Question about GE Profile JTP18 Electric Single Oven
Oven shuts off after approx 1 hr durring baking
Oven wont bake
If this is the design that the oven will click to light they generally will preheat but shut down once they go to standard bake. The oven will try three times to relight but then shuts down and will not try to light again until you reset the oven. If this is the case the oven burner itself is usually the problem. the burner comes with the electrode.
Nov 27, 2013 | Whirlpool Ovens
I want to use top and bottom ovens but at different temps - how do I do this
To Set a Cook T ime:
1. On double oven models only, press UPPER OVEN or LOWER
OVEN for the one you want to set.
2. Press BAKE or CONVECT UPPER (on some models).
Press the number pads to enter a temperature other than the
one displayed.
3. Press COOK TIME.
4. Press the HR and MIN "up" or "down" arrow pads to enter
the length of time to cook.
5. Press START/ENTER.
The start time and stop time countdown will appear on the
oven display.
On double oven models only, when both upper and lower
ovens are being used at the same time, touch UPPER OVEN
or LOWER OVEN to display the respective cook time.
When the stop time is reached, the oven will shut off
automatically and "End" will appear on the oven display.
If enabled, end-of-cycle tones will sound, then reminder
tones will sound every minute.
Repeat the process by choosing the other option of UPPER or LOWER OVEN
Sep 04, 2011 | Whirlpool RBD305PD Electric Double Oven
Oven will not stay heated. F1 light on.
Hello there:
on most ge models this code it can be either a (f 0) or the (f 1 ) is telling you that the the thermistor controle circuit is going bad or has failed all together. or there is a short in the erc circuit meaning the electronic controle board. ok
So i would recommend have a repairman check out the thermistor first since this is the most common thing to fail then if this passes have them test the controle board or the ecr circuit
and if the oven is still under warranty you might be able to use the warranty to get it fixed ok
Hope this is very helpful for you
Best regards MIchael
May 14, 2010 | GE JTP20 Electric Single Oven
Oven comes on for 5 min then shuts down everything even the keyboard
Same problem here on JKP15WOW1WW. The cycle starts like this:
1) Open circuit Breaker
2) Open oven panel and push ribbon connector to ERC. Replace planel.
3) Close circuit breaker
4) Run to oven, notice clock flashing some time but not 12:00 and start Bake. Bake button beeps and starts bake coil.
5) Within 5 minutes hear a beep and all buttons on panel are unresponsive. Bake continues. if oven light is on it continues to glow. Only button that responds with a beep (and not to clear bake or oven light) is Clear botton.
Rinse..wash..lather...repeat...
Nov 11, 2009 | GE JKP15 Electric Single Oven
F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
May 09, 2009 | GE JRP15 Electric Single Oven
Self cleaning oven instructions
Self cleans generally do a good ****on small messes in 2 -2.5 hours. Larger messes take 3. Leaving the racks in is okay...but they will likely lose their shiny appearance. Manuals are on the GE website.
Jan 05, 2008 | GE JKS05 Electric Single Oven
I need to disable my ovens auto shut off
The control is automatically set to turn off the oven after 12 hours baking or 3 hours broiling should you forget and leave the oven on. If you want to remvoe this feature do the following steps: 1. Press and hold, at the same time, the BAKE and BROIL buttons for 3 seconds, until the display shows "SF". 2. Press the DELAY START TIME button. The display shows "12Shdn" for 12 hour shut off. Press the DELAY START TIME button again. The display will show "no Shdn" for no shut off. 3. Press the START button.
May 21, 2007 | Kenmore 33464 / 33465 / 33469 Gas Single...
GE Profile JTP18 Electric Single Oven Logo
23 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
