Question about Kirby G4 Bagged Upright Vacuum
I watched video on replacing the fan. I am a grandmother and have never replaced anything. Everything went fine until I tried to remove the shaft holding the fan in. I keep turning the shaft to the right but it never releases from the unit. I can see wheels and a belt on the opposite side of the unit going around. Did I ruin the vacuum by letting this problem go too long. I don't know how to remove the shaft if it is stripped (that is all I can figure must be wrong).
  • 32 Answers
Those video's aren't detailed enough. You have to take apart the other side too. Follow the directions on this page and you should be able to do it. You can order a new fan on amazon for about $12.
http://www.greatvacs.com/education/kirby-fan.html
Posted on Oct 22, 2013
  • cmoore2440
    cmoore2440 Oct 22, 2013
    The video was very helpful and I have replaced the fan. I think I may have killed the motor though. Now the motor just hums a little and does not provide power to the fan. Do you think I have blown the engine?
3 Suggested Answers
SOURCE: belt replacement
The belt handle should be turned so the red arrow is lined up. Then make sure the belt is hooked on the inner assembly handle. Reconnect the vaccum assembly to vaccum and turn handle to allow green arrow to align and the belt is hooked on motor rod anmd your ready to vacuum.
Posted on Jun 17, 2007
reddevil6
  • 1673 Answers
SOURCE: Fan replacement gone bad!
I take it the armature is not moving at all when you are turning the pulley(to the right, is right). You may have to pull the motor asm. out, remove the 4 scres and nuts off of the front bearing plate and pull it out along with the armature. I can't rmember if there is enough romm after pulling it out, from the inside to cut the shaft off with a hack saw. It is either that or replace the front bearing plate along with the armature.
Posted on May 26, 2008
Replace fan
Replacing a broken fan in a Kirby is not an easy job. You have to take off the handle, the top cover, the front piece covering the fan and then stick a wrench down onto the motor shaft to hold the shaft tight while you stick an awl or small screwdriver into the hole on the spindle sticking out the front of the vacuum. Turn the spindle to remove it so you can remove the fan. Install the new fan and reassemble the vacuum.
Mar 11, 2014 | Kirby Vacuums
I had problems replacing the fan on my KirbyG4 but with the help of this site was finally able to do so. When I put it all back together and turned on, the motor was very weak and then stopped and I smell...
There are a couple of possibilities here. First, I hope you made sure the new fan spun freely after installation, if so, and if you re-installed the rest of the parts correctly, you may have the belt installation crank on the front of the agitator housing in the up position yet. This is when you've installed the belt over the motor spindle. After that you need to continue cranking the assembly on the front until it's all the way down. That releases the belt so it can run freely and turn the brush. If it's still in the up position, it has the belt locked and the spindle will rub against the belt making the smell and smoke. Also if you closed the metal bottom plate and caught the belt under it when you finished the installation, that will also keep the belt from turning with the brush.
Oct 22, 2013 | Kirby G4 Bagged Upright Vacuum
Im trying to replace a fan on a simplicity freedom f3300 vacum. HOW DOES THE OLD FAN COME OFF? It seems to be pressed on but I dont want to brake anything.
Assuming you have the motor out of the fan housings, check to see if you can move the fan around clockwise/counter-clockwise. If the fan is not moveable, the fan has probably melted to the motor housing. Replacing the motor is recommended as the plastic motor housing under the fan is probably damaged/melted. It could still be fixed but there is a possibility of damaging the housing. If after removing the fan following the directions below be sure to remove/trim any melted plastic away from housing before replacing fan. Not trimming the plastic could result in your new fan melting again to the housing when the machine is turned on. If you have an older model pay careful attention to the carbon brush area, if there are plastic posts holding the carbon brush springs, these are easy to break.
If the fan is movable, remove the nut and washers from fan. Use two large flat head screwdrivers and place them opposite of each other under the bottom lip of the fan between the fan and motor housing. (it might be a little easier if you have an extra pair of hands to hold the motor). With the flat heads in place, push the handles of the flatheads toward the side of the motor where the belt shaft is. If the fan does not pop off rotate the position of the screwdrivers and try again. Pay close attention that the fan washer is installed before replacing your new fan. after installing the new fan, rotate it several times making sure it isn't rubbing anywhere.
If you need any further help feel free to contact me.
Tim
TheVacCenter.com
Mar 02, 2013 | Simplicity Freedom Cord - F3300 -...
My g7 will not pick up anything
Without more information, my first guess is a worn or broken fan. You can take it to a shop and have it replaced, or buy one from a Kirby store and replace it yourself. There are also on-line stores where you can purchase impellers.
Here are instructions for replacing the fan:
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302
Here are video clips showing how to do it yourself.
http://www.youtube.com/watch?v=WJvw4NujOpU
http://www.youtube.com/watch?v=wS9nrQr_Kvc&feature=related
Feb 12, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G4 motor is very loud. It has suction but seams to be a lot louder than when we bought it in 1996.
Hi There,
Most likely it's just the fan that is making the noise rather then the motor. The way the Kirby vacuums are designed, anything hard that's vacuumed up such a coin, or other hard things can break the fan.
In order to check and see if it's your fan, remove the front part of the vacuum that contains the roller brush and belt. If you're not sure how to do this, here's a video that shows you how to change the belt, but will also explain how to get the front bell shaped housing off:
Once you have the front cover off, look inside the vacuum directly behind the motor shaft. You will be able to inspect the fan here. Turn the motor shaft which also turns the fan, and see if there's any cracks, or if the fan blade is broken. I think most likely you'll see the fan damaged somehow.
