Question about Brother 1034D Serger Sewing Machine
Upper looper hits lower looper
I tried to serge a thick fabric and at one point, the fabric got stuck. Now when I try to serge, the upper looper hits, overlaps the lower looper and I can't serge. How can I fix this?
  • 130 Answers
The upper/lower looper need realignment, requires a qualified technician to do this.
Posted on Nov 01, 2013
  • 13 Answers
SOURCE: Upper and lower parts hitting
It sounds like the timing of the loopers is out they will need to be reset correctly within millimeters. If not done properly they can hit and bend or break easily and most are not cheap parts. Best it goes to a repair centre as it will work out more cost effective than the damaged caused by getting it wrong.
Posted on Jun 23, 2008
SOURCE: My 1034D serger has a broken part that holds the lower looper.
call brothers hot line 1-901-373-6256 tell them your problem and part no, if you know it if not they should be able to help you
Posted on Mar 13, 2008
  • 323 Answers
SOURCE: brother serger thread
The lower looper thread MUST be threaded before the needles are threaded. You must also be sure the lower looper thread is pushed and staying all the way to the left before it is threaded through the looper eye. Double check the threading diagram and count the number of guides the thread passes through. Count how many guides you have actually passed it through. It must be the same. The dealer you bought it from should be willing to show you if you can't figure it out.
sewman7
Posted on Jun 18, 2008
rochelle0099
  • 5 Answers
SOURCE: tension problem on Brother ES 2000
I have a Brother CE 4000 Computer sewing machine. I had the same problem when I first used it. I worked with it several hours but to no avail so I decided to stop and wait until my head clear..
I went back a couple of days later. Reread the manual and started over. I discovered my problem was that I was threading the bobbin wrong. Once I threaded it precisely as the manual stated it worked fine.
So this might be your problem. Make sure that the thread on the bobbin is wind on properly. It should be wound evenly. The bobbin must be threaded precisely as the manual says.
Try rethreading the bobbin and the machine
and see if that help.
Posted on Jul 30, 2009
  • 1116 Answers
SOURCE: I get loops on top and/or bottom of fabric during
Top tension back to 4 and leave the bobbin tension as is.
Make sure you have a new needle for the type of fabric being sewn installed with the flat side to the back of the machine. A bent needle can sometimes go unnoticed.
Always thread the machine with the presser foot up and this will give proper tension to the stitch.
Check the manual to be sure you are threading correctly (always with the presser foot up) and that the bobbin thread is feeding in the correct direction from the bobbin spool and through the guides.
Take hold of the thread at the needle as you lower and raise the needle to pull up the bobbin thread. Take both thread ends under the presser foot and to the back of the machine.
Posted on Mar 11, 2010
Pushing material away, but still overlocking
It is difficult to tell what exactly is happening with your serger.
First thing--make sure you RAISE the presser foot BEFORE you thread any of the threads. This releases the tension disks so the threads will seat properly. You may need to remove all the threads and rethread from the beginning, making sure you thread each in the proper order. Start out with the thread tensions set at the ideal setting--usually the halfway point between the high & low numbers. From there, you will adjust them to even up the thread tensions.
Are you actually trimming off some of the fabric as it is stitching? If so, you might try increasing the cutting width (moves the cutting edge further toward the right) so that there is more fabric caught within the looper threads. It also appears that the looper tensions may be too loose. Try tightening the upper and lower looper tensions so less of the thread loops don't fall off the fabric's raw edge.
Make It Handmade Understanding Your Serger Features
Serger Stitches 101 Cheat Sheet Never Ever Without It Your New Must Have...
Meet Serge Beginners Guide To Using an Overlocker Serger
Using Serger Learn to Use Your Serger to the Max
Bernina 700D Serger 8 Cutting Width Knife Adjustments
Dec 30, 2015 | Sewing Machines
WHy is my Husqvarna Viking 560 serger is skipping stitches????
Here are a few things to try.
1. Make sure that correct type of needles are being used, both are the same size, and that the needle size matches the fabric weight. This is the first serger to use 15X1 needles.
2. Make sure that the needles are installed correctly and are pushed all the way up. Have you replaced the old needles with new ones, not other used ones?
3. Thread has a shelf life, it can expire over-night. Just to eliminate this possibility, replace all threads with fresh good quality serging thread (and not just another spool which was purchased some time ago).
4 It sounds like you have re-threaded the serger correctly according to manual instructions. Here is a sure fire method:
- thread the upper looper and place the thread behind the needles under the presser foot. Make sure that the thread is lying firmly between the tension discs.
- thread the lower looper (the tricky one). Check that the thread is between the tension discs as before and place the thread over the upper looper and then behind the needles, and under the presser foot.
- thread the needles, checking that the thread is between the corresponding tension discs. Place the thread under the presser foot.
5. Check stitch length.
6. Check if the problem persists with other fabric types, use two layers. If the problem occurs with only a particular fabric, then the cause is incorrect needles.
7. Check tips on both upper and lower loopers. They should be free of burs, smooth, and have a semi-sharp point.
Hopefully this will solve your problem, if not it may be time to have it inspected by a qualified technician.
Please rate how effective were these suggestion in solving your problem, it is important to me.
May 13, 2014 | Brother XL-2610
Upper looper stuck?
Had the same prob once. I needed to find the screw that ataches the looper to the machine and readjust it. If you are not machine savey then you may need a professional. I needed the hubby to help me.
Feb 18, 2013 | Brother 1034D Mechanical Sewing Machine
Janome Juno 3434d wont make a chain
If it was hitting before you stopped, it's likely that the looper either got bent or was knocked out of time. I would take it in for repair.
Dec 23, 2012 | Sewing Machines
I need a replacement manual for Babylock Xscape BL66
You will need to contact a BL dealer to order a manual, if any are available. This model has been replaced.
There is a threading guide in on the inside of the door on the front of the serger.
Raise the presser foot and set the tension controls to zero.
Turn the handwheel until the upper looper (curved looper) is at it's highest point - there may be a mark on the side of the serger and handwheel for aligning to this point.
Thread the upper looper first, then the lower looper, then the needles.
Pull the threads under the presser foot and to the left side of the serger.
Set the tensions back to 4 - 6 setting, lower the presser foot and stitch a chain before serging fabric.
You may be able to find a free manual download at the Brother website for a similar product.
Feb 20, 2010 | Baby Lock Sewing Machines
Adjusting lower/upper looper tension
Clean in between you tension plates of your tension units and rethread making sure your cotton runs between the tesion discs.
Jan 19, 2010 | Janome MyLock 634D Mechanical Sewing...
Just replaced my uppper looper on my white 1634....
Hi.
The upper looper goes just in front of the needles. I had issues with my machine when I got some fabric jammed and the looper moved so it wasn't catching the left needle and it was sewing a straight stitch on the left. The looper needs to be placed in front of the needles and very close to the needles without hitting them.
Hope this helps!
Cherie
Nov 01, 2008 | Singer White Speedylock 1634
2000ats - not serging
Make sure the tension disks are clean and not binding.. You can use a piece of yarn dampened with alcohol and floss the disks.
Threading order is:
1) Upper Looper first
2) Lower Looper
3) Right Needle -- exception: if you are doing 3 thread using left needle only
4) Left Needle
Sep 17, 2008 | White Sewing Superlock 2000 ATS Mechanical...
Brother 1034D Serger Sewing Machine Logo
538 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
