Question about RCA 3-Device Universal Remote
Require universal remote bereson tv - RCA 3-Device Universal Remote
I have a RCA 3 device universal remote model RCR314WZ and cannot get it to work with my Bereson TV
Your RCA remote may not have a code for your Bereson TV. All universal remotes do not contain all possible codes.
Apr 28, 2017 | RCA Televison & Video
I have a sony bravia tv and and rca universal remote need the code numbers
TV/VCR Combo.
For power on, these products require programming TV
codes on the remote control. For Sony, use TV code 0000
and VCR code 0032
Sep 29, 2013 | RCA 3-dev Universal Remote Remote Control
I have an RCA tv model # f27159wn, we had a universal remote to turn it on because the power button is missing. Our son lost the remote, when we found the remote it doesnt turn the tv on now. How do I...
RCA tv codes from the original RCA 3-in-1 universal remote.000,181,100,233,203,212,098,005,003 004,006.One of these codes program for the RCA universal remote will work.Sorry but to find the tv wright codes for the tv to work.The tv must be power on and working to find the tv wright codes to program in to turn the tv off to get the tv wright codes.Try website like Rmotes.com to buy the tv original remote,will not require tv on to used the tv original remote.
May 03, 2011 | RCA 4-in-1 Universal Remote Control
I have no remote for my sylvania tv, so i cant change tv/video! help!
Try purchasing a "universal" remote control and programming it for your TV. Tip: If you are able to get a universal with the Sylvania name, odds increase a bit of being able to control all functions.
You do NOT want a learning only type of remote. Those require the original remote to learn from.
Aug 25, 2010 | Televison & Video
How do i get codes to program a universal remote to this tv
This will require you have the newer remote to program this TV. The conventional ones purchased at discount stores rarely have these. Contact the Philips company about puchasing a universal remote. Emerson is under contract with Philips now!
Jan 10, 2010 | Emerson SLC195EM8 LCD TV
NEED SONY CODES FOR PHILLIPS REMOTE
Universal Remote Control Simple Setup
* Point it at a TV set and press the Mute/Power button. (Mute button if TV is already on, or Power button if the TV hasnt already been turned on)
* Keep pointing it at the TV until the TV turns on or muted, most TVs respond in about 5 seconds, the most is up to 20 seconds. (Other universal television remote you find in stores take minutes to program and enter long confusing codes)
* Once the TV is muted or turns on, simply let go of button and you have total control. You can use the remote as if you had the original remote, and responds instantly. ENJOY YOUR FREEDOM of choices with our remote!
Most remote controls require minutes of programming a universal remote code into each television while you read the confusing instruction manual.
Jan 02, 2010 | Philips Magnavox Learning Universal Remote
Memorex television, and an rca universal remote, need code
If you are talking about a rca universal remote control, for a memorex tv here are your options 1004, 1006, 1013, 1019, 1047, 1054, 1163, 1167, 1205, 1207, 1213, 1230
Jan 10, 2009 | RCA Universal Remote Control
Can't use tv without remote
There are many TV's that require a remote to operate them.
Are you saying your remote is lost or broken?
If that's the case, and you don't wan't to purchase an original replacement, you could try a universal remote.
Many 'universal' remotes come pre-programmed or can be programmed by entering codes for the make of TV.
Hope this helps.
Jan 28, 2008 | Televison & Video
RCA 3-Device Universal Remote Logo
82 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
