Question about Sony BRAVIA KLV-32U100M 32 in. LCD Television
I have Sony BRAVIA KLV-32U100M 32 in without the remote control, and I need to set it up for channel 3 or 4, how can i do that?
futureloginn
  • 734 Answers
SOURCE: Remote Codes for new Sony Bravia
0000 worked for my XBR4 using the remote called: Comcast Custom DVR 3 Device found here:http://www.comcast.com/corporate/customers/customer_support/remotes.html
Posted on Nov 17, 2008
  • 6 Answers
SOURCE: Screen goes blank / black, sound still works
It sounds like your LCD Screen is no longer working. I would try contacting Sony and ask for a refund. I had the same T.V and the LCD Screen had gone out. A techniction came out and Condemned the screen and i had to pay $500 for a new T.V.
Posted on Apr 14, 2009
  • 630 Answers
SOURCE: my sony bravia has no audio when used as cable tv
Check the connections between the cable box and the TV. If you are using scart check the connector is in squarely if using rgb or composite you need a separate audio connection using the red and white phon sockets.
Posted on Nov 08, 2009
SOURCE: Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
Posted on May 30, 2010
SOURCE: Need to program my synergy v time warner remote to
STEP 1: PRESS THE MODE BUTTON ON THE TOP OF THE REMOTE, THEN PRESS TV STEP 2: PRESS AND HOLD THE "SEL" BUTTON AND THESH "MUTE" BUTTON AT THE SAME TIME UNTIL THE BUTTONS ON THE TOP ARE LIGHTING UP IN SEQUENCE FROM RIGHT TO LEFT STEP 3: HOLD THE CHANNEL UP BUTTON UNTIL YOUR TV TURNS OFF. WHEN THE TV TURNS OFF HOLD THE CHANNEL DOWN BUTTON UNTIL YOUR TV IS BACK ON AND ALL LIGHTS ON TOP FLASH AT THE SAME TIME
Posted on Sep 24, 2010
32s530a software is not working will you please send me software file??
you must get this from Sony: http://esupport.sony.com/US/p/model-home.pl?mdl=KLV32U100M&LOC=3&session_id=221047ee10c5a4a88875f2358d43b222#/howtoTab
Nov 26, 2013 | Sony BRAVIA KLV-32U100M 32 in. LCD...
My sony 32 tv screen cuts people's heads off. what can i do to correct it?
Look in ur remote control for a button like Zoom, Aspect,VIEWMODES,P.Sizes.Tries one of these buttons to tuggles the pictures sizes on the tv screen.
Dec 11, 2010 | Sony BRAVIA KLV-32U100M 32 in. LCD...
My sony klv-32u100m won't power up, is there something i should check?
Verify that the power cord works with something else (like a computer monitor) while it is plugged into the same outlet. I've seen power cords pull loose when a cat stepped on them, or break inside under stress, particularly when people pull them by the cable instead of the plug.
If that is good, you may have a failed power supply. Do you want to get inside the set for a visual inspection? If so, post back for directions on what to look for, and when you do, please indicate whether you know the difference between a transformer and an electrolytic capacitor.
Oct 16, 2010 | Sony BRAVIA KLV-32U100M 32 in. LCD...
I have a KLV-32U100M and recently I've noticed a wide bar of color rolling up the screen and a I hear a slight hum from the speakers. This occurs when different devices (cable box, dvd player, Wii) are on...
You may have an earth ground problem with your house electrical wiring-- third prong in AC socket. Get a 3-prong to 2-prong plug adapter ( also called an "AC-cheater plug") and put on TV cord. Try again.
May 01, 2010 | Sony BRAVIA KLV-32U100M 32 in. LCD...
NO POWER?
Ur power IC invertder board it dead.
Need a new one.
Tries the Sony Website buy the power board.
MIght work or some things else might also burned.
Aug 17, 2009 | Sony BRAVIA KLV-32U100M 32 in. LCD...
Sony 32 lcd
This LCD could have a defective back light inverter board.
If your TV is less then a year old, still under manufacturers warranty. If not, I would suggest to contact sony and ask them for parts availability.
Let me know if you need further assistance.
Oct 27, 2008 | Sony BRAVIA KLV-32U100M 32 in. LCD...
TV remote infrared sensor
A company known as Niles Audio makes remote Infra-red sensors ... Is this what you are looking for?
www.nilesaudio.com
Jul 20, 2008 | Sony BRAVIA KLV-32U100M 32 in. LCD...
Sony tv model klv-32u100m dead standby 5 volts ok
most probably is (a) board ..very common on these models.These boards are made by RoHM.These are similar and used in maganvox,philips and others..Very common breakdown
Nov 30, 2007 | Sony BRAVIA KLV-32U100M 32 in. LCD...
Getting my Sony TV to operate in 1080i.
Asumming you have set the Xbox at 1080i in the video settings and you have used all the four component lead ends, (apart from the yellow video end, as you won't need this) it should work.
Jan 11, 2007 | Sony BRAVIA KLV-32U100M 32 in. LCD...
Sony BRAVIA KLV-32U100M 32 in. LCD Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
