Question about Exercise & Fitness
Nordic Track C2200 Error Code 440-17E what might be wrong?
MY treadmill got wet and is giving a Error Code 440-17e turns on but will only give the code will not do anything more.
    Top Expert:
  • 12,223 Answers
Reset the machine, follow this step and fix it. God bless you
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Posted on Oct 22, 2013
  • 64 Answers
SOURCE: Nordic Track Treadmill will not run
If console lights up but doesnt respond when buttons are pressed, you more than likely have a console problem. Key pad issue would be my best guess.
Posted on Jun 08, 2009
  • 103 Answers
SOURCE: Calibration Mode for nordic track treadmill model
Hello there, The calibration mode for a nordictrack is as follows.
With the safety key out, hold the stop and speed up arrow at the same time while inserting the key. Release the buttons. You will then be in diagnostics.
You then press the stop button one time.
If you are trying to calibrate the incline you just need to hit the incline up button and the machine will do an incline calibration. The unit should go all the way to the top and return to the bottom when completed.
If you need to calibrate the speed you will need to press and hold the speed up button on the console until the display reads 85. The machine should then be running at its maximum speed (either 10 or 12 mph depending on the unit)
The display will show a speed on the console and should be within .3 of the maximum speed.
If it is not then it will need to be adjusted using a potentiometer on the control pwb.
To access the control pwb open the hood cover. Should be 3 screws in the rear of the cover and 2 screws on the bottom of the unit.
Once inside the cover locate the control pwb. On the control pwb there will be a yellow/orange potentiometer. This is the adjusting part.
Use a non-metallic phillips head screw driver to adjust the potentiometer either clockwise for faster or counterclockwise for slower.
Hope this helps!
Good Luck! Tim
Posted on Jan 13, 2010
Testimonial: "Although I haven't attempted this solution, but it makes perfect sense and will attempt it as soon as I get back to the treadmill - Thank you"
  • 3 Answers
SOURCE: I have a Nordic Track treadmill C1800. When first
You have 1,2 or maybe 3 problems. 1st is you need to remove the cover over the motor. The belt that the motor turns may be slipping. You need to loosen the bolt that keeps the tension on the drive belt. Push down to tighten manually and then tighten bolt. While your in there you should check the drive belt for wear. If you have used the treadmill a lot it may need replacement. $20 from readmilldocter.com The walking belt if badly worn can be replaced for like $99 but probably is fine. put all back together and tighten tension. Should be able to lift walking belt 3 to 4 inches from center sides. Any less and its too tight. Its probably better to just replace the drive belt anyway. This should work. Do not over tighten ever. This is the cause of most problems.
Posted on Feb 20, 2010
SOURCE: my nordic track treadmill won't decline
My wife had the same problem with her treadmill. I turned the beast on it's side, and unscrewed the plastic casing that houses the motor, computer, and all the electronics to the treadmill. I unplugged the incline/decline motor. Then on the bottom of the treadmill the long threaded rod that causes the incline needed to be moved. So I unbolted it from the catch, and manually screwed the rod back in with a wrench. Now the treadmill works fantastically, of course the incline/decline mechanism has been disabled, but I would rather have a treadmill with the incline disabled than have one always on 100% incline. Hope you found this helpful :)
Posted on Apr 19, 2010
SOURCE: Have a nordic track exp 1000x treadmill and the
my nordictrack exp1000x doesn't elevate anymore, what can be the problem and how can i fix it?
Posted on Oct 29, 2010
Tread belt not turning on
please LUBE the deck belt with WD-40 or grease . and try to loose a little the deck, the idea is to lift- 2-3" max.
Of course is time too, to maintenance Motor
Feb 12, 2015 | Nordic Track NordicTrack C2200 Treadmill...
STARTS AND THEN ITS STOPS??
If the timer is set it will always stop at EXACTLY the same time.
If the motor is overheating, it will usually slow down before it stops; and the time will be a little different each time.
Congratulations, I only know one other person who has worn out a nodic track.
Feb 03, 2015 | Nordic Track Nordictrack C2200 Treadmill...
Nordi Track Treadmill C2200
treadmills draw alot of amps when being used. they recommend a 20 amp dedicated outlet.i ran into the same problem with a treadclimber.
you can try using a 15 amp but make sure nothing else is on that line
Mar 20, 2014 | Nordic Track Nordictrack C2200 Treadmill...
NTL 1192 is the product.
The reset switch is to close to main switch, reset it. See your instruction manual in section troubleshooting. for identify the reset switch. or download your instr. manual from www. fitness.manualsonline.com
God bless you
Nov 07, 2012 | Nordic Track Nordictrack C2200 Treadmill...
C2200 treadmill motor problem
1)measure the voltage input motor, if there are The motor need repair or replace.
2) mEASURE the output voltage board, for input voltage motor, if there are NOT the board is faulty, see the block diagram.
3) Test th drive belt for loose or break and replace.
Jun 28, 2012 | Nordic Track Nordictrack C2200 Treadmill...
My Nordic Track C2200 Treadmill will stop in mid run. The timing when it happens is random. I can pull the safety tab out and put it back in and run for a bit till it stops again. Any suggestions on...
It it completely shuts down ( console shuts down then restarts) it may be a static electricity problem. Check your outlet to be sure it is grounded. Check the plug . The ground pin may have been removed.
Jan 02, 2011 | Nordic Track Exercise & Fitness
I have a Nordictrack c2200 treadmill. All of a sudden I feel like I am going to fall through when I run near the front of it. What could be the problem? And if it is the deck, can I flip it and use the...
The deck is most likely broken, It would need replaced if this is the problem. The nordictrack models do not have decks that can be flipped. That is usually reserved for a commercial grade machine of a different brand.
Aug 13, 2010 | Nordic Track Exercise & Fitness
My c2200 treadmill will not reset or operate other than the incline from 4 degrees thru 12 degrees. fan nor tread will operate. Pulse sensor does work. is there reset instructions
This is dinesh from AADHI FITNESS SERVICE CENTRE...
Search for the details in justdial india...
Can we come to ur place and check the machine... My contact no is 9986202487
Jul 28, 2010 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
131 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
