My pyle 695 is stuck at the calibration screen and every time i do the calibration test it doesnt get past that step
When i turn on the car the radio doesnt go to the home page it goes to a screen with circle and arrows number 1234
You have the unit wired wrong. When you shut your key off the radio loses ALL power and it needs ACC power to maintain the memory. If not, the unit will reset itself. The screen you see is the touchscreen calibration screen. Just follow the " X " around the screen to 5. Then the unit will boot up again. You will have to reset radio stations and EQ and speaker settings. If you don't fix the ACC wire, you will have to do this A LOT!
Dec 06, 2013 | PYLE Audio PYLE PLDNV695 6.95 DOUBLE-DIN...
Tempo 621T treadmill stuck in incline postion scale is reading 0 but it is not completely down..How to reset my incline button
Run the software calibration for troubleshooting and fix it. See the next steps. God bless you
The Steps for Newer Style Console Calibration
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Lube the elevation motor, shaft and gear. adjust the POTentiomer,
Jan 09, 2013 | Exercise & Fitness
Treadmill wont speed up
RUN the software calibration for diagnose, and fix it.
God bless you
The Steps for Newer Style Console Calibration:
Jan 06, 2013 | Exercise & Fitness
Calibrare distance
yes go to under the HOOD motor, and follow the steps for software calibration.
otherwise go to the instr.manual and see the steps and proceed according.
If you do not have the instr. manual go to
www.fitness.manualsonline.com
God bless you
Nov 30, 2012 | Proform 695 LT Treadmill
How do you calibrate touch screen on alpine pmd-b100t?
There are a lot of steps so you might as well download the manual from
http://phone.manualsonline.com/manuals/mfg/alpine_electronics/blackbird_pmdb100t.html
May 28, 2011 | Alpine PMD-B100 GPS Receiver
Hi! The touch screen on my Garmin nuvi 660 is not working. On boot up I can't get past the reminder to update map data screen. I have updated the unit software and tried to recalibrate the screen. As is...
Try to remove the battery and re insert it back in to see if it will work. Or hold down the power on/off for about 15 seconds, that should do the job.
If that does not do it, then calibrate the screen, to calibrate the screen, screen calibration do not just work once you do it, you have to do it over time for it to work. Ensure you are calibrating properly. These are the proper steps to follow when trying to calibrate the screen:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen, turn on the nuvi.
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears(white screen with touch dot),
  5. Then follow the on screen instructions.
Try this repeatedly till you get it to work. If it does not work, then it means there is an internal problem that need to be checked by a repairman.That should do the job for you.
hope this helps.
Dec 26, 2010 | Garmin Nuvi 660 GPS Receiver
MP3 Touch screen is stuck . Can't configure
if the touch screen feature is not working, and you cant navigate to the calibrate screen, push the off switch but release right away, so it dont turn off, it will bring up the calibrate operation, its a default to access the calibrate when you cant navigate the screens.
Dec 29, 2009 | Sylvania SMPK8854 Digital Media Player
My computer screen is stuck on hp logo nothing including key is responding my computer is stuck on hp invent screen.... it wont go past that, doesnt respond to f8 or esc. HELP
Sounds like a faulty hard drive that is locking up the system. Take out the hard drive completely and turn on the computer and see if it goes past the HP screen. If it does then the hard drive is bad. If it still locks up on you then reseat the memory one stick at a time in one slot at a time. If this doesnt work then you might be having motherboard issues.
Try these things and let me know what happens and I'll help you further.
Ben
May 18, 2009 | HP Pavilion dv2000t Notebook
Touch screen does not work.
(1) Disconnect any external GPS antenna. (2) Do not turn on auto engine. (3) Turn off any other peripheral devices. (4) Simultaneusly hold down the PAGE and MENU buttons while turning on the 2620. A prompt box will appear asking if you really want to delete all user data. Touch the NO selection. Then turn off the 2620. (5) Simultaneously hold down MENU & ROUTE buttons while turning on the 2620. (6) A self-running diagnostic program will appear. Allow it to run for a couple of minutes; check to see that all parameters indicate "PASS" or other indication of being OK. If any parameter is not OK, make a note of it for potential communication to Garmin, then proceed with the following steps (7) Turn off the 2620. (8) Simultaneously hold down the PAGE, MENU & ROUTE buttons while turning on the 2620. A SCREEN CALIBRATION adjustment screen will apear. Quickly touch the points indicated as the calibration program runs. At the end of this procedure, the screen will display a window indicating that the calibration either "PASSED" or "FAILED." If it "PASSED," continue to steps (8)-(9). If it "FAILED," turn off the 2620 and repeat this step. If, after three calibrations attempts, each one is "FAILED," then also turn off the 2620 and proceed to steps (8)-(9). (8) Turn on the 2620. Press the "OK" button each time prompted to do so. Wait for maps to load and for the 2620 to initialize, acquire satellites, and display your position. (9) Press FIND button, then touch the right-hand vertical screen position adjustment to scroll screen display down to reveal WAYPOINT selection box. If unable to select WAYPOINT, or if attempting to do so only selects an adjacent box, then repeat step (7), and return to this step. (10) When various waypoint selections appear, attempt to scroll down to a selection not visible when the list of waypoints first appears, and select one of them. If still unable to select WAYPOINT box, unable to scroll screen down (or if trying to do so selects a stored waypoint instead), once again repeat step (7). If successful,then proceed to step (11). Also proceed to step (11) if you have repeat step (7) but then still can't select WAYPOINT, can't scroll down after selecting WAYPOINT, or can't select a particular stored WAYPOINT. (11) Press the upper-right hand "X" to close out the FIND screen or sub-screen within that function. If unable to close the screen, press the PAGE button. (12) Press FIND button, and when selection screen appears, touch ADDRESS. On next screen, touch the STATE line and touch the ENTER A CITY in (name of state). When keyboard appears on screen, use it to enter your city, then touch OK. Continue this procedure to enter your house number and street name, then press "OK." If all screen keyboard keys not responding, repeat step (7), turn the 2620 off and on again, wait for it to initialize, and then attempt this step again. (13) Repeat this procedure several times if not initially successful. By the second or third run-through, the touch screen should respond fully and accurately. If, after many runs through this procedure, the touch screen still will not respond, the screen sensor probably will need to be replaced ($255). The foregoing procedure brought my touch screen back to life last evening, much to my delight. Do not be too concerned if the SCREEN CALIBRATION step does nto produce a "PASS;" on my third calibration attempt it produced a PASS but all of the touch screen points still had not returned to functionality. I was unable to get a PASS during the screen calibration step after that, but the many repetitions apparently nonetheless made the difference, as by patiently following the above prcoess for five cycles, full screen functionality was restored.
Jun 18, 2007 | Garmin StreetPilot 2620 GPS Receiver
 Grubhead
Grubhead
