Question about GE Profile JTP18 Electric Single Oven
GE Profile model JT910 clock will not work. All other functions work. Control panel is blank and pressing the clock pad does nothing. Can you help ?
Powerman
  • 68 Answers
SOURCE: GE Profile Oven FTP18 - F7 Code
The F7 problem is usually caused by a short circuit between segments of the ribbon cable connecting the touchpanel to the ERC. Open the touch panel. Insert a slip of paper (yes paper) between the two segments of ribbon cable where it exits the slot in the touchpanel. Try to work the paper down as far as possible. A piece of file card may work better. See the attached photo. If you have a metal touch panel, also add slips of paper between the ribbon cable and the edges of the slot. I have shared my solution with over 795 folks with the F7 problem. Most report success. Cleaning the contacts is a myth. It is only a short time solution as when you move the cable you are temporarily disrupting the short circuit, but it will grow back. The short is caused by what is know a dendrite. It is a growth from the silver traces on the membrane switch conductors. If you want more technical information, contact me at hutchipop@yahoo.com. The solution should work for all ovens made by GE including Kenmore as far back as 1998. Don't be concerned about putting paper in the top of the oven. GE places a set of instructions in the top of the oven. Many folks have replaced touchpanels only to have the problem return.
Posted on May 29, 2007
Powerman
  • 68 Answers
SOURCE: Time flashes ...No other electronic button function
You may have the dreaded F7 problem. Go to the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
Please let me know if this works for you. I have shared this fix with over 1600 folks and most report success. You can email me at hutchipop@yahoo.com
Regards,
Charlie Popeck, P.E.
Consulting Engineer
Posted on Mar 10, 2008
aborcass
  • 2651 Answers
SOURCE: GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Posted on Mar 30, 2008
Sea Breeze
  • 4655 Answers
SOURCE: GE Profile JT952 Touch Pad Button Issue
Try this link
Posted on Mar 28, 2009
localwonder
  • 6784 Answers
SOURCE: My G.E. Profile would turn on then immediatley
Hi. The F-2 code will appear if the control board is sensing an abnormal oven operating temperature above 615F-630F, during bake, or above 915F-930F, during the self cleaning stages.
If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
NOTE_
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
Posted on Dec 03, 2009
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    GE profile oven 326B1230P001 error code F7 will not go off. what does it indicate?
    F7 A = Function pad button stuck or
    B = Bad clock Unstick button or
    Replace Electronic Range Control (ERC)
    Sep 05, 2011 | GE Profile JTP18 Electric Single Oven
    !0 year old GE Profile Double Oven. Control Panel repaired but oven is again not working with a "F7" mal function indicator on panel. Model # JT 950 S0A3SS
    Hello & Welcome to FixYa
    F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Sorry for the bad news....but hope you understand. Please get back to me if you have any other questions.
    Kevin
    Jan 03, 2011 | GE Ovens
    F7 error code
    Hi
    On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
    On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
    On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
    check out more detail here
    hope this helps
    Aug 14, 2009 | GE Profile JTP56 Electric Double Oven
    Ge profile double oven. The bottom oven is beepin and f7 is showing. we have not used the oven today. what does this mean
    HI, this is a Stuck button on the function pad or, the clock or ERC(control board) is damaged. Try to free the stuck button.(in some models, this is not an option). if the pad is fixed(keypad and board are integrated), simply replace the oven control board.
    Jul 27, 2009 | Ovens
    I have a GE Profile built in oven and the F7 display with the beeping sound. Clear or cancel will not work What do I do
    Well, F7 error code occures due to
    Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
    REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
    Good Luck!!
    Jun 28, 2009 | GE JGRP17 Gas Single Oven
    F7 Code on my GE Profile Oven
    Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
    F7 error
    Good Luck!!
    Have a nice Day!!
    May 03, 2009 | GE Profile JTP18 Electric Single Oven
    My GE oven wont stop beeping it has an FO on the screen. All the buttons will not press. I just bought the house and have no idea if its done this before. Please help!!!! Chelsea
    F0 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
    Dec 12, 2008 | GE Profile JTP18 Electric Single Oven
    My GE profile oven is giving me a code f7 and I can't clear it.  What does this mean?
    Best of luck!!
    Thanks
    Dec 02, 2008 | GE Profile JTP56 Electric Double Oven
    GE Profile JTP18 Electric Single Oven Logo
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
    Are you a GE Oven Expert? Answer questions, earn points and help others
