Question about Sport & Outdoor - Others
HOW DO I ADJUST THE SIGHTS ON A BERETTA NANO? THANKS
How do adjust the scope on an airsoft gun?
For magnified scopes and plain old red dot sights, there are usually two dials you adjust - one for up and down, one for left and right.
My ACOG replica and BSA red dot sights require a small flat head to be able to adjust said dials. Most sights follow the same thing, aside from holo sights which have buttons that don't require tools.
May 30, 2018 | The Optics
Charles Daly 9mm hand gun. How do I adjust the sights?
Are you sure, the reviews seem good on it?
How do you sight a handgun?
The same way you sight in any other firearm. You set up a bench rest, line up the sights with a paper target, fire three rounds, then adjust the sights as needed (assuming, of course, that it has adjustable sights - many pistols don't). Then you repeat as necessary until you achieve zero.
I found this and part of the review is interesting.
The one irritating thing is the magazine disconnect safety. While I think it is a great idea it is not well executed with the stock magazine. (it only included one) The stock magazine has a matte finish and doesn't drop down at all when the mag release button is pressed. So if my wife is getting wrestled down and hits the mag release thinking it will disable the gun, it may not even work. With the Mec-Gar magazines they drop down a little, but not always enough to engage the mag disconnect safety. That means the only time this safety could come in handy would be when some person thinks the gun is unloaded because the mag is out. I'm thinking about installing an aftermarket wide-faced trigger that defeats this mag disconnect safety. That should help the trigger pull. But I did notice that my point of impact is much different when I pull the trigger with the pad of my finger instead of the power crease. I'd have to buy a drift punch just to re-adjust the sights.
- See more at: http://www.budsgunshop.com/catalog/product_info.php/cPath/21_225/products_id/81389/Charles+Daly+Hi-Power,+9mm,+10-round,+Blued#sthash.qnHI8oSO.dpuf
Jan 01, 2016 | Optics
How much is value of gun
You should indicate the make and model of the gun you want to buy.
Maybe you can get some interesting information from this website:
http://gundata.org/details/gun/7/pistols/beretta-px4-storm-compact/
Apr 24, 2015 | Optics
How much is the value of a gun
Where is the crank senser located on a 1995 chev beretta
On 1995 Chevrolet Beretta 2.2L SFI OHV 4cyl the Crankshaft Position Sensor is located under hood, passenger side, rear engine area,mounted on engine under intake manifold.
Hope this helps, and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment. Have a nice weekend and thanks for using FixYa.
Jose.
Oct 14, 2011 | 1995 Chevrolet Beretta
Have no idea how to set up the sight on my air gun
I don't have this particular model. Chances are, those are not "knobs" but caps. Remove the caps as you would remove the caps from a pill bottle. Underneath, you should find the adjustment dials for windage and elevation,
You can download a generic Simmons scope manual here:
http://www.simmonsoptics.com/downloads/manuals/archive/HSI_Simmons%20Generic%20Scope%20Adjusting%20Instructions.pdf
Apr 04, 2010 | Simmons 511070 4x32 22 MAG Riflescope -...
I AM WONTING TO REMOVE THE FRONT AND REAR SIGHTS ON A SPRINGFIELD XP 40 AND REPLACE WITH A TRUE GLOW SIGHTS. HOW IS THE BEST WAY TO REMOVE SIGHTS MYSELF ? I HAVE TOOLS BUT NO PRESS.
Lock the slide in a padded vise and drift the sight using brass punches and a brass or plastic mallet. The brass won't mar the finish and this is how I used to adjust sights or remove factory sights and install night sights for customers back in the day.
Nov 10, 2009 | Optics
Need to reset the time on a factory installed radio on a 1989 chevy beretta
u have turn the radio off usually the tune and seek buttons adjust the time
Mar 26, 2009 | 1989 Chevrolet Beretta
Sport & Outdoor - Others Logo
129 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
