Question about Brother All-In-One Laser Printer DCP7065DN
Clean head dx4400 alcohol
Dirty print. How can I clean it
    Problem Solver:
  • 7 Answers
Wipe the optics scan glass with a soft cloth or replaced the drum unit.
Posted on Oct 22, 2013
4 Suggested Answers
Mix-it-up
  • 832 Answers
SOURCE: brother dcp 115c : print head clogged (Red & Black not printing).
read the whole (!!!) post here:
http://www.fixya.com/support/t224245-missing_dot_in_all_colors
Its the same issue.
Posted on Oct 18, 2007
mitpatterson
  • 74 Answers
SOURCE: Brother MFC-5440 Print Head
To remove it you pretty much have to take apart the printer, tip up the lid and try and get the scanner cover verticle and then slide to the left it should detach and then undo all the screws you see on the top were the pinter head is, and i would recommend Alcohol Swabs (IsoPropyl Alcohol), Then just reverse the dissassimbay directions
Thanks Mitch
P.S. Don't forget to rate me
P.S.S. If you follow my directions you do so at your own risk, I am not liable for any damages that occur
Posted on Aug 22, 2008
komguy
  • 2306 Answers
SOURCE: How to remove the print head?
When you lift the lid like you're changing inks, you will see on each side long plastic covers that pop out, all the wires and the ground wire have to be removed and then you can set the whole top aside, after that there's several phillips screws that come out and you lift the middle cover off. The printhead is exposed at this time and the tubes come off, and the drive belt. The head will lift off the left side of the rails. Good Luck!
Posted on Dec 31, 2009
Testimonial: "I will try it....Thanks ART"
Envelopes print red only. All cartridges have enough ink.
Possible dirty / clogged / dried up print-head. Try cleaning routine of printer - or remove and wipe heads with lint-free rag dipped in rubbing alcohol. Align and clean if needed again in printer and try again.
May 12, 2015 | Lexmark Pro901 All-In-One Inkjet Printer
Epson xp-100 won't print without the shadow, how do I get a clear print?
Try aligning the print head using it's software. Most probably the head is dirty. Remove it and wash it clean with some alcohol.
Aug 30, 2014 | Office Equipment & Supplies
I have PIXMA iP90 printer but having problem of not printing blank test,I mean if i change the text colour to blue or any different colout it prints but not with black ink
This seems to be a comon problem with canon printers the black head is either dirty or needs to be replaced. canon should look into this
to clean heads use rubbing alcohol, cotton swab
put some rubbing alcohol on the cotton swab and gently rub the black portion of the head until it is clean
Mar 06, 2011 | Canon PIXMA iP90 Mobile Printer
Are the ink cartridges just a few copies, I have new copier and print is very faint
You need to clean the print head and insert the cartridge and check, whether it is working at fine because a dirty printer header will not allow the right formulation of the basic cyan, magenta, and yellow to print and comes up with the yellow color and not red.
If you still face the problem after cleaning print head then you need to check for a clogged nozzle. Clean the nozzle and then try printing it will work fine now.
To clean the print head from the Utility section found in the printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. Furthermore, you can clean the print head by Using a cotton Q-Tip & Isopropyl Alcohol and gently rub the print head with alcohol.
Hope this helps.
If you still have any queries, please feel free to ask us.
Shane
Mar 03, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Black ink does not print. How do you disassemble
Possibly you printer has two ink tanks ? a small black one and a large one ? If one is empty it will not print black. The better solution is to use a q-tip and some alcohol to clean the head. If the cartridges have been replaced - possibly the new one is defective? U might also try using the head clean option in the printer properties. Additionally sometimes the contacts for the cartridge are dirty or if they have been touched with fingers they will not work, alcohol again is recommended to clean those.
Oct 19, 2009 | HP Photosmart 3310 Printer
Prints have lines throughout
Sounds like the printer head is dirty and needs to be cleaned. If after removing the ink cartridge and cleaning the print head with DENATURED ALCOHOL NOT RUBBING ALCOHOL, does not produce clean prints with out the lines, you might need to replace the actual print head mechanism. The print heads do not last forever and need to be replace every so often.
Cheers,
Keith
Sep 19, 2009 | Canon MultiPASS MP700 All-In-One InkJet...
Why has the print quality gone down on my i860 printer
The head may be dirty or misaligned.
Run through the tools on the printer to clean the printer head and realign the print head.
If this does not work, then you will have to remove the print head and clean it (with rubbing alcohol) until residue is removed. Or you can soak it over night with a 25% rubbing alcohol and 75% water mixture.
Dont take your printer apart unless you know how.
Aug 04, 2009 | Canon Office Equipment & Supplies
CAN NOT PRINT COLOR -PRINTS PINK STRIPES
Take some paper towels, fold them in half, spray them with alcohol FREE glass cleaner and set your color cartrige on the paper towels and let them soak for thirty minutes or so. DO NOT USE ALCOHOL it sets the ink. also clean the thin plastic strip in the back of the print heads this is the encoder strip and it tells the print heads when to dispense if this is dirty from overspray it will affect your print quality. Use q tips and the same alcohol free window cleaner.
Jun 04, 2009 | HP Officejet 9110 All-In-One InkJet...
I have an epson dx4400 printer, when printing there are lines across the text and complete lines missing. I have tried running all of the diagnostic and repair tools that came with the printer e.g head...
Regrettably EPSON print heads/inks are notorious for clogging unless you print every day.
You may have to buy a print head cleaning solution and try that.
Jan 20, 2009 | Office Equipment & Supplies
Canon BJC 80 Printer
Try cleaning off the contacts on the ink carriage with a cotton swab dipped in rubbing alcohol. The part that connects to the copper contacts on the printhead. You can't harm them by cleaning this way. And the alcohol evaporates pretty quick. Canon ink is 65% alcohol and this dissolves and cleans off ink residue on any part of the printer. Sometimes these contacts get dirty over time and won't read print heads installed any more. This fixes about half the printers like this I have problems with.
If cleaning doesn't help, and a new print head won't work, then the only fix is to replace the ink tank carriage assembly.
Dec 20, 2007 | Canon BJC 80 InkJet Printer
Brother All-In-One Laser Printer DCP7065DN Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