Here's a video repair that we've put together that explains step by step on how to replace the suction fan on your Kirby:
Part 2:
Hopefully this helped you fix your Kirby. Please be so kind and rate the repair, or leave feedback if this was helpful to you. Thanks so much,
Chris Jones
GoVacuum.com
May 02, 2010 | Kirby G4 Bagged Upright Vacuum
Th end of the shaft that come from the motor is worn out, and won't hold the belt well. How do I change it?
Thanks for the clarification. I have never seen this problem previously in a Kirby. I wonder if the belt keeps sliding off because it's been stretched out? After about 1-2 years, the belts on the Kirby will stretch out to a point where there can possibly slide off the motor shaft. Have you tried just replacing the belt on the unit first?
If you're sure that it's not the belt that may be stretched out, and you'd like to replace the motor shaft, you certainly may do this. The only problem with this is the motor shaft is not sold by itself as a separate part. The only way to purchase this motor shaft is to purchase the entire fan assembly, which includes a new fan, and the hardware necessary on the fan assembly.
Here's a parts diagram that shows you the motor shaft is sold only in a completely assembly:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/kirby-generation-parts-diagram.pdf
If you haven't already purchased the motor shaft, here's a direct link to the motor shaft and fan assembly on our website:
Kirby Generation Fan Assembly With Motor Shaft and Hardware
In terms of installing it, we've actually recorded a video repair on how to replace the fan assembly, which involves removing the motor shaft in order to get the fan off. Since you have to purchase the fan assembly anyways in order get the motor shaft, you may want to go ahead and replace your fan assembly at this time also. Even though your fan may not be broken, on Kirby's the fans can become coated with dirt and fine dust, which can sometimes lead to the Kirby exhausting a bad smell. If you'd rather not replace the fan, you may remove the motor shaft without disassembling the entire machine, you'll just need to secure the fan somehow so that the fan doesn't spin while you're using a nail to turn the motor shaft off.
Anyways, here's the video repair that we recorded. I hope that this helps you. If you found this helpful, please kindly rate my repair helpful by clicking the thumbs up icons in the top right hand corner of the repair. This is really what keeps Fixya repair professionals continue to give free repairs online.
Here's Part 1 of the video:
Here's Part 2 on Replacing the motor shaft and fan:
If you have any follow up questions, I'd be more then happy to answer them for you, please just add another comment here on the repair page, and I'll be more then happy to answer any follow up questions that you have. Thanks again for rating the repair, I greatly appreciate this.
Chris Jones
GoVacuum.com
Apr 15, 2010 | Kirby G5 Bagged Upright Vacuum
Replace Kirby legend II fan (impeller blade)
In order to replace the fan you will buy a 2 or three piece lexan fan kit containing the fan a spacer and shaft.
You must remove the carpet head and then looking from the back of the machine you will find a series of philips screws on the outer edge of the fan housing facing towards the front, several of which may be partly covered by the motor housing. You will remove the forward facing screws to allow the housing to separate and reveal the fan.
If you are lucky there will be a sideways hole through the impeller shaft allowing you to slip a nail through to help twist the saft to unscrew it while holding the fan .
The shaft will turn off revealing a threaded motor shaft with spacers which the broken fan will slide off revealing a second spacer at the back . Be sure to replace these spacers in the same order when re-assembling the unit. Secure the shaft hand tight. Post back to advise if you need further help
Oct 07, 2009 | Kirby G4 Bagged Upright Vacuum
It sounds fine in the upright position but when I drop the handle to vacuum there's a terrible whining sound from the front. Something's up with the roller. Can the belt go bad?
If its a loud clicking sound then it may be your clutch is bad. I called Dyson about mine and thats what they diagnosed it as. They wanted $125 to fix it. I went on ebay and bought a clutch and tool to help do the job and replaced it myself for less than $50. I watched a video on youtube about how to replace a clutch in my Dyson. It was done step by step and made the job so easy. It works perfect now.
Jul 17, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Oreck xl 9100 how to replace the fan
I just replaced the fan (plastic) on an XL9100. I assume you got the bottom plate off (5 screws).
Undo the single screw holding the suction housing in place.
Remove the two screws holding the motor in place and gently lift the assemble up, being careful not to stress the wires. The motor and fan assembly should now be exposed. If the nut holdling fan in place is removed, the whole fan should slide right off. If it does not, try a little WD-40 on the shaft and wiggle and move from side to side. (I slipped a small drill bit between the motor fan (motor cooling fan) to prevent the shaft from turning when you remove the nut.) Be sure you turn the nut counter-clockwise to remove it.
You should now have the fan off. Reverse the procedure to place the new fan - following the directions carefully as some assemblies need a washer and "feathered" washer on the top.
Assuming everything went well, it should work.
My 9100 sucked a magnetic bearing and trashed the metal fan to where suction was weak. The new fan works great.
Cheers
Mar 26, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Hoover Elite II Model # u4689-910 Impeller replacement
I have had to use a dremmel tool to cut the plastic around the shaft, you can also something sharp and a hammer to break away the remainer of the fan. There are no threads on the fan so to keep truning it may or may not get it off. Just have to watch and not damage the motor shaft and housing.
Dec 31, 2007 | Vacuums
Kirby G4 Bagged Upright Vacuum Logo
64 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
