Tengo una lavadora kenmore 110.21252110 y la luz del lid se queda parpadeando y no funciona. Que puedo hacer para arreglarla
SOURCE: lavadora kenmore HE3 parpadea la luz de delay cuando faltaba 15 minutos para terminar el ciclo.
necesito instrucciones de uso de mi lavadora kenmore Elite pero en español
Posted on Jul 10, 2009
SOURCE: tengo una lavadora LXR7144EZ1 Empezo con un ruido
Mil gracias por tu ayuda, la lavadora cuando llena no hace ningun ruido, luego cuando empieza a restregar empieza un ruido fuerte y despues de esto se detiene por completo, muchas veces a trata de llegar al ciclo de exprimido. Pero el dia de ayer dejo de funcionar completamente.
Posted on Sep 01, 2009
SOURCE: no puedo usar mi camara para chatear
no se como usar la camara de mi laptop ayudenme
Posted on Dec 23, 2009
blueextc3221
  • 15935 Answers
SOURCE: tengo una lavadora aeg lavamat
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 16, 2010
Daniel S
  • 4323 Answers
SOURCE: El programador de mi lavadora
Hi
First make sure that nothing is blocking the drain pump assembly located inside the bottom of the unit, after this test the lid switch assembly, you jump it to test it. If the lid switch is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 26, 2011
Por que la lavadora no exprime y se queda quieta
Tengo una lavadora nave de 39 libras y cuando empieza el ciclo de lavado se queda quieta y el bombillo empieza a parpadear que debo hacer?
Mar 08, 2011 | GE Washing Machines
Mi monitor parpadea y no arranca ? que debo hacer tengo conocimientos de electronica pero no se que hacer
Primero verifica la luz frente a tu monitor si la misma esta parpadeando o de color anaranjada hay un problema con la tarjeta de video de tu computadora. Si esta verde esta recibiendo señal de tu tarjeta de video. La mejor forma de saber si tu tarjeta de video esta funcionando correctamente es utilizar otro monitor que sepas que esta funcionando correctamente y conectarlo a la computadora. Si funciona bien, tu monitor esta dañado. Mi recomendación es compra uno nuevo por que es mas economico que repararlo.
Mar 03, 2011 | LG Office Equipment & Supplies
TENGO UNA COPIADORA XEROX 1012, CUANDO TRATO DE SACAR UNA COPIA TARDA EN CALENTARSE Y NO HACE LA IMPRESION Y ASI UNA SEGUNDA OCACION, HASTA LA TERCERA VEZ QUE TRATO DE SACAR LA COPIA SALE, CUANDO INTENTO...
Esta maquina es viejo, pero si la quiere usar, buenos.
Hay algunos alambres en centro de abajo, limpa los. Tiene cuidado porque los alambres se cebran faci.
Otra cosa es la tinta. La tinta tiene una cosa que media la tinta en el roldono palo. Si esta cabado, no va poner tinta muy bien. Se puede acer copias malas.
Otra cosa tambien es si el papel se tora.
Las jantas pueden ser mal. O otra cosa es si la maquina esta cebrara. Cuando abre la machina, mira adetro donde los dos partes se pegan. Si estran cebranan, el cloche en la atras puede pegra la ariba del metale de ariba de la machina. Usa unas pinsa a planar el metala de el clotche.
Buen suerte! Ojala que entiende esta mensaje.
Aug 12, 2010 | Xerox FaxCentre 1012 Plain Paper Laser
Activar luz de bloq.mayús
a tu mano derecha del teclado veras una techa que dice Caps Lock
esa es para las mayusculas o minusculas. ;)
Mar 14, 2010 | HP Computers & Internet
Tengo una lavadora Whirlpool modelo LXR7144EQ1 que al exprimir la ropa no gira la tina si me pueden Ayudar de una Resolución de este problema
tengo una lavadora whirlpool, el problema es que no gira para exprimir, todo lo demás funciona, el motor recibe la señal para la función exprimir, sin embargo la transmisión no funciona.
Jan 09, 2010 | Whirlpool Washing Machines
No puedo usar mi camara para chatear
Sep 06, 2009 | Logitech Webcam
Tengo una lavadora LXR7144EZ1 Empezo con un ruido
Sep 01, 2009 | Whirlpool Washing Machines
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
