Question edited for full 'make model (what it is)'.
Question moved from Cars and Trucks category.
You will need a multimeter to check the switch and cabling to the socket, and also check if the new bulb is good.
REPLACING THE BULB
1. Use only a 10 watt maximum, candelabra base bulb.
Turn the light switch off and unplug the saw.
2. Remove old bulb. Place new bulb into socket
I'm sorry I could not find any downloadable information on this scroll saw, but I would imagine if you call or email the company above, they may be able to email you a PDF of what you need. Good luck.
Sorry, but that is not going to work ,that motor is not compatible with that type switch. you would need a variable speed motor.Newer models have many more improvements, you should try one of them,much smoother cut. Good luck and please don't forget to rate this answer.Thanks.
