Question about Cybex International CYBEX LCX425T Treadmill
Buttons not working
Both of the incline buttons, as well as the STOP button and the "increase" speed button have stopped working and I am not sure why.
  • Mark
    Mark Nov 03, 2013
    Hi, i have the same problem.. did you find a solution?
    Top Expert:
  • Cybex Intern... Master
  • 12,223 Answers
Replace the old batteries( if your system have it, clean the contacts batteries, and tight the spring with plyer)
2) tight the ribbon cable, and clean inside the display board)
3) tight the upper connector and lower connector
4) adjust the REED switch, tight the connector and clean it. see the diagram attached.
Posted on Oct 22, 2013
My manual does not tell me how to turn off demo mode on my console and I need to turn it off Model #NordicTrack x22i treadmill incline
  • roperly connected to the NordicTrack and plugged fully into a grounded electrical outlet if the machine does not turn on. If the unit is plugged in correctly, look at the reset switch, located on the frame near the power cord. If the switch is flipped open, wait five minutes then push the switch back in.
  • Remove the key from the console, wait a minute and reinsert the key back into the console if the buttons on the console are not functioning properly. If the console stays on when the key is taken out of the console, the device is likely still in "Demo" mode. Hold down the "Stop" button for a few seconds to turn off the "Demo" mode and restart the unit.
  • Turn the machine off and unplug the machine if the console display is not working correctly. Wait a few minutes and plug the machine back into the electrical supply and turn on. The console should now operate correctly.
  • Hold down the "Stop" and "Speed" buttons at the same time if the incline is not changing as desired. Insert the key into the console while holding down the buttons and then release the buttons. Press the "Stop" button and the arrows to increase or decrease the incline. This will cause the incline to recalibrate. Remove the key from the console unit.
Sponsored Links
May 03, 2017 | Exercise & Fitness
Why won't incline go up or down?
Calibrating Your Incline Is your incline not operating correctly? There are a few simple steps that can be followed which will most likely resolve that problem for you.
9bvipvsqvatex9kgfcnn03s5zhvtng9too4023mrox7s22mjjuue73rxrrhupctrxro022nhu0i53bbtrxqocdrxro402hhw0410bbbtxqkad79poo41hbe1410ybbtwq+p8byj8qzuzzwaoaaaaasuvork5cyii=
The first step is to press and hold both the STOP and SPEED INCREASE buttons, this will be either an UP ARROW or a + (plus) symbol. While holding these two buttons down you will need to insert your safety key.
Once you have inserted the safety key you can release the buttons and let go of the key. At this point you will need to press the STOP button one time. Congratulations, you are now in Calibration Mode.
Now that we are in calibration, press the INCLINE UP button one time. This will cause the platform to go all the way up and then it will come all the way back down again.
Now that the incline has stopped moving you can remove the safety key.
Parts for ProForm Fitness Equipment Treadmills Bikes Ellipticals Belts...
Apr 26, 2014 | Proform Sport 1000 Folding Treadmill...
Some of the Vision Fitness t9450 treadmill incline and speed quick keys stopped working along with the manual speed and incline buttons
It sounds like you have a membrane issue. There are a number of different T9450 models and they all have slightly different consoles. You'll need your serial number to help pinpoint the parts you need. Your best bet is to go through the manufacturer (johnsonfit.com) and have them help you get the correct membrane and overlay.
Jun 08, 2017 | Dmm Vision Fitness T9500 Treadmill
Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
11_17_2011_8_43_24_pm.gifsincerely. Please keep me in touch.
Nov 17, 2011 | Nordic Track NordicTrack Commercial 1500...
I hae a Pro Form 540 Iteracive Trainer treadmill. When the key is inserted, the treadmill cuts on but the control panel doesn't seem to work when you touch start. I waited and cut it off and went...
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
Step 4 Repeat the process if the display does not read "Calibration Successful."
Aug 08, 2011 | Sport & Outdoor - Others
The Nordic Track machine's controls seem to be stuck. If I press any button other than "3 mph", it fails to respond and nothing happens. However, when I press the 3 mph button, it will only stay at the 3...
Remove the console from the treadmill and remove the back
remove and replace the ribbon cables that run from the keypads to the control board (they are flat plastic strips that push into the board).
remove and replace all the connections on the console
reattach the console and calibrate by doing the following:
1. With the key off press the speed + and stop buttons at the same time and hold
2. place the key on and release the buttons
3. press the stop key once
4. press the speed up til it reaches 85
5. if your max speed is 10 mph then it should read about 9.8-10.2
If the keys will not work then the console is bad and would need replaced.
Jul 22, 2010 | Nordic Track NordicTrack Treadmill, A2550
My treadmill proform835QT fails to incline. What can I do?
Try to calibrate the incline: Hold down the stop and speed up buttons at the same time then insert the key. release the buttons the press the stop button and release then press the incline up button. the incline motor should go all the way up then all the way down with - - on the console. If the unit only moves just a and inch or so or the motor just hums , the incline sensor is faulty.
Jan 15, 2010 | Proform CrossTrainer Treadmill
Nordictrack apex4100i level incline will not work
Try this calibration procedure.
Turn the power switch on. Remove the safety key. Hold the Stop and Speed Up or Speed Plus buttons down then insert the safety key.
The display should show some numbers.
Press the stop key one time and the display should show some other numbers and some 00's. Press the Incline Up button and see if the Incline begins to move, if it does let it go all the way up and then all the way down, wait a few seconds after it stops, then hit the stop key 4 times. It should be calibrated. If it didn't move then the board or the incline motor is bad.
May 31, 2009 | Nordic Track Nordictrack Apex 4100i...
Cybex International CYBEX LCX425T Treadmill Logo
152 people viewed this question
Top Cybex International Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Cybex International Exercise and Fitnes Expert? Answer questions, earn points and help others
