Question about Hoover F5835900 Upright Steam Vacuum
Water keeps running while trying to suck. replaced the water pump. something in handle or trigger
Castex Scx 400
It sounds like the valve that actuates the flow of water is stuck open. Whether or not you could fix it depends on how the handle is configured. If the handle triggers something internally then it needs to be disassembled and the valve given some oil.
Mar 06, 2016 | Vacuums
Hoover steam vac maxx 77 motor suddenly not running?? its almost new
Should still be in warranty. Read the warranty and get in touch with Hoover.
May 07, 2015 | Hoover Vacuums
No water getting to brushs
Hi! Sometimes it is necessary to prime the trigger under the handle to get the solution flowing. To prime the trigger, recline the handle and pump trigger about 60 times. Then, power the cleaner on and squeeze the trigger for about 60 seconds. The solution should start to dispense. If it is still not dispensing there may be an issue with the pump assembly on the cleaner. We would recommend taking the cleaner in to a Hoover authorized service center for repair. Follow the link to locate one nearest you. Service Center Locator
Hope this helps!
Jun 12, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Leaves too much water on floor. Do I release the trigger to suck up water or keep it pulled at all times?
I don't know the particular brand you're talking about, but in my experience I do one pass with the trigger/sprayer on and then two or three passes with just the vacuum to remove the excess water. Devices with sprayers always need at least one pass over without the sprayer trigger on.
Nov 05, 2013 | Mytee 8904 Spinner Hard Surface Cleaner...
Been cleaning for 2 hours now with my Bissell Quicksteamer and on my next run i presses the water release trigger on the handle and water isnt being squirted on the carpet..why?
ran out of water? (if water) >
Is there some form of water filter?
Problem with the trigger?
Bad steam heating element or the power connection supplying the power to it?
Of could it just be tired and need a break? (grin)
Best Regards
Ck
Aug 16, 2011 | Vacuums
Carpet steamer continually sprays water/cleaner. Can't stop it!
This is a solution for the Bissell Pro Heat, although it may apply to other Bissell steam cleaners as well. This is for the problem of the cleaning solution continually spraying without stop.
I found a quick and simple solution to this problem.
This problem occurs because the valve that allows the solution to flow gets "sticky" and will not close. The valve is engaged by the trigger mechanism in the handle. Squeezing the trigger pushes downward on the valve's plunger, but the spring in the valve that is meant to push the plunger back up to the closed position is not capable of doing so.
Here's the solution:
This valve is white and resides about half way down the vertical handle portion of the cleaner. To get to it, unscrew the 2 black screws that hold the top part of the handle to the bottom part. These are the same screws that you used for assembling the cleaner when you first bought it. Pull the top portion of the handle up and it should slide out.
Now, looking down into the handle body of the remaining portion of the handle, you'll see the top of the white valve. If you push down on the top of the valve (like the trigger mechanism in the top part of the handle you just removed does) it may go down some, but it probably won't go back up by itself like it should.
I found that lubricating this plunger with dish soap was the trick. If you can't get enough access to the valve to do this, you can remove the seven phillips head screws in the lower portion of the handle and pry it apart. I did this. I even took the valve out and put soap around the plunger and into the valve itself. I worked it up and down until it had a quick and positive open/close action.
Reassemble and you should be good to go. You'll notice that the trigger now has a more positive feel to it. I hope this helps.
Dec 14, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
How to install a new water pump on a big Green machine?
I have replaced this pump before, and had the pump "seize" again. I hooked the output of the bissel to a siphon pump to pull a vacuum while i had the input hose (with the little filter) submerged in a bucket of water. After i got the pump started, I submerged both the inlet and outlet hoses (after the trigger handle) into a bucket of warm water and turned the spray switch on to circulate clear water through the whole deal
Jun 27, 2008 | Bissell Vacuums
No Water
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle also, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just re-fasten it down.
Bissel's Number is: 1-800-237-7691, they can tell you were to get service in your area.
Jun 23, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Won't spray. . .nothing happens when pull trigger. . .pump belt is ok. ..
I assume you've changed the flat belt and it's working o.k. So, the next thing to check is the bucket seat. When the bucket is set down into the machine, the bucket valve is opened by the center pin on the receiver in the floor of the machine. You should put clean water into the bucket and install it. Wait a couple of seconds and remove it. Inspect the receiver and see if there is any water in it. If not, check the valve in the bucket and make sure that the rubber seal is in place. Sometimes they come off and stay stuck in the receiver. This will not allow the valve to open. If the seal is stuck in the receiver, remove it and re-install it on the bucket valve and test again.
By the way, if there is no shampoo in the shampoo tank, and the mixture dial is set anywhere but off, the machine will not spray. The pump will suck air through the empty tank and will not pick up water from the main tank.
If there is water in the receiver after you remove the bucket, then the problem is likely in the heater. The heater is located in the center of the handle and you must open the handle by removing the hose storage rack and then the top of the handle. There are two screws behind the hose holder that are at the back/bottom of the handle and are recessed into the handle. Once the handle is open, the heater is obvious. You will find two clear hoses attached and they often become plugged at the connections, just inside the heater. You can clear this with a 1/8" drill bit. Remove the hoses and take the bit in you hand and gently insert and rotate. Once cleared, replace the hoses and reassemble. I hope this helps. Be careful. These machines are a maze of hoses and valves and can be difficult to reassemble. Be very observant whenever taking one apart.
One more thing. I have seen instances where the screws that hold down the hood in the area of the tank have broken through the plastic and will lift enough that the tank will not sit down far enough to allow the valve to open. Check here, too.
I hope this helps.
Jan 30, 2008 | Bissell 8910 ProHeat Clear View Upright...
Hoover F5835900 Upright Steam Vacuum Logo
24 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
