I had the same series pressure washer for the past 6 years and used a downstream chemical unloader quick connect to pull chemical. I attached it...
The injector might be worn out or have something inside of the valve causing it not to ****. If you are using a new high pressure hose or a longer hose this may also have an effect over the injector not working.
Oct 06, 2010 | Northstar Professional Series Pressure...
Genrac power washer chemical injector not working
How long is your high pressure hose and what diameter as it maybe to long and won,t **** chemical due to back pressure. To test this remove the high pressure hose and run the machine and check too see if any chemical is coming up the pipe. If it does then its a problem with your hose or the adjuster is not going to low enough pressure.
Jun 04, 2010 | Garden
Dewalt 3700 pressure washer will not take in the cleaning solvents works fine but will not spray chemicals
Be sure that you have your chemical injector plumbed correctly. They will only work one way.
Oct 08, 2009 | Dewalt 3700 Pressure Washer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
