Question about Shop Vac 201-12 Wet/Dry Vacuum
Shop vac model 4025 filter cleaning - Shop Vac 201-12 Wet/Dry Vacuum
4 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: my shop vac won't turn back on after emptying
I'm afraid you'll need to take it apart. the switch is mounted in a plastic holder in the top. While you got it apart and without it plugged in, check to see that both brushes are touching the commutator. there should be sufficient spring tension to hold the brushes against the spinning part [commutator] if even one brush isn't making contact it won't spin.
Posted on Sep 11, 2007
  • 10 Answers
SOURCE: after i cleaned the filter, shop vac doesn't turn back on
IT SOUND LIKE THE MOTOR WENT BAD OR IN SIDE THE PANLE A WIRE CAME LOSE
Posted on May 04, 2008
  • 120 Answers
SOURCE: using shop vac 52722-90 for wet applications
yes, the foam filter is what you should use, also make sure you remove any bag, or paper filter, the water would make it fall apart.
Posted on Sep 16, 2009
My shop-vac stopped mid-job with no warning
Maybe it over heated or the hose was jammed. Unplug it for a few minutes, check the hose for any stuck debris, then plug it back in. Shop vacs also come with a filter. If the filter is too dirty, it might have shut off as a safety precaution to not cause a fire. Follow directions to clean the filter. Hope this helped. Dee
Oct 13, 2014 | Craftsman Shop Vac 8 Gallon Replacement...
My shop vac is not sucking anything only blowing air out of the open hole where the hose should go if I wanted to blow something. I want it to vacuum not blow out. The filter sleeve and dry cloth are...
I just had the same problem, the vac wouldn't suck in. Turned out to be because the filter was WET. It works great when I take the filter off before sucking up water or liquids! Not sure if this applies in your case, but definitely something to keep in mind. : )
Jan 17, 2011 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
May 16, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
Vac doesn't work well after cleaning
check your filter
it the round thing hanging from the middle
you may need to clean or replace your filter
you should never leave the filter in while using it as a wet vac that will ruin it immedatly
Oct 09, 2009 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Old shop vac
Yes there should be a filter fitted onto the top section.
For suppliers, it would be cheapest to find your nearest stockist, or buy online and have it shipped. It's still current stock - so spares should be readily available.
Sears stock it -
CRAFTSMAN FILTER
Thank you for using Fixya,
Sep 22, 2009 | Craftsman 17765 Canister Wet/Dry Vacuum
Ridgid 16.5 gallon motor running with no suction
When you use the shop vac for cleaning up water you must remove the filter.
The filter is for dust particles not for water
I would replace your filter and dump the water out from the shop vac, Also after each time you vacuum up water dump it out of shop vac.
I hope this helped you happy new year!
Jun 30, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
There are no known vacum bags for a model wd06350 vac
This type of vacuum does not use a bag. If you are worried about clogging the filter cartridge try using a paper filter for a shop-vac. They are relatively cheap and are available at most hardware and department stores. These are made to simply wrap around the big cartridge. A rubber band will hold it in place.
Feb 09, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Shop Vac Model 758.17871
I would suggest it if it gets dirty muddy you can always clean the filter alot easier than replaceing vac
Dec 21, 2007 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Shopvac 2010
Just be sure to remove the paper filter bag that fits over the foam filter before vacuuming liquids. It's easy to get it wet and they don't work very well when that happens.
Dec 10, 2007 | Shop Vac 201-13 Wet/Dry Vacuum
Shop Vac 201-12 Wet/Dry Vacuum Logo
53 people viewed this question
Top Shop Vac Vacuums Experts
Mike
maple flats
Level 1 Expert
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
