Question about Sewing Machines
Is there a way to reset the Bernina Aurora 430? I seem to be getting computer glitches.
SOURCE: Bernina Aurora 430
I figured out the solution for this issue. It all has to do with the threading. And I mean literally follow the instructions word for word. Most importantly is the Bobbin thread. make sure to thread the bobbin through the case eyelet.
Posted on Mar 29, 2008
  • 8 Answers
SOURCE: I have a Bernina Aurora
If you remove the metal plate on the bottom of your machine, you can see the workings of the feed dog raise and lower button. With some luck it just might be a screw that came out or it might be a broken spring inside the sewing arm.
Without a service manual or a view of what it should look like inside when it is functioning correctly, at best you would just be guessing. It should be a simple 5 min fix but it is best to take it to a Bernina dealer for proper repair. Good luck, bushvideo
Posted on Sep 27, 2008
  • 52 Answers
SOURCE: Bernina Aurora 430 utomatic button hole
Take it to your local bernina dealer and have them calibrate the buttonhole foot along with the speed control.
Posted on Jun 25, 2009
RickE1
  • 202 Answers
SOURCE: Aurora 430 Bernina
Hi, possibly your feedogs are dropped and in the darning position and/or its thinking you want to embroider and there is NO hoop attached or entire embroidery unit plugged in. Check your feedog button below the handwheel on the bottom.
Rick
Posted on Aug 02, 2009
  • 255 Answers
SOURCE: I get an electrical tingle from metalwork on
It's NOT a good answer!! Sounds to me like you have an short in the wiring. Unplug the machine and check all the wiring connections. Replace any frayed wires and make sure the connections are solid.
Robbie
Posted on Jul 30, 2010
430 aurora
Probably too thick to feed without dislodging the bobbin case, causing the error message.
May 07, 2013 | Bernina Activa 140
I get an electrical tingle from metalwork on Bernina Aurora 430. They say this is common and not a problem. That doesn't sound like a good answer!
Robbie
Jul 27, 2010 | Bernina Activa 140
Bernina aurora 430 calibration problem
The complete manual is available at:
http://www.bernina.com/en-US/SupportData/BERNINA-Nah-und-Stickmaschinen/aurora/Manuals/032907-52-04_1103_a430_a440_a450_EN
A reset can be done as follows:
press the clr button. The altered stitches will be set to basic when you turn the machine off
May 21, 2017 | Bernina Artista 180
Aurora 430 Bernina
Rick
Jul 29, 2009 | Bernina Sewing Machines
Jun 07, 2009 | Bernina Artista 180
Bernina 430 aurora will not sew, beeps when pedal is pushed...
If you took the door off check and make sure the lower thread sensor on the door is snapped on correctly. Many times it gets put on beneith the bar rather than over it.
Nov 27, 2008 | Bernina Activa 140
I have a Bernina Aurora 430 (not on your list). For some reason, the feed dogs have dropped. The button that usually drops them isn't working.
Aug 17, 2008 | Bernina Artista 180
Bernina Aurora 430
Jan 11, 2008 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
