Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What spark plug (make, number) can I get for a Poulan 2025 chainsaw and what gap?
  • 71 Answers
Replace with Champion CJ-7Y or RCJ--7Y spark
plug and tighten securely with a 3/4 inch
socket wrench. Spark plug gap should be
0.025 inches
R stands for resistor on the RCJ-7Y. Either plug will work.
PDF of Owners Manual
If you have other questions about your saw, there is an 800# at the top of PDF.
Hope this helps.
Posted on Oct 22, 2013
5 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: I NEED TO KNOW THE SPARK PLUG GAP AND MAGNITO GAP
Spark plug gap is .025
As for the air gap in-between the flywheel, and magneto, I generally start with a piece of notebook paper in-between them.
After the bolts are snugged down, turn the flywheel by hand to spin the paper out.
Posted on Oct 29, 2009
dontbother10
  • 2220 Answers
SOURCE: Need to replace fuel lines. routing of lines
A Poulan 2025 IPL follows:
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
http://www.ordertree.com/modelinfo/PWE/2025-Gas-Saw/75.2025-Gas-Saw.1.59.1.html
Small hose (filter on bottom) long enough to reach all corners inside tank, to lower carburetor connection. Please leave the 2 carburetor connections long enough to reverse until the saw is running.
Upper carburetor connection, small hose to suction side of primer.
Pressure side of primer (large hose) to middle of tank. nothing on bottom, length not critical.
The IPL is deceptive it appears the filtered hose connects to the primer; it does not.
Typical fuel system link and a couple of suggestions here:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 16, 2010
  • 4088 Answers
SOURCE: I replaceed spark plug,and still on spark. Whats
Remove the flywheel side cover to expose the flywheel and ignition module. Check the flywheel magnets to ignition module gap with a thin business card for a gauge. If ok, remove the grounding wire that goes to the ignition switch and try for spark again. If still nothing, it's new module time. If removing the grounding wire got it to spark, replace the ignition switch or perhaps the grounding wire has shorted out on it's way to the ignition switch. Hope this helps!
Posted on Apr 22, 2010
seanpwright
  • 2030 Answers
SOURCE: sparkplug gap for poulan chainsaw model 2025
.030 -.045
Posted on Apr 25, 2010
One more try before I trash it. I have a poulan p3314 chainsaw. It is 2 years old. Installed new carb,fuel lines,air filter, and spark plug. Fuel is routed properly. Can't get unit to fire. Any ideas.
Check the gap between the magneto and the magnet on the flywheel, if it is too much of a gap you wont get spark. We are talking .007 inches or less. You need a feeler gauge to set this
Apr 22, 2016 | Poulan Pro 14" Gas Chainsaw 33CC P3314
What is the air gap on the coil & the spark plug gap on a 42cc poulan chainsaw
Hi Mike:
It's hard to go wrong with 30 thou on a spark plug, and If I remember correctly, isn;t there a mark on the coil bracket that shows where to line it up? As long as it's not touching the flywheel those saws want to run.
Bolt it up and back to the woodpile!
Jul 16, 2015 | Poulan Garden
Gap coil on ppb 330 poulan pro
First and foremost ppb330 is a model number for a grass line trimmer, gas model.
Second, I am unsure what you are asking. Gap coil?? Do you need the spark plug gap for your chainsaw? That gap is .025.
I hope this helps. If not, please re-post with the correct model number for you chainsaw.
Jul 08, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What is the gap setting for a 221 pro 40cc poulan chainsaw
The gap for all Poulan chainsaws, regardless of the spark plug used, is .025.
Jun 12, 2014 | Poulan Garden
What is the spark gap for 221 pro 40cc
Jun 12, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What is theair gap setting poulan 2150 2.1c i
.025" or .6MM is the spark plug gap I assume air gap is what you were referring to is spark plug?
May 16, 2014 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Proper spark plug gap for poulan chain saws
I believe the proper spark plug gap for poulan chainsaws is .025-inch. That goes for all units.
Aug 22, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
309 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
