Question about Alesis Sr 16 Stereo Drum Machine
I get a loud crack sound when I switch on the drum machine when I have it connected to the mixer
  • 61 Answers
That would be normal - the order you power up equipment is very important. Always start with peripherals and work toward the power amp. Powering off is reverse - power amp first. You can also mute the mixer channel you're plugged into before powering up the drum machine but get into the habit of proper power sequence.
Posted on Oct 22, 2013
Testimonial: "Only trouble is that when I first got the machine,(not long ago) and switched it on there was just a gentle click,now it is more of a bang. <a href=http://dress-up-games.en.softonic.com/ >i dress up games</a>"
  • Darren Stagg Oct 23, 2013
    That could be as simple as the gain/level settings at the time. Powering up a piece of equipment connected to a live channel will surely generate a noise and can damage speakers. I take it the unit works fine when powered up?
I have a pmp6000 powered mixer. I was running an ipod in and sending out to one powered speaker. I heard a loud pop and smoke started pouring out of the mixer. I immediately stopped using it. This morning...
Cease using the mixer until it is repaired. One or both of the amps have blown. Further use MAY result in power supply damage. 1 to 6 switching power transistors will have blown and often a Zener diode or two. If the metering resistors smoked, there will be two small surface mounted transistors per channel blown wide open as well. These are all in the HCA2400 amplifier module.
Feb 12, 2011 | Behringer PMP6000 / B215XL Powered Mixer...
When we are trying to get a reasonable level of sound for vocals before it gets loud enough to be able to hear clearly with the band playing it starts to clip at the speakers now we are only using this set...
Proper level setting of the mixer is important. HOWEVER if the clipping is occuring at the speakers the only possible problem MIGHT be that you have a supersonic feedback that is saturating the speakers above your hearing range, Be sure you don't boost the highs too much with the EQ as this can cause the feedback that you can't hear. Also make sure that you power the speakers from the SAME receptacle as the mixer, even if it means running an extension cord to bring power to the mixer. This is to avoid a low frequency hum and common mode distortion/damage. A low frequency hum could cause the clipping.
It would be a good idea to get a sound meter to check the sound level. You should be able to reach 85 Db from this system without clipping. If you need more than that, you MAY need more speakers if the band instruments are too loud. Also if the band has amps that get into the vocal microphones that adds to the clipping level... make sure the mics don't "hear" the band instruments. Make sure your speakers are toward the audience from the mics to avoid the supersonic feedback problem. If the vocalists can't hear themselves with that configuration you need to set up seperate stage monitors.
There are some pretty good videos on YouTube about proper mixer level setup.
Jan 30, 2011 | Behringer Xenyx X2442USB / Harbinger...
The sound on my synths is not working. I just bought reason5, and all that makes noise is the kong drum machine. I am very new at this so it is probably a stupid problem, but whenever I pull up the...
okaye, i justt figured itt outt, hopefully you gett an email aboutt this postt...
so anywayz yo,
how many instruments you have hooked up to your mixer? thats the key, #1.
make sure you have atleast ATLEAST 2 mixers in your start up program, once you use the max output input for your original mixer, the next instrument patch you load will not be routed, (no more space), you'll have to route it manually (press Tab) *get familar with routing your own devices, for reverb/chorus and such,
this applies to everything about recieving sound from your project/keyboard. and just route your extra devices on the new mixer --they go up to 14 channels, i have like 22!
so thats my solution, hope itt applies.
Dre'
South Caro-line-em- up
~1~
Jan 16, 2011 | Propellerhead Reason 5
Crate pa6fx powered mixer, powers on but when I hook speakers up to them, hear loud hissing and pops out of one of the speakers, nothing out of the other. I can hook up a mic and hear myself through the...
It is likely that there is a failure of one of the amps in the unit. It could be a cracked circuit board, bad solder, bad volume control, or a bad compnent in the power amp section for one side. HOWEVER something does NOT compute here as you can't connect more than one speaker to a 15 Watt Crate amp... Maybe you have two of these amps.
Dec 27, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Sound cutting out
You may be having early stages of arc over in the main amp. This leads to catastrophic failure of the power amp section (usually the rearward one) and sometimes the power supply.
Facing the back of theunit, usually the left speakon connector is the one that connects to the section that fails.
The arcing is between two layers of a multi-layer board.
Note, if you smell smoke or pop a fuse DO NOT continue to use the device but get immediate servicing.
Jul 10, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Can you directly hook a sr16 to a peavey bass speaker cabinet using the output mono on the sr16 to send or retrn on the cabinet?
You can, however a bass speaker cabinet will NOT handle the higher pitch sounds needed for cymbals and snares, etc. You would connect it to the return AND doing so would DISABLE the other inputs of the bass speaker cabinet.
If you want both a guitar and drum machine into the cabinet, you need at least a small mixer or a speaker cabinet that can take two channels input simultaneously.
Plugging into the "return" of the cabinet DISCONNECTS the power amp from the preamp section in the cabinet.
Nov 09, 2009 | Alesis Sr 16 Stereo Drum Machine
My Roland TD6 drum module output jacks have a bad hum and cut out
sounds like the solder on the connections has either dried and cracked or come loosse if the wrigling of cables works its the connections if you unpluig and remove the back panel look where the cable connect check the condition of the wiring at source point of contact you may need to resolder or reconnect..
Jul 29, 2009 | Music
The drum machine goes on and off, and I think the problem is at the connection from the power cord into the SR16. I think I need a new power cord.Or is there an internal problem at the connection?
It sounds like the adapter jack in the Alesis has a bad solder joint to the circuit board .This is a fairly common problem with all modules that have external power supplies and is an easy fix if you feel confident and are good at soldering.
May 16, 2009 | Alesis Sr 16 Stereo Drum Machine
Alesis SR-16 distorted sounds
The distorted and low volume output plus noise is usually caused by using the wrong power supply adapter. The Alesis SR-16 takes a 9V "A/C" supply not "DC". The A/C supply provides a negative voltage swing which wouldn't exist with a DC supply. So check and make sure you have 9V A/C output supply not DC.
Nov 18, 2008 | Alesis Sr 16 Stereo Drum Machine
Alesis Sr 16 Stereo Drum Machine Logo
88 people viewed this question
Top Alesis Music Experts
drivealot
Lawrence Oravetz
Robert Graf
Are you an Alesis Music Expert? Answer questions, earn points and help others
