Question about Magic Chef CYE4000AWW Electric Dryer
I have a Kenmore HE2 gas dryer model # 110.97561601. Moved the washer and dry to a different spot. started fine after we moved it. Went to use the dryer 2 days later and it wouldn't start. It will turn on and let you select the the cycle,when I push start it only beeps 3 times. Diagnostic shows code 88 the 09 no F-codes.Does anyone have a solution to my problem? I'm really not wanting to pay a $75.00 service call.
Master_Tech
  • 770 Answers
SOURCE: Kenmore dryer stopped working, start button does nothing
need the model # from the unit should be where the door closes to the CYE4000AWW is not a Kenmore Model
Posted on Jan 21, 2008
mikedurland
  • 481 Answers
SOURCE: Kenmore (Whirlpool) Dryer Model 110.64632300
make sure you are getting a full 220v at the outlet. these symptoms are sometimes caused by one side of a dual circuit breaker in the house tripping leaving you with a partially functioning machine that seems to have power. d8d2a06.jpg
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Aug 08, 2008
ngfam1
  • 639 Answers
SOURCE: Dryer doesn't dry very well.
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Why are you talking about it rather than acting on it?
You need service to fix it or perhaps if its old trash it and buy new!NOT MAGIC CHEF!
If you buy for price only you will change APPLIANCES EVERY 5 YEARS!!
For this problem you will need to use factory service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
SOURCE: Magic Chef Gas Dryer # YG225LV
VT,
The dryer is clogged disconnect the exhaust hose(usually a 3-4 inch thin spring like tube) from the back of the dryer and clean out the entire thing disconnect it from the window (I imagine this is what you have it connected through?) and make sure all lint is removed and then reattach. Also make sure you don't have to much slack going from the machine to the window. Cut any access hose off. It should go the shortest possible path no big loops or sags! After this it should heat up like you just pulled it out of the box.
BMG
Posted on Nov 02, 2008
  • 72 Answers
SOURCE: My Magic Chef dryer doesn't dry properly
remove the vent from the back of the machine, run it full of clothes from the washing machine and if it dries nicely, then you have a clogged vent that needs replacing.
Posted on Jun 16, 2009
My LG DLG2526W gas dryer wont start
I had a problem like this and our fix was to reach in and turn the drum a half a turn and push the start button. it worked for us because the motor had a dead spot on motor and once moved pass that spot, it did its job. you may have a different problem but, try it.
Sep 03, 2014 | LG DLG2526W Gas Dryer
My Kenmore 6.7 cu ft he2 Super capacity electric dryer is taking twice as long to dry. no error codes
It sounds like a connection problem with one of the heating elements, or perhaps only a clogged input or output hose from the dryer. Either of these could cause the problem...also, a burned out electric element.
Jan 15, 2013 | Kenmore Dryers
Clothes with pin holes are seen afetr washing/drying with He2 plus/He Washer dryer combination
Are you over loading the dryer? I know those combo machines can't dry a lot at once
Apr 28, 2012 | Kenmore HE2 Plus Front Load Washer
Dryer does not heat up when drying. Tumbler works but no heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101././
May 03, 2011 | Kenmore HE2 Plus Front Load Washer
Washer on stackable unit won't start after it initially started..
Check the out of ballance switch. It' located between the tub and the cabenit. It sounds like it might have gotten broken when you moved it. You can bypass it by connecting the two wires together until you can replace it.
Please rate solution if helpful
Aug 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Series 70 Gas Dryer not getting hot enough
The first thought I have is about the gas supply. If you had natural gas at the old house and now have propane or visa versa you need to change the orifices in the dryer as gas flow is different. Also, if the gas line some how got a kink in it when the dryer was being installed that too would restrict the flow of gas.
Jul 06, 2009 | Dryers
Dryer won't start
Just a general troubleshooting guide for your washer! hope this helps!! PS don't forget to give me a rating if this helped!! Thank you!!
http://fixitnow.com/2005/09/washing-machine-diagnostic-and-repair.htm
May 06, 2009 | Kenmore 62602 Electric Dryer
Clothes smell like gas
STOP USING THE DRYER AND CALL A QUALIFIED SERVICE PERSON TO TEST ALL GAS LINE CONNECTIONS WITHIN THE UNIT!
A gas leak can cause a fire in your home. Although, we have always used a gas dryer, and the clothes do have a fresher smell to them than an electric dryer. Any gas which may be in the area would be consumed when the gas flame was burning as normally the pilot remains lit throughout the drying cycle.
Jan 24, 2009 | Kenmore 43142 Front Load Washer
I have a Kenmore Elite HE3 gas dryer. The dryer worked great. And then we moved to a new house. We had to have a gas line installed for the washer and dryer. Ever since we've been in the new house the...
The first thing to do is check the venting from the back of the dryer to the outside of the house including the venthood make sure it is clear. Blocked airflow can increase dry time decrease efficiency.
Dec 30, 2008 | Dryers
Magic Chef CYE4000AWW Electric Dryer Logo
24 people viewed this question
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Roderick Scott
Roderick Scott
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
