Question about Vacuums
Kenmore vacuum model 116
There seems to be a short in the connection between the canister and the hookup for the extension wand. if it moves a certain way, the canister will stop working while the beater brush stays on. How do I fix that?
    Novelist:
    Champion:
  • 210 Answers
Anthony, glad to have you back, except that you're missing a bunch of numbers. All Kenmore vac's models start with a 116., (notice the decimal after the 6). Then there's at least four to six more numbers that spell out the actual model. If you can get those for me I might be able to help.
Posted on Oct 23, 2013
SOURCE: Kenmore canister model 116
The top plate encloses/covers the lilght.
Posted on Mar 02, 2008
VacuumRepair
  • 438 Answers
SOURCE: Belt broken a a Kenmore
Greetings from GoVacuum.com,
To properly fix a belt on a Kenmore vacuum, you will first need to indicate whether this is an upright or a canister vacuum. The model given, 116, is only the first part of the model number, and all Kenmore vacuums, upright and canister style, start with 116. There is a period first, then a whole string of numbers, 116.255553 etc.
Kenmore vacuums are mainly made by Panasonic for Sears, and most will use a Panasonic belt. If the belt is an upright, this makes it simple, and will be a Panasonic "UB" belt.
For a canister vacuum, most models use what's referred to as a cogged belt. This type of belt has little teeth on the inside of the belt, and is Panasonic CB-5 belt.
Instructions on How to Replace the Belt for an Upright;
There will usually be to plastic screws on the top of the agitator housing on the base of the vacuum, that will say belt access. Simply take a flat head screw driver, and turn the screws so that the screw is pointing up and down on both sides. Then pull the plastic agitator housing, or the top of the base of the vacuum off. Inside you will see a the roller brush, and the belt (or broken belt). Simply take the new belt and wrap it around the silver pulley located in the back of the machine, opposite the roller brush, and wrap the other end of the belt through the roller brush. Stretch the roller brush back into the housing of the machine, and replace the top of the base of the vacuum back on the machine. You should give the belt a tug, to ensure that the brush is spinning when the belt is being pulled.
Feel free to email me if you have any further questions, I'd be happy to walk you through it, or even shoot an instructional video to show you how you to replace it. My email is chris.jones at govacuum . com.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Posted on Oct 01, 2008
SOURCE: Kenmore vacuum manuals
I tried what reddevil6 suggested and was not able to get Sears to produce a manual. I would prefer an online manual but at this point I'm desperate enough to try anything.
Posted on Oct 05, 2008
SOURCE: Kenmore Model 116 upright beltless vacuum, agitator will not turn
I had the same problem. The agitator stopped turning after I sucked up a foreign object (my wife's watch) and it got jammed in the intake. After removal of the watch the agitator did not spin when turning on the machine, and the reset button never deployed (it remained buried in its housing and would not depress with a paper clip). The agitator was not bound and I could manually move it in both directions with ease. Faced with prospect of paying $125 or more for a repair, a good sharp kick to the chassis from the top promptly fixed the problem. I have found that kicking malfunctioning electronics often works.
Posted on Dec 05, 2009
SOURCE: my kenmore beltless upright canister vaccuum doesn't spin anymore
Ensure the agitator is not bound up and can be moved manually by hand in both directions. Clean any string or binding material if you find it. Press the reset button on the top of the chassis. If it clicks, then you should try turning it on and see if the agitator spins. If it doesn't spin, I have had luck giving a sharp kick to the top of the chassis.
Beater bar turning on and off. Why doesn't the vacuum?
Try wiggling the wire and where the hose swivels to attempt to determine where it may be shorting out. It could be the wire or the plugs where the wires connect if your model has them. Inspect these areas closely to find your short.
Apr 08, 2016 | Kenmore Vacuums
The power brush on my Kenmore canister vac #116 2761 works intermittently Depending on how I hold it. Seems to be a problem with the contacts on the wand????
all you can do is clean them contacts that you see on the wand
use wd40 .
an a brillo pad or such.
look at the female connector on the end an see if u can tighten an clean it .
Jan 04, 2015 | Kenmore Vacuums
How do I disassemble a Canister Vac Model 116.21714. extension wand ?
Sadly, there does not seem to be much help available for this. Sears wants $100++ another $30-40 shipping to have UPS take it and may be fix it. If you do not want to pay the fees, you will still have to pay $50 to get it back. Sears service shops will not fix vacuums. What the heck?!
Apr 24, 2014 | Kenmore 23913 Progressive PowerMate Bagged...
There seems to be a short between the canister and the extension wand hookup. Right at the plug between located at the front of the canister and where the extension wand plugs in. When you rotate the...
Well, Anthony, considering as how I have no idea of what brand, make, model or color your vac is, I can't make much of a guess as to why it doesn't work. We'd need more info if you want to log back on at a later date, such as brand, model, maybe even a picture of the unit so we could see just where your problem might be.
Oct 22, 2013 | Vacuums
Can you tell me if Powermate Power Brush attachments are all the same for all the Sears Powermate Cannister vacuums.  That is, would one power brush attachment on a Model 116.56512690 fit one that is Model...
i think your confusing model #s ,as the 116. 22512202 is the canister model number and the model number of the powerbrush attch would be 116.52512202,but to answer your ? no it depends on which wand your useing that determans which one you can use
there 3 types of wands 1 telescoping which comes only on progressive models 2 a 2 piece with wire connected and a 2 piece
wire not connected,hope this helps,les
Jan 03, 2009 | Kenmore 22812 Bagged Canister Vacuum
Kenmore vacum wand power cord
http://www.vacsew.com/vacuum-cleaners/kenmore-vacuum-parts.html/
Try here
Jul 16, 2008 | Vacuums
Losing power to stick/floor vacuum
if you have an extension wand, the replacement will cost about $100.00. there is a way to repair both the pwr-cord on the brush assemble and the wand, but it depends on how much damage there is. also you need to check the contacts where the wand connects with the handle,and the prongs on the handle.
let me know if you still need help
Jan 11, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Vacuums Logo
160 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
