Question about GE Spacemaker JVM1540 Microwave Oven
How to vent exhaust outside - GE Spacemaker JVM1540 Microwave Oven
  • 2,113 Answers
how to vent exhaust outside - bea12bfe-3a65-4764-8544-5bc63391c2dc.jpg6bfcce66-f35e-4950-b5c4-5ba9eff2c34c.jpgI usually choose an outside wall if possible to vent outside. You can buy a rear vent that is superior to a dryer vent. When this isn't possible you need a rectangular duct going up through your cabinet and up through your ceiling. hopefully you have an attic or you have to switch to a 5 inch tube going sideways (above your cabinets (if there is space) to the outside wall. If it goes into an attic you have to cut through the shingles to a vent made for bathroom and or hood vents. The motor and blower assembly inside your microwave is designed to turn to be front facing, rear facing or vertical facing. Just unscrew or break out the side that you need to vent through.
Posted on Oct 22, 2013
Need to know if I can convert it to outside vent
This unit has a three way exhaust capability on it. There is a plate on the back that you remove to set the blower housing to back, top or frontal exhaust. You take the plate off and then just lift the blower assy. up and then reset it back into position for the direction that you want. It may be missing the vent louver for outside exhaust if it wasn't left with the unit when it was installed.
Sep 17, 2013 | Sharp R-1850A Convection/Microwave Oven
Exhaust fan direction
You can usually recongure the outlet on the vent to just vent into the room,but if you aren't going to use it,not an issue.
Dec 18, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
We have a Kenmore builin icrowave with exhaust hood over the range. The exhaust fan appears to recirculate the air into the kitchen and not sending it out. This causes the cooking smell to remain inside...
some fans have a charcoal filter that needs replacing others are supposed to be vented out side by the roof or out the wall to see if the vent is going outside you will have to unmount the unit tak it down and check and see if it is conected to a duct in the celing or through the wall hope this helps
Mar 09, 2011 | Kenmore Microwave Ovens
The microwave doesn't seem to be bringing the air up into the vent for exhaustion outside. It's brand new.
I presume that you can hear the fan running? If so, most over the cook top microwaves have an option to vent to the outside or simply recycle through the filter and vents above the unit. If you check your manual there should be instructions on how to change this configuration to suit your situation, but it likely needs to be done before you install the microwave.
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316137234.pdf
The above manual shows how to reconfigure the microwave from recirculation (as shipped) to external exhaust setup on pages 4 - 5.
Oct 10, 2010 | Frigidaire PLMV169DC Microwave Oven
Can this unit indoor vent be changed to vent outside?
Yes. There is an installation manual available for this model listed at managemylife.com. Just type in the model number under the "Manuals" link and the installation manual is available in .pdf (Adobe) format that you can download or print for FREE. Ductwork installation instructions for outside rear exhaust and outside top exhaust are listed. I hope this helps you.
Mar 01, 2010 | GE JVM1650 1000 Watts Microwave Oven
Can i install an external blower outside to boost
Possibly so.
I'd first check to be sure the grease filter is clean, the duct work is not clogged, and the outside vent is not home to an animal's nest.
You can download GE owner's manuals and installation instructions here.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Jan 10, 2010 | GE JVM1190 Microwave Oven
I had the exhaust switched from inside to outside venting, but there is no air intake. What do I need to check?
Check to see if the damper is stuck, either on the exterior vent outside the house or at the microwave. Also, did the blower get turned to point at the desired exaust direction. Unfortunately, both interior possibilities will require removing the microwave.
Dec 27, 2009 | Microwave Ovens
Oven is installed not outside vented. There is
It could be that the filter elements are clogged and need to be cleaned. Remove then from the underside of the micro hood and clean them using a good quality cleaner, such as Simple Green. Clean and allow to air dry before reinstalling.
While the filter elements are out, you can check for obstructions and run the fan to see if it is better without the filters installed.
If there is no noticeable increase in the air flow, it is possible that the exhaust vent baffle was not installed correctly, when the mircrowave was first installed.
Hope you found this Very Helpful and best regards!
Aug 18, 2009 | GE Advantium 120 Convection/Microwave Oven
Outside venting GE Profile Spacemaker XL1800
Your vent flap could be taped or it could be faulty installation not allowing the vent to open. If you take the front vent cover off, you should be able to reach in above the fan unit and gently push the vent flap up, it should move freely with no binding. If it doesn't it is taped or blocked. If it is taped, gently putting upward pressure on the flap might release the tape. If that doesn't work the vent installation is blocking the flap. You might have to remove the unit from the wall (two people to do this) or disassemble the vent duct above the microwave and rework the interface for clearance.
hope this helps,
Sep 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Exhaust fan
The fan pulls from the range top and either out those vents on top unless there is a vent in your upper cupboard. Then it is vented outside. Hope this helps.
Jan 07, 2008 | Maytag MMV1153A Microwave Oven
GE Spacemaker JVM1540 Microwave Oven Logo
146 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
