Nesesito codigo para el control universal isel u-47 plus de dvd amw
Benimur
  • 6966 Answers
SOURCE: nesesito un codigo para un
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
1. (Open the disc tray)
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
6. A new menu entry appears (Version)
7. Select it and select RC (0=codefree)
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 18, 2008
SOURCE: codigo del dvd sungale 2026 para control universal motorola
hola tengo un problema tengo un dvd marca sungale y no tengo control le compre uno universal marca lax-max y quiero saber cual es el codigo para este dvd
Posted on Jul 19, 2010
SOURCE: nesesito el codigo de un tv jvc para programar
COMO BUSCO EL CODIGO DE MI CONTROL REMOTO DE MI PUR FLAT?
Posted on Sep 27, 2010
SOURCE: el codigo del control remoto de una tv mitsui
el control remoto del digitalizador motorola no trae codigo de acceso a la tv mitsui, cual sería el código de acceso; hablé a Megacable y no tienen registrada la marca de la tv así que no pudieron darme el codigo de acceso y me recomendaron que indaagara en internet
Posted on Nov 13, 2010
Demonic-2011
  • 467 Answers
SOURCE: necesito el codigo de un control universal
English: the universal remote codes for Daewoo TV are: 002 102 110 214 303 311 314 403 407 415 502 503 611 614 805 809 909. Try those - I hope they help a bit.
Spanish: los c?digos alejados universales para Daewoo TV son: 002 102 110 214 303 311 314 403 407 415 502 503 611 614 805 809 909. Intente ?sos - esperanza de I que ayudan a un pedacito.
I had to translate (roughly) from the asker's question. Here is where I got the list from:
http://dogbytecomputer.com/universal-remote-control-code-list.html
Posted on Mar 10, 2011
Nesesito saber el codigo para un tv mitsui
Mitsui 0067 0586 0517 0039 0265 0041 0385 0102 0066 0247 0324 0401 0463 0473
0393 0609 0485 0193 0379 0546 0065 0238 0075 0225 0221 0365 0574 0744
1067.
Feb 06, 2012 | Motorola Mobility DRC800 Universal Remote...
Nesesito los codigos para controlar mi tv panasonic
Hola mi nombre es Kimberly Escobar con DISH Network. Sera un placer asisterle proveendole la informacion que necesita. Algunos codigos que pueden ser programados a un televisor Panasonic so los siguientes: 700, 734, 512, 644, and 685. El procedimiento a integrar uno de estos codigos al control para que funcione con la T.V es el siguiente: oprima el boton de T.V localisado en la parte de arriba del control hasta que los demas botones se prendan en rojo, una vez esto suceda ingrese uno de los codigos seguido por el signo de numero por ejemplo 700#, el boton de T.V deberia iluminarse 3 veces en rojo despues de esto puede tratar el control para verificar que funcione. Este link tambien le puede ser de mucha ayuda aqui encontrara mas codigos e informacion a programar el control http://www.dishnetwork.com/SupportSection/remote-setup. Si necesita informacion adicional o mas ayuda por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le ayude.
Feb 12, 2011 | DISH Network IR Remote Control
Hola nesesito el codigo de un control dish 103602 el codigo que quiero es para una tv sanyo si me pueden ayudar mandenme los datos a este correo
Hola sharkys_cybe para programar su control de DISH Network para su televisor Sanyo hay varias formas que se puede hacer. La primera forma es mantener pulsada la tecla TV hasta que todos los botones de modo de luz y luego los códigos de la TV Sanyo son: 590, 683, 090, 121, 500, 183, 111, 589, 542, 754, 621, 563 , 512 o 652 suguiente del codigo presione el signo de #. Yo también dejo el link para ayudar con una "exploración de energía". http://www.dishnetwork.com/SupportSection/power-scan-instructions
Feb 02, 2011 | DISH Network IR Remote Control
Mi caja convertidora es zenith y quiero programar el control de la caja convertidora con mi television zenith
como puedo conseguir el control remoto de mi caja covertodora se me descompuso y no puedo programar mi senal
Jan 30, 2011 | Abt Television 1745 Remote Control
Tengo un contro remoto universal marca philips y no tengo los codigos para programar otros aparatos
necesito el codigo de un remoto universal RM-230E para un dvd portatil accurian
Sep 05, 2010 | Televison & Video
Nesesito el codigo de un tv jvc para programar
Apr 06, 2010 | RCA TruFlat 27F520T 27" TV
CODIGOS PARA EL DAEWOOD TV DEL CONTROL REMOTO RCU403A
NO SE EL CODIGO DE MI CONTROL REMOTO RCA 403, PARA MI TV MAGNAVOX..... AYUDENME, PLIS
Jan 28, 2010 | RCA RCU403 Remote Control
COMO PROGRAMO LA TV A MI CONTROL REMOTO DE DISH
Hola! mi nombre es Kimberly Escobar trabajo con DISH Network. Para programar el control remoto con su television hay ciertos codigos que se pueden integrar al control para que pueda funcionar con la television estos codigo son diferentes dependiendo de la marca de televisor que tenga. Es importante saver cual es la marca para saber que codigo se va a integrar este link puede ser de mucha ayuda aqui puede encontrar los codigos necesarios y el procedimiento a como integrarlos http://www.dishnetwork.com/SupportSection/remote-setup si tiene preguntas adicionales o necesita mas ayuda por favor contactenos directamente al 1800-333-DISH.
Jan 16, 2010 | DISH Network IR Remote Control
El codigo del control remoto de una tv mitsui
Dec 19, 2009 | Televison & Video
Televison & Video Logo
417 people viewed this question
Top Televison & Video Experts
Electro Med Services...
