Can I buy a lint filter or trap for my LG Front Loader washing machine.
    New Friend:
  • 50 Answers
Of way not you can purchace
Posted on Oct 22, 2013
onthejob5130
  • 640 Answers
SOURCE: cleaning the lint trap of my Affinity washing machine
no lint trap...the best you can do is give it a hot wash bleach with a cold rinse,,,onthejob
Posted on Jan 31, 2009
TechBrian
  • 15 Answers
SOURCE: Blocked filter in Fisher & Paykel washing machine top loader
Fisher & Paykel washers do not have lint filters inside the tubs as they are designed to drain away any debris from the wash during the drain cycle.
Posted on Mar 10, 2009
  • 4 Answers
SOURCE: bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Posted on Jun 16, 2009
pride applia
  • 232 Answers
SOURCE: How do I remove the lint trap holder. I have lint
you have to remove the top then the control pannel then the entire front. are you ready for this?
Posted on Jan 08, 2010
Testimonial: "Even though it was not what I wanted to hear, I do appreciate the incredible help. You guys are the best!"
SOURCE: washing machine stops and flashes 4E
1. WATER SUPPLY ERROR – Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Posted on Feb 23, 2010
I HAVE A WHIRLPOOL TOP LOADER MODEL 3LSR6253E01 MY WASHING COMES OUT COVERED IN LINT. I CANT FIND A FILTER ON THE MACHINE IS THERE ONE? PLEASE HELP THANKS KATE
All washing machine have lint filters to protect the pump, but they generally have quite large holes and although called 'lint' filters, they are to stop baby socks and coins getting into the pump. They are always at the bottom of the machine behind the front kick panel on a front loader or under the agitator on a top loader.
If your washing comes out covered in lint, you need to find the item that is shedding it. May also be paper tissues left in pockets. We only have one item that sheds lint and that is a bathmat. We wash it separately.
Take a look at this video.
Washer Filter Plug Kit part 285868 How To Replace
May 26, 2016 | Whirlpool Washing Machines
I HAVE A WHIRLPOOL FRONT LOADER MODEL 3LSR6253E01 MY WASHING COMES OUT COVERED IN LINT. I CANT FIND A FILTER ON THE MACHINE IS THERE ONE? PLEASE HELP THANKS KATE
No, there is no filter- but you should check the drain pump trap for a mass of fibers/lint. Usually, there is a service door on the lower front of the machine that leads to the pump... Have some towels ready for residual water, but I would check there first...
Samsung sw80usp wont drain
On my LG I removed the front panel and there was a drain trap with a filter. I removed and cleaned the filter. Mine started draining again. (assuming you have a front loader not a top loader)
May 07, 2014 | Samsung Washing Machines
Where is the lint trap on the front loader
There is no lint trap. There is a coin catcher on the pump. The design of the wash action on a front loader is such there is less lint than on standard machines. One of the bennies of the design.
Eric
May 20, 2010 | Kenmore Elite 45986 Front Load Washer
Where is the filter?
To find the filter you need to do the following steps. Find your lint trap. Lint traps in washing machines can be in the agitator (the large plastic piece in the center of the tub), at the top of the washer on the rim of the tub, or attached to the washing machine's drainage hose. Pull out the agitator tube to check for the lint trap. Peel any loose lint from the filter. Scrub away lint that doesn't peel off easily with a heavy-duty paper towel or a wet sponge. Feel your way around the top rim of the washing machine's basin. If you locate a trap, pull it straight out of the machine. Peel away loose lint and follow up with a wet sponge or heavy-duty paper towel. Check your machine's drainage hose for an attached lint trap. Remove the trap and peel the top layer of lint off. Rinse the trap in low-pressure, warm water. Reattach to the drainage hose. Check for and remove any lint or debris that may have dropped into the washing machine basin during the cleaning.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Hotpoint Aquarius WF210 Front Load Washer
I have a Whirlpool Duet front loader that will not drain properly because of the extra lint from a rug. I have unclogged the pump and ran the Rinse/spin cycle about 30 times to only get about a handful of...
lon this type of machine there is a lint trap on the lower right of the bottom access panel. It is part of the pump. Disassemble the pump/filter see if anything is caught in it. If there is clean and try again, if problem remains then replace pump/filter combination
Sep 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LG washing machine wm0532 is flasing an OE
check the drain filter in the bottom left corner behind the access door
Mar 19, 2009 | LG WM-0532HW Front Load Washer
LG FRont Load Washer Dryer WD-1256RD filling up with lint
If you have not done it already, replace the lint filter. Follow instructions on manual. The lint filter access should be on front side of machine.
Other users had same problem on this model, I quote:
"I've only had it 2 weeks so far. It seems to be collecting lint/fluff all around the rubber door lining"
Source here.
Sometimes there may be too much lint if you use excessive softener and detergent.
Feb 08, 2009 | LG WD-12124RD Front Load Washer
Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Jan 13, 2009 | LG WFT1071TP Top Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
