Question about Troy Garden
Tory bilt 21" lawn mower with briggs and stratton 550ex wont start no compression, valves are moving and piston is moving has spark
  • 33 Answers
Loss of compression is usually a bad head gasket or the spark plug is seated tightly.
Posted on Oct 22, 2013
Testimonial: "i put a compression gauge on it and it didnt move. beofre it ran one day then cut off then nothing"
  • 59 Answers
SOURCE: My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
Posted on Jun 26, 2009
  • 143 Answers
SOURCE: my lawn mower cranks but wont start I have
The magnets are fitted in the flywheel under the pullstart engine cover but i dont think thats your problem. It sounds more like fuel trouble. Remove and clean out the carb. and maybe renew the diaphram.
Posted on Sep 05, 2009
SOURCE: Cleaned the Briggs & Stratton Riding Lawn
kehmahcliff:
It looks like that your valves need to be maintenanced. This can be done by small engine repair shops. They should have the proper tools.
Also the "timing" of the spark and the fuel injection could be a problem. I hope this helped you.
Greetings Joe
Posted on Sep 30, 2009
  • 152 Answers
SOURCE: LOOKING FOR A MANUAL FOR A 21" CUT SELF PROPELLED
try putting your serial number and model number here. http://www.troybilt.ca/troybilt/troybilt_manual_search.asp
Posted on Aug 08, 2010
  • 6468 Answers
SOURCE: VALVE SETTING ON 21 HP BRIGGS AND STRATTON LAWN MOWER ENGINE MODEL 207577
i set mine to .006 and have no problems
Posted on Apr 03, 2012
Why doesn't the pull cord wont move
Could be a few things but I would start by taking the spark plug out to reduce the compression. This will make it easier for the engine to turn just to make sure the piston is moving. If it is an older machine you may have rust build up all the way to a seized engine depending on maintance preformed on the mower.
Jun 20, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
Hard hitting on compression stroke when starting
Most Briggs deco vaves are internal and pretty reliable, the valve clearances are very important, if the exhaust valve clerance is too wide the valve lifter will not work, if there is no adjustment yoy would have to fit a new service valve and re do the clerance by removing material from the valve stem
Jan 02, 2014 | Briggs AND Stratton Intek Briggs &...
14 HSORSE BRIGGS & STRATTON TRUNNS OVER QUICKLY WONT START
if it spins fast check for compression if none take the valve cover off and see if the valves are working if there working remove the head and inspect the valves and piston
Apr 24, 2012 | Garden
Tory bilt lawn tractor replaced with new battery
What most likely happened is the diaphram in the carberator has burst. It is a simple fix if you take your time, use reliable resources and be patient. The parts can be picked up at the local hardware store.
Mar 25, 2010 | Briggs & Stratton Garden
How to adjust valves on briggs and stratton 17.5 h.p. troy bilt lawn tractor
Remove spark plug
Remove cover from engine that covers the flywheel
Remove rockerarm cover or valve cover
Find TDC (top dead center) by rotating the flywheel by hand and your finger over the spark plug hole as you rotate the flywheel you will feel pressure against you finger at some point then stop.
This is the compression stroke it is called now find a long slim round piece of plastic or plastic ink pen to stick in the spark plug hole (If you are careful a slim screwdriver can be used ) and find the piston top, then slowly rotate flywheel again (cw) as the piston is moving up pushing the plastic up as you rotate the flywheel slowly.
a max. piston up or tdc as you turn you will feel and then the piston starts to go the other way,at that transition this is tdc (piston is on top of stroke) leave it there,,both valves should be closed at that point.
Have a feeler gauge and set the exhaust valve at a loose .002 and the intake a loose .004 be sure engine is cold when valves are adjusted
Feeler gauge goes in between the rocker arm tip and valve stem top for each valve setting.
Note the rocker adjustment at the push rod side of each valve by tightening and loosening to make adjustments,lock your adjustments in place and rotate flywheel a few times and recheck settings
Sep 20, 2009 | Briggs & Stratton Garden
Ran over somthing with lawn mower now it wont
You're right to check the flywheel key - are you certain it's ok? Also our instinct is to tip the machine over to clear the obstruction, which can send oil to places it shouldn't be! Does the machine have compression? It's possible to break the con-rod if you hit something really solid. You can check the piston's still moving by taking out the spark plug and inserting something like a cable tie in the plug hole. As you turn the engine over you should be able to detect the piston moving up and down. The jolt could also have dislodged coke in the engine that could foul the spark plug. Try fitting a new one. Come back to me if none of these solutions work..
Sep 09, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Cleaned the Briggs & Stratton Riding Lawn Mower's head and valves. Put it back together and it refuses to start, get good starting try, no joy. Checked the spark, great! Checked the gas- great!...
did you usae a new head gasket and clean the old gasket off? does the plug get gas? you must have spark, fuel, compression and timing in order for it to run. also did you gap the coil to flywheel spacing?
Jul 08, 2009 | Parks Optical 13.5hp Briggs And Stratton...
190cc 3in1 briggs and stratton mower wont start... new plug and good spark..any ideas..
Take the carburator apart and clean it. Also, clean needle and seat. Please let me know if this helps.
Apr 24, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Garden Logo
208 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
