Question about Magic Chef Refrigerators
My model #RB193T magic chef freezer refrigerator motor keeps running and does not shut off.
  • 249 Answers
SOURCE: refrigerator will not cool
there is a fault in compressor motor the clicking is the overload cutting off,If its a relay on the motor its worth repairing,If its the whole motor it would be too costly,I know
its not what you want to hear,but thats the size of it.the relay is in a black plastic box on the motor itself,I hope its that
Posted on Dec 16, 2007
  • 2920 Answers
SOURCE: Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Posted on Aug 27, 2008
mastatech
  • 478 Answers
SOURCE: refrigerator makes loud noise when motor is shutting down
Check for dirt, vacume throughly. Visually inspect fan blade, for anything not normal.
Posted on Mar 11, 2009
  • 44 Answers
SOURCE: water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Posted on Apr 18, 2009
  • 16 Answers
SOURCE: bottom of refrigerator not getting cold enough
have you cleaned out the coils underneath the fridge? it's very simple. pull the fridge out, look underneath(try pulling off the bottom grill from the front for more access), and start cleaning. to much dust and lint will hinder the coils from cooling. A vacuum with the brush attachment or little broom works good.
Posted on Jul 27, 2009
My magic chef rb193p fridge wont stop running. I replaced the fan motor 4 months ago. The top of the fridge compartment is freezing. Is the defrost timer bad?
I had the same problem. When the evaporator heater stops working, frost will build up until there is no air flow to the refrigerator. This will cause the refrigerator to keep running. Remove everything from the freezer and remove the pan at the bottom and see if there is a frost buildup. .... Bruce
Jun 18, 2011 | Magic Chef CTB1922 Top Freezer...
My Magic chef refrigerator/freezer has a problem with the refrigerator part getting warm. I tried shutting it off and letting it set for 24 hrs and that worked a couple of times, but now it just doesn't...
sounds like your refir has an interior circulation fan which is not running. If not the vent to allow cold air to recirculate is closed. Could be the freezer is icing up and defrosting it is helping somewhat.
Feb 03, 2011 | Magic Chef Refrigerators
Magic Chef refigerator/freezer stopped running
if you said stop running id assume that there is no power?? even with good electrical input..
for that instance, better check.charred cables.. if not there maybe a problem with timer itself..
Nov 05, 2009 | Magic Chef CTB1922 Top Freezer...
Magic chef not cooling
The compressor is shutting down because it is drawing too much power and overheating. The clixon detects this and shuts off all power till it cools - then it resets and supplies power back to compressor until it overheats and problem repeats itself.
So what is responsible for overheating? Well, if there is an obstruction in the cooling system (high pressure side), the compression goes up past spec and the motor labors and slows down, creating less back emf, and increasing current consumption > then overheats and turns off. OR, if some of the the motor windings have had the insulation melt off, then the motor has less resistance than designed, more current goes through and again it overheats and shuts down. In this case your motor is fubar and needs to be replaced.
Apr 24, 2017 | Magic Chef CTB1922 Top Freezer...
Does not get cold enough.
HI THANKS FOR YOUR QUESTION.tHE FIRST THING TO LOOK AT IS . iF YOU HAVE FROST BUILD UP ON THE WALL, OF FREEZER.#2. IS THE FAN RUNNING. #3. CLEAN ALL COILS AT THE BACK, OF FRIDGE, VERY IMPORTANT . tHANKS THE APPLIANCE DOC.
Oct 04, 2008 | Magic Chef Refrigerators
Not a themostat. 3 most common causes are defrost problem (frost on back freezer panel), bad evaporator fan motor, or damper.
Sep 24, 2007 | KitchenAid KSRS25ILSS Side by Side...
Refrigerators Logo
50 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
