Question about Weslo Exercise & Fitness
Dyaco treadmill model 909
Dyaco Treadmill, Model #ET98.
SOURCE: york t500 treadmill model no:LQ6010 showing err07 when turned on
Error 7 is a Safety Key Error..
that's the red magnetic circular thingy on the console.
Simply secure the safety key in place and try it again
Posted on Apr 20, 2009
SOURCE: roger black gold treadmill
Me neither. I can switch it on but cant get it to do anything :(
Posted on Dec 01, 2009
  • 73 Answers
SOURCE: Running belt slips om treadmill Sports Art 1060
Either the belt has stretched (normal wear over time) or the tension needs to be readjusted to tighten it. Every treadmill is different, and some can't be adjusted, so I can't really help with particulars, but if you get down and look really carefully, you'll be able to find the tension adjustment mechanism if it exists. Good Luck.
Posted on Dec 07, 2009
  • 103 Answers
SOURCE: Calibration Mode for nordic track treadmill model
Hello there, The calibration mode for a nordictrack is as follows.
With the safety key out, hold the stop and speed up arrow at the same time while inserting the key. Release the buttons. You will then be in diagnostics.
You then press the stop button one time.
If you are trying to calibrate the incline you just need to hit the incline up button and the machine will do an incline calibration. The unit should go all the way to the top and return to the bottom when completed.
If you need to calibrate the speed you will need to press and hold the speed up button on the console until the display reads 85. The machine should then be running at its maximum speed (either 10 or 12 mph depending on the unit)
The display will show a speed on the console and should be within .3 of the maximum speed.
If it is not then it will need to be adjusted using a potentiometer on the control pwb.
To access the control pwb open the hood cover. Should be 3 screws in the rear of the cover and 2 screws on the bottom of the unit.
Once inside the cover locate the control pwb. On the control pwb there will be a yellow/orange potentiometer. This is the adjusting part.
Use a non-metallic phillips head screw driver to adjust the potentiometer either clockwise for faster or counterclockwise for slower.
Hope this helps!
Good Luck! Tim
Posted on Jan 13, 2010
Testimonial: "Although I haven't attempted this solution, but it makes perfect sense and will attempt it as soon as I get back to the treadmill - Thank you"
  • 6 Answers
SOURCE: Treadmill incline error
Try this, it fixed it for me, if it doesn't work let me know
http://www.youtube.com/watch?v=MIIxoPtvhy8
I bought a used Precor 9.4 treadmill, but the incline adjustment was not working.
So, I did the following.
1. Turn off, unplug the treadmill and wait for an hour (this is for safety
2. Remove the black motor cover
3. Observe the transformer to the right of the motor and towards the belt ( I point to it in the video)
This transformer converts DC electricity to AC electricity and the AC current goes directly to the Incline motor which is in the black box towards the front of the machine.
4. On mine the wires had come loose from the transformer, they were soldered on very poorly, the wires are stiff and you should be able to see 4 wires coming from the top of the circuit board and plugging into the transformer, I had three of the 4 wires loose.
5. If you are not comfortable working with electronics or soldering DO NOT DO THIS REPAIR, you could get shocked very badly if you just go poking around in there with metal objects, get a friend who knows how to solder or hire someone.
6. It took about 5 minutes I just heated up my $10 soldering gun from radio shack and soldered all the loose wires that were about a millimeter away from the tabs on the back of the transformer, and VOILA! The incline now works!
Posted on Mar 25, 2010
Can I fix a NB1500 treadmill belt that is bowing in the middle? I've tried adjusting the tighteners on the back and cannot eliminate the bowing in the middle.
No, you need a new belt as it is stretched because that is where it gets pounded all the time. $50 to $100 depending on the quality you choose.
New Balance 1500 Treadmill Walking Belt 20 x 119 - Treadmill Doctor
https://www.treadmilldoctor.com/new-balance-walking-belt-1500
Replacement Walking Belt For The New Balance 1500 Treadmill. Belt size 20" X 119".
New Balance 1500 Treadmill Walking Belt - eBay
www.ebay.com > ... > Fitness Equipment & Gear > Other Fitness Equipment & Gear US$94.99 - ‎In stock
New Balance 1500 Treadmill Walking Belt in Sporting Goods, Fitness, Running & Yoga, Fitness Equipment & Gear, Other Fitness Equipment & Gear ' eBay.
Amazon.com : New Balance Treadmill Running Belt Model 1500 ...
https://www.amazon.com/Balance-Treadmill-Running-Belt-Model/.../B00H4QKAOO Rating: 5 - ‎1 review
This is a 1-ply Residential walking belt, some sellers will try to sell you a 2-ply belt (claiming better quality) for your treadmill, which is not recommended for ...
Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt ...
https://www.amazon.com/Newbalance-Treadmill-Running-Belt-Model/.../B008EYOF... Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt Model 1500 : Exercise Treadmill Belts : Sports & Outdoors.
NB1500 treadmill belt Google Search
Aug 14, 2017 | Exercise & Fitness
This treadmill require a magnet I bought it used did not have it
You can try using a strong refrigerator magnet. It's not coded or anything.
Otherwise, you can go to http://www.treadmilldoctor.com/treadmill-parts-model-select and pick your brand and model and order the part. Probably under "accessories" somewhere.
The treadmill should have a label with the model and part number.
Apr 02, 2015 | Exercise & Fitness
Manual for 1622738 Dyaco Freesprit treadmill
http://pincoffs.ca/files/Download/1622766en.pdf
Jan 31, 2015 | Cell Phones
Please RUN the software calibration for easy diagnostic and fix it.
Go under the HOOD cover motor and see the steps. God bless you
Oct 10, 2013 | Exercise & Fitness
Does the odor treadmill measure heart rate without holding on to the grips
Are you sure you have the correct brand of Treadmill. Never heard of this one.
Double check your brand and model. IFIT is availalable on several brands and models of treadmills, it is possible that your treadmill only has heart rate grips and also possible it will do both.
Generally a treadmill that will work with a heart rate strap will say so right on the face.
Dec 05, 2010 | Heart Interface Ifit Treadmill My Progress...
I have a Freespirit treadmill model 909. It turns on and the track runs, but clicks off after just a few seconds. It was working fine until then. Now it does it every time I turn it on. What could be the...
it sounds like the speed sensor is not close enough to the magnet, or the speed sensor is bad. it is located inside the motor area, next to the pulley on the front roller. well depending on what treadmill you have. it can be shaped like a pencil but shorter. make sure it is about a centimeter away from the magnet that ison the flywheel. once you have moved it turn on the treadmill and try it, if it doesnt work then move the belt with your foot and every time the magnet goes past the sensor you should see a light flicker on the control board if not then the sensor needs to be replaced.
Sep 16, 2010 | Exercise & Fitness
Exercise & Fitness Logo
Top Weslo Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Shehu Pro
Shehu Pro
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
