Question about Weedeater Garden
Ineed spark plug gap setting for a weedeater leaf blower ---spark plug model c-j8y
    Master:
  • Weedeater Master
  • 645 Answers
The plug should gap at .020
Posted on Dec 13, 2017
slohry
  • 87 Answers
SOURCE: Spark Plug Gap
.030
Posted on Apr 10, 2009
#1 Taper
  • 1041 Answers
SOURCE: How to you repalce a fuel line on a weedeater gb1/22v leaf blower
When replacing fuel line, make sure that you have the correct size lines. Depending on the size of your engine, the lines may vary in size. The primer bulb line will sometimes be larger in diameter than the fuel line to the carburetor. The primer bulb line will be the shorter of the two. When replacing the fuel line, make sure you have enough line to go from the bottom of the tank up to the carburetor. Give yourself a couple extra inches to work with. Cut one end at an angle, this makes it easier to feed down through the hole. Continue feeding the line until it comes out of the gas cap hole. Then cut the end of the line square again and attach the fuel filter that goes on the end of the line. Place the filter back in the tank, then adjust the line so that the fuel filter lays comfortably at the bottom of the tank. Then attach the other end of the line, (where you inserted it), to the carburetor, cutting off any extra line you may have.
Posted on May 23, 2009
  • 148 Answers
SOURCE: Need to know specifications of spark plug for Ryobi Leaf Blower
You can download the manual at www.managemyhome.com. I have the Ryobi 720r and the sparkplug is a champion RDJ7Y.
Posted on Jul 13, 2009
#1 Taper
  • 1041 Answers
SOURCE: weedeater leaf blower FL1500
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spray withcarb.cleaner.Make sure the small screen is free of debris. (Should beable to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 27, 2009
  • 10 Answers
SOURCE: Craftsman 200 mph model 358.794741 Leaf
You need to check if the piston was fired, or if the piston rings was stick.
Posted on Jan 11, 2011
Spark plug gap on a stihl leaf blower shoulder strap
.0020 is the gap.Here's a link to your manual,it's listed in section 26,specifications. http://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/STIHL-BG-56-66-86-SH-56-86-Owners-Instruction-Manual.pdf I also had a B56C and after 2 years,the engine locked up,am very disappointed in these ,also have a weedeater that the carb had to be rebuilt twice,if you leave gas in them over the winter,it messes up the carb,we'll I threw the blower away,got a huskvana from lowes,it is awesome,Stihl has let me down,will never buy another one,guess your having problems now,want to buy my weedeater and 500 chain saw.lol.
Aug 08, 2015 | Stihl Garden
Weedeater gbi 22 leaf blower will not start, how do I start it and what could be the cause?
Replace the spark plug, drain last years fuel and use fresh fuel mix.
Sounds like you may have a fouled plug. A speck of carbon or other debris can short the gap causing ZERO runtime.
Apr 02, 2015 | Weedeater Garden
What is the spark plug gap for weed eater 25cc leafblower
Hi Joyce,try 015" thats 15 thousands of an inch.with imperial feeler gauges.Cheers.Ronnie.
Apr 21, 2012 | Weedeater 25cc Gas Blower ()
What is the spark plug gap for weedeater bv 1850
You shouldn't need to set the gap on plugs when you buy them for handheld equipment. It should be close enough straight from the factory. You can find replacement spark plugs at PartsBuggy.com.
Oct 12, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Not getting any spark. what should I check first
Check the obvious first.
  • Is the spark plug in good condition? No cracks
  • Try a new plug
  • Are you sure no wire is shorting?
  • Have you done any recent repairs?
  • Does a new plug get spark??
Try to change the plug with correct gap new plug.
Jul 04, 2010 | Weedeater 2 Speed Gas Blower FL1500LE ()
Garden Logo
Top Weedeater Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
 steve
steve
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
