Question about Honeywell Programmable Thermostat Heater
Aube 350000071b can not control the heat
  • 400 Answers
Not enough information to really help. I suggest you check out the furnace. Shorting across the switch line into the furnace should make it start. If it does not, the furnace is at fault; if it does start, the thermostat or wiring is at fault. If you have central air, it gets more complex. Did you change the batteries first? I hope this helps.
Posted on Oct 22, 2013
How do I switch from Celsius to Faranheit on thermostat for heated bathroom floor?
There are 3 dip switches on the subbase. the first one controls C or F. Down is C, Up is F.
Feb 22, 2015 | Honeywell Aube TH115-AF-GA 7-Day...
240 volt thermostata
Aube Technologies should be able to supply wiring information.
Jan 28, 2014 | Aube Technologies TH115-A-240S - Aube...
I have under floor heating cannot set thermostat timer
Model number usually located on back of thermostat
Change battery.
Search for model number on web and include .pdf in search parameter.
For example aube thermostat manuals appear following link:
http://www.aubetech.com/manuals/index.php?noLangue=2&noFamille=1
Oct 28, 2012 | Honeywell Aube by TI0323WU 7Day...
I have the aube TH132 underfloor heating system installed. I have programmed the temperature set points to 18c but its over heating to 43c!! I've re programmed it but with no luck!! The icon for when...
This product has 2-year warranty against defects in workmanship.
Aube technologies Inc.
Warranty does not apply to poorly installed ...
Canada 450-358-4600
Manual does not have troubleshoot section.
section 4 includes temperature setpoints by model number.
On-line manual can be word-searched for fine details that might be missed by a visual read.
http://waterheatertimer.org/pdf/TH132-A-F-AF-230-thermostat.pdf
Check that air vents are open to control, so the unit can read correct temperature.
Change temperature Display selector for F or C.
Make sure wires are connected to correct terminals to match your voltage.
15 amp max rating indicates #12 gauge wire for 120Volts. Recommend that thermostat control a contactor instead of direct-wire to heat coils.
Example contactors
http://waterheatertimer.org/H230A.html
Oct 09, 2012 | Hardware & Accessories
My timer is set to shut off at a certain time of day, and I want to turn the timer off, but I can't figure out how to do it. Can you send instructions on how to turn the timer off?
Honeywell product is not identified.
More information is needed to identify product. Add a comment with as much information as possible, to help expert locate correct information.
For example Honeywell makes timer controls for boiler and heat-ac units.
Honeywell also makes Aube brand wall and box timers for lights and pumps.
http://waterheatertimer.org/Aube-timers.html
Honeywell has a contact-us page:
https://honeywell.com/Pages/contact-us.aspx
Aug 30, 2011 | Honeywell 24-hour Timer Control 120v Spdt...
Have an aube digital timer (7-day, model TI032) running outside lights. Just installed yesterday, when it comes on (either manually or on auto) I can hear a loud, audible clicking at a pretty fast rate...
Please review the technical manual for your Aube timer and check your wiring. I'm sure it is a oversight in the wiring.
I hope this helps you solve your problem...Please leave a comment...Thanks! Jim
http://www.aubetech.com/manuel/2/TI032.pdf
Feb 13, 2011 | Aube Technologies Aube 7-Day 40-500w Light...
Lost power and need to reset the timer.
Aube timers have back up battery that recharges after power resumes.
Battery should hold programming during outage.
If battery does not charge, then screen doesn't light up and programming not possible.
Aube makes several timers.
Aube timers and manuals posted at following link.
If you have different timer, add a comment
Nov 15, 2010 | Aube Technologies Aube 7-Day Programmable...
Will your timer work inside a cold garage though the winter?
Fixya doesn't make timers.
Honeywell makes the Aube Timer
Aube timers are a new product with a rechargeable battery.
Batteries are susceptible to cold temperatures just as you suspect
http://www.aubetech.com/products/produitsDetails.php?noProduit=75&noLangue=2
Aube/Honeywell has a 'contact us' page
http://www.aubetech.com/contactUs/index.php
I sent an e-mail to Aube tech support about your question.
As soon as they answer, I will post their answer on this thread.
I also posted a page on Aube timers with links and manuals:
Nov 10, 2010 | Aube Technologies Aube 7-Day 40-500w Light...
I do not understand the manual that came with my TH132 control unit. Can some one guide me so that I can set the heating for different times for Mon-Fri and different times for the weekend?
Aube technologies has a page with thermostat manuals
http://www.aubetech.com/products/list.php?noLangue=2&noFamille=1&app=1
Thermostat page shows 3 models for your TH132 (toward bottom of page)
Click the model number and it opens a second page
The manuals for each product are conveniently located on that second page, toward the bottom, along with a description of your product.
In my opinion, Aube (Honeywell I think) website is way ahead of the curve for customer convenience
Most other electric device websites have manuals located on a different page than the product
A lot of sites, like Leviton, have no manuals at all. Lose the manual, and you have to call their customer service like in the 1980's
Aube must want your repeat business.
Oct 17, 2010 | Aube Technologies Hardware & Accessories
Need Aube by Honeywell TI032-3W-5/U instructions
http://waterheatertimer.org/pdf/Aube-TI032.pdf
Manual for Aube T1032
Internal rechargeable battery
7 day programmable timer for halogen, incandescent, florescent
Aube T1032 has 40 Watt mim & 500 Watt maximum (5- 100 watt incandescent bulbs etc)
Buy Aube-1033 for heavy 20Amp 2400 Watt maximum
Replaces single-pole switch or 3-way switch (slight modification needed in 2nd 3-way switch)
Buttons
Oct 12, 2010 | Honeywell Aube by TI0323W5U 7Day...
Heating & Cooling Logo
122 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
