Question about Rheem 42VP50FW 50 GallonNatural Gas Water Heater
Rheem power vent error codes, I'm getting a (ECO FAILURE) CODE ?
gary1121
  • 332 Answers
SOURCE: rheem tankless water heater gives error code, flashes 80. Also what do I use to seal the exterior of the vent? Should the vent outside smell like gas?
check to make sure that your flue pipes are together if the have not been put together properly it will not start, it has to pull in cold air while exhaust is forced out,, if it isn't right it will pul exahust thru the cold air intake and shut sown or not start at all,, you might want to call who ever installed it,they are supposed to warraty it for 1 year on labor at a min, to be able to install them thru the company,, rheem,, they are supposed to be quilaifeid and have a card that states they took the class to have the knowledge to do so.
Posted on Jun 01, 2009
gary1121
  • 332 Answers
SOURCE: ECO Failure
make sure your flue is clear,, and no suit is in the burner, also there are wires going to the ignitor make sure they are not touching after time for what ever reason they need to be seperated because they short out but doesn't cause any problem other then the unit not lighting
Posted on Jun 21, 2009
  • 2976 Answers
SOURCE: ECO failure. Replaced the gas control thermostat & vapor sensor
It sounds like your gas/air mixture needs to be adjusted. The flame should have just the slightest amount of white, at the very tip. The rest should be evenly blue. There is an air vent adjustment in the line to the burner, right after the gas input.
Posted on Sep 03, 2009
connertamago
  • 37 Answers
SOURCE: Rheem Eco-180dvn. Error code 12
actually, does it give you a big rumble? if it does, then your problem is that the meter's btu's are not high enough and there's too litle gas getting to the heater so it's blowing itself out, basically. you'll need to call your gas provider and ask for them to bring in a higher btu meter. around 220,000 btu meter is best, so your furnace and gas stove(if you have one) dont take to much gas themselves, meaning dont get a 180,000 btu meter, because it would only be able to supply the heater.
Posted on Oct 18, 2009
SOURCE: Error code 13, replace
Before calling service technician, open following link for troubleshoot resources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
The same error code and problem on one person's tankless unit can have different solution than another tankless unit.
This is because tankless require perfect operation of parts and sensors while being affected by incomming water and gas issues, and venting, plus plumbing factors.
Replacing one part is not always the fix, since that part interrelates with so many other parts, each affected by the operation of the other, and operation of the chip and integrity of wiring and wiring connections.
Read manual for yearly maintenance requirements, and calculate those costs when figuring anticipated $1-8 monthly energy savings from owning tankless.
Check that your region has reasonably-priced, qualified service technician for your brand before buying tankless. And check part list and cost of parts before buying any water heater because these factors weigh-in after a few years of operation.
Repair most tankless problems yourself, same day, any brand, for around $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 12, 2011
What does ECO failure mean on my hot water heater?
I'm guessing about model. I Goggled Eco failure. For reheme this site and discussion may help. http://terrylove.com/forums/index.php?threads/ge-rheem-power-vent-eco-failure-code-gg50s06rvj.43646/
but since it's gas, and an expensive unit I'd call the installer or his service.
Mar 08, 2015 | Water Water Heaters
Rheem tankless water heater error code 11
Error 11 is ignition failure, or insufficient gas, or defective sensor, dirty combustion parts.
Do the yearly required maintenance such as cleaning the combustion parts, and error code will probably be solved.
Problem is Rheem does not post service manuals for people to learn how to service their equipment without calling service tech.
Copy following link for Rheem troubleshoot resources
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
The cost of yearly maintenance will easily eat away the expected yearly savings of $100 for typical family of 4.
Aug 20, 2012 | Rheem RTG-66DVN Direct Vent Natural Gas
I have a poloma model/ pt62-42pvn its flashing error code c4 76 i have had no hot water for six days now need help
1) Before calling service technician who can test parts, open following link for Rheem resources including error codes, Rheem chat and phone number, possible manual:
If local technician cannot solve problem, Rheem can probably recommend a person.
2) Error codes are start-point for troubleshooting.
3) Multiple error codes can indicate PC board failure.
If your computer motherboard fails, most people feel the computer is compromised even after motherboard replacement.
4) Error code C7-76 is communication error with remote, and can include bad remote, bad wire to remote, loose wire, or bad PC board.
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
5) Error C4-13 can include part failure, vent problem, oxygen depletion, and can also include PC board failure.
http://waterheatertimer.org/pdf/Error-code-13.pdf
6) Tankless routine maintenance manual:
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
7) Some posts about tankless concede that qualified technician was unable to repair unit.
Solve most tankless problems yourself, same day, for about $350.
8) Take a moment and rate answer:
Sep 08, 2011 | Rheem Paloma Tankless Water Heaters...
No hot water error codes 76, C4,C7
Before calling service tech, open following links for Rheem troubleshoot resources including rheem chat, error codes, possible maintenance and service manual.
Error codes are considered start-point for troubleshooting.
Multiple error codes can mean PC board failure.
Aug 12, 2011 | Rheem RTG-66DVN Direct Vent Natural Gas
I am getting a C2 11 code on my eco sense tankless water heater. There is also a flashing 24, any ideas? Thanks
C2 11 is no ignition.
Error 24 is malfunction of operational switch: "press max or mim button on PC board, or replace PC board." On some models, max and mim button can be located just above dip switches, and rotates with screwdriver. See diagram in manual.
Before calling service technician, open following links for troubleshoot resources including error codes, Rheem chat, and possible manual.
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Aug 10, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
HOW TO RESET CODE 1L
Open cover.. find buttons min/max press nim then press mas and then hold min and max presses for 5 seconds or so. Power off controller and power back on..You have reset your fault code til next time. Rheem is poor on info and poorer yet on service..Good luck
Aug 04, 2011 | Rheem Tankless Hot Water Heater...
RHEEM 50 GALLON WATER HEATER,4 BLINKS THEN 2 BLINKS ,ECO FAILURE,UNPLUGGED HEATER STARTS UP AGAIN THEN FAILURE OCCURS AGAIN.
That is a power vent failure code.
Rheem is aware of this problem and are changing systems as we speak. Call your Rheem dealer and demand the updated system.
Feb 07, 2011 | Water RHEEM 40 Gallon FVR PROP PWR Heater...
Sep 03, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
ECO Failure
Jun 12, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem 40 gal power vent gas water heater shows code 42
you plugged it in and the fan started or you unplugged it and the fan started,,the fan will come on first before the unit will inginte to take out the excess gas, if it didn't lite then the ignitor might not be working there are 2 swithces on the unit one on the fan and one by the gas valve make sure they are both on and make sure the gas it also turned on.
May 30, 2009 | Water Heaters
Rheem 42VP50FW 50 GallonNatural Gas Water Heater Logo
57 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
