Question about Toshiba DKT-2020 Corded Phone
Toshiba model DP5022-SD remove name on display
5 Suggested Answers
mdesmet
SOURCE: Change name display on Toshiba DKT2020-SD
I am assuming you want to change the display to read another persons name, or blank. If that is correct:
Press a [DN](labeled intercom on my system) + #621.
That opens edit mode.
an example. My phone reads "MARK 29"
where Mark is the user, 29 the extension. John replaced
Mark, so target is "JOHN 29"
so intercom # 6 2 1 puts me in edit mode
# toggles between alpha/numeric
* moves the cursor, I repeat * until cursor is under M
Hit the 5 key, changes the M to J and moves cursor under the A.
Hit the 6 key, the A changes to M, and the cursor moves to under the R. I hit 0 which changes the M to N. I hit 0 again, the N changes to O.
Hit the 4 key, the R changes to G. Hit 0, G changes to H.
Hit the 6 key, K changes to M. Hit 0, that changes the K to M. Hit 0, M changes to N.
We are done, as the extension number stays the same. Hit spkr key to leave edit mode.
Hope that helps!
# toggles alpha/numeric
Posted on Dec 10, 2007
Press "intercom" button, then #621. Use * to move the cursor all the way to the left. Use the # sign to change from numbers to Alpha. For example: You want "N", but the "M" comes up. Press the "0" to toggle to additional letters on same number key. For a SPACE, use the number 1 and toggle to get a space.
Posted on Feb 01, 2010
  • 13 Answers
SOURCE: I need to change the name that is displayed on my
On the DK systems, you need to go into system programming, and enter the name for your extension under a setting you can access.on the CIX or CTX Phone system, you have to have a computer based software, called emanager, and program it through the computer. You may need a technician to help set that up.
Posted on Mar 15, 2010
Lidon888
  • 4 Answers
SOURCE: how do I cancel a
#6051
Posted on Sep 25, 2011
Change name on display
U need to have network emanager installed on a computer
Feb 17, 2014 | Toshiba DKT-3220-SD Corded Phone
After I insert the disc, the digital readout say bAd and the screen states Incorrect Disc.
There is an recall from Toshiba for "bad" problem in Toshiba SD-3980 dvd player.
"Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit. If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit."
Click Toshiba Support link for original message, please contact Toshiba and above number for replacement unit.
Hope these info will help you.
Thanks.
Feb 12, 2011 | Toshiba SD-3980 DVD Player
I have a toshiba dkt2010-sd how go i program this phone ... right now my display screen has NO.11 in the upper right hand corner and lower left corner it has CALL 11-15
What do you want to program? to get rid of blinking light press intercom and dial #409 to program display name type Intercom #620 and #621
Jan 21, 2010 | Toshiba DKT2010SD Phone
Trying to change the display name on a DKT
DN just stands for "Directory Number", which is also another name for an extension number. That button should either say EXT______, ot DN______ or Intercom.
So, just push any of those buttons, and dial #621
Nov 03, 2009 | Toshiba DKT3020SD Corded Phone
Display name / date time
1)First tell me mob-ph-whitch company.2)mob-ph-Model-no-otherwise donot solve.
Aug 25, 2009 | Lands Phones
Programming a Name in Toshiba DKT3020-SD
To edit display name on LCD DKT3020-SD.
Follow this sequence:
Mode
Scroll
Enter passwork - 0000 is default
Hold
Hold (again)
DN ID (This is your phone extension #)
Old name should now be displayed. Hit page button to delete letters, scroll button for space.
Use characters for the the associated number key to enter desired name. For example if you want an "F" you would hit the 3 button 3 times. After your name is entered, press hold. Pick up and put down receiver.
Mar 11, 2009 | Toshiba DKT3020SD Corded Phone
I NEED TO CHANGE THE NAME ON THE WINDOW OF THE PHONE
wat system using?
find out the adminstrator phone (pic to set the speed dial)
must hv displayed phone.
press MODE will see PHONE NAME press HOLD display show ID DN it means key in extention number, after that key in name, press HOLD to confirm, repeat step for other extention name
press MODE untill time appear
Jan 20, 2009 | Toshiba DKT-3220-SD Corded Phone
Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players spacer.gif To ensure the satisfaction of our customers and to maintain the integrity and quality of our products, Toshiba America Consumer Products, L.L.C. is issuing an important product update. This is not a safety issue.
Mar 29, 2008 | Toshiba SD-3980 DVD Player
Disc Error
Simple issue, the lead laser cannot read any data, for better result please try to check with the DVD shop.
Hope you like my solution please rate me solved.
Best regards,
Philip
Nov 17, 2007 | Toshiba SD-3980 DVD Player
Toshiba DKT-2020 Corded Phone Logo
1,274 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
