Question about KitchenAid KDRS483VSS 48" Commercial-Style Dual Fuel Range with 6.3 cu. ft. Total Capacity Self-Clean Ovens, True Convection Bake, Two 20K BTU Dual-Flame Burners, Glass Touch Controls and Star-K Certified: Stainless Steel
LED screen fogs up when an oven and range are on at the same time.
    Top Expert:
  • KitchenAid Master
  • 9,472 Answers
The seal on the display is broke and you will need to replace the board. Eventually it will short out from the moisture. Here is that part to order.
All parts come with a 365 day, any part, any reason return policy.
Posted on Oct 26, 2013
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Our larger oven will not turn on and the led lights do not work either. the smaller oven does turn and led lights work. All burners work fine any ideas??
Hello Brian, thank you for allowing me to assist you!
I understand the larger oven of your Electrolux range is inoperable. Let's try resetting your range by either unplugging it or flipping off the breaker for about ten minutes. An experienced service technician may need to further evaluate this issue if it was not resolved with the power reset. In this case, your appliance may possibly be experiencing a communication properly with the EOC (electronic oven control), faulty bake/broil element, or a potential wiring failure.
Dec 16, 2013 | Electrolux E48DF76EPS Dual Fuel Range
How do you remove the light bulb cover in a fivestar 48
You remove your incandescent light bulb and insert your automotive LED light bulb.The LED lights cover the landscape area for people to be able to see.
home light bulbs
May 28, 2012 | Five Star FiveStar 48'' Range Hood -...
Glass in over the range microwave fogged up after boiling vegtables on range top
It will do. The glass is cooler than the water vapour and will condense, causing fogging.
Mar 28, 2011 | Samsung 1.8 Cu. Ft. Over-the-Range...
Very low rumble when oven is on, more noticable as oven warms up.
Sounds like an built-in exhaust fan going bad. Bearings most likely.
Jul 08, 2009 | DCS RGS-305 Professional Gas Kitchen Range
Oven, oven light and oven led display will not work
that sounds like an erc[electronic range control] or clock timer etc. You can check power supply to it but chances are thats what you need.
May 20, 2009 | GE Spectra JBP78 Electric Kitchen Range
I have a Jennaire range and the control panel no longerworks to control turning oven on etc....first the LED display had went out. Now no touch pads work!
The clock is a very common problem the only way you can fix the LED display and it also controls the oven...replace the clock
Jul 11, 2008 | Kitchen Ranges
KENMORE SELF CLEANING FEATURE WILL NOT ACTUATE
Firstly, empty the oven of stuff, including the little thermostat that dangles from the grate, if you value it's life.
Next, close oven door.
Press CLEAN; it beeps and green LED illuminates. LED readout says " -- -- --".
Press the UP arrow; it beeps and LED readout says: ''3:00'', for a three hour burn.
DOOR LOCKED LED blinks while door locking mechanism actuates, then stays on steady. Burner ignites, and it's off to the races.
The exterior of the Range becomes quite HOT, providing an excellent opportunity to educate young children of the concept. ;)
The Cleaning Cycle can be stopped at any time by pressing the OFF/CANCEL button for ~3 seconds. The door will remain locked until the internal temperature of the oven falls below 400F. Nice toy.
Apr 10, 2008 | Kitchen Ranges
LED display not working
Did somebody use the control lock by accident. Here is how to disable it. Hopefully it will work: The Control Lock feature shuts down the control panel pads to avoid unintended use of the oven. The Control Lock feature may be used either when the range is in use or turned off (for example, during cleaning). To lock/unlock control: Before locking, make sure the oven, the timer, and Timed Cooking are off. Press and hold the START pad for 5 seconds until ?CONTROL LOCK? appears on the display. Repeat to unlock, and ?CONTROL LOCK? will disappear from the display. Hope this helps Jason
Sep 04, 2007 | KitchenAid KESC308LSS Electric Kitchen...
KitchenAid KDRS483VSS 48" Commercial-Style Dual Fuel Range with 6.3 cu. ft. Total Capacity Self-Clean Ovens, True Convection Bake, Two 20K BTU Dual-Flame Burners, Glass Touch Controls and Star-K Certified: Stainless Steel Logo
76 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
