Zenith z50pv220 While my children were watching cartoons one day they started yelling to turn the TV back on. The sound was still functional, but the screen was black with thin grey vertical lines. It is a Zenith Z50pv220 1080P 50" Plasma... Any ideas what the issue is and what the cost of parts and level of complication for install would be?
  • 179 Answers
SOURCE: Toshiba 50HP95 50 in. Plasma TV Has A Black Vertical Line!
either the address buffer or the panel has gone bad..a technician would be needed to determine which one..
Posted on Nov 28, 2007
  • 31 Answers
SOURCE: 50" LG Plasma - Thin red vertical line in middle of screen
I work for a auth LG service center and each time I have had this symptom we had to either change what called the T_CON control board or the Plasma display panel itself. You need to cocntact LG @ 800-253-0000 report your problem and they will find a service center in your area you should have 1 year warranty parts and labor.
Posted on Mar 10, 2008
  • 4234 Answers
SOURCE: 42HDS69 42 in. Plasma has several thin green vertical lines in middle of screen
If the set is still in warranty, call for warranty service. If not and you feel comfortable working on the set, carefully open up the back and reseat all of hte cables and connectors. This can be caused by marginal connections inside the set.
Keep us posted on your progress and results.
Dan
Posted on Aug 29, 2008
SOURCE: a large pop and I lost my screen, it turned black
Its not the CRT, its the Y Sustain board.. This happened to mine 30 minutes ago.. and has happened to every owner of a plasma tv that uses the toshiba Y Sustain board..
Posted on Jul 21, 2009
  • 92 Answers
SOURCE: heard a loud pop in my zenith 50
LG Inside.
Needs either a Y-Sustain or a Z-Sustain.
Whichever has the blown fuse inside.
Posted on Sep 08, 2009
Z50PV220 TV CODE
These are all the Zenith codes that I have listed.
Zenith 0016 0017 0092 0178 1909
Jan 23, 2017 | Sony Televison & Video
Picked up a Zenith 50'' plasma TV model no. Z50PV220 at a garage sale with no remote. But I cannot get the screen to work. The tv powers on when plugged in as certain parts light up. How do I fix it?
dear me
you expect a tv from a garage sale to work.
if you didn't test it before paying money to see if it worked , it will probably cost more to fix than a new one
but still take it to a repair shop for a diagnosis and quote
Oct 30, 2016 | Zenith Televison & Video
Zenith sound issues
Check the sound mute button in your remote and press it and watch the TV menu.
Apr 27, 2010 | Televison & Video
Sony KDP51WS550-LED light blinks 10 times
This is usually a problem on the high voltage board. When you first turn it on, the main board does it's P.O.S.T., then powers the HV board. You'll be hard pressed to find a replacement for it. You MIGHT find someone that can rebuild it, but for the money? Time for an open box special at you local electronics place.
Jul 02, 2017 | Gateway GTW-P42M303 42 in. Plasma...
Zenith tv no pic
You have a picture when you're watching a DVD, but none when you're watching regular cable? Does the audio appear to be okay?? Are you sure you've switched the inputs on the TV back to main???
Let me know..
Bill
Dec 08, 2007 | Zenith B25A24Z 25" TV
My tv will not turn on.
First of all, forget about the remote and see if the TV functions normally using the buttons on the front of the set itself. If the TV will not power on with the power button on the set itself, then something is wrong inside the TV. If the set works fine from the front buttons but no longer responds to that remote, then the remote has either gone bad or was accidently set to a different brand. In this case, look for the original book that came with the remote (or TV if it is the original remote) and follow the instructions for setting the remote back to Zenith. Try that and post your results here.
Aug 09, 2007 | Zenith C27A24T 27" TV
Speakers have died?
Probaby the stereo decoder IC went bad or a supply voltage to it is too low or noisy. If it has audio output jacks on the back of the TV, connect it to an external amplifier and see what that sounds like. If it is ok in stereo or mono mode then the amplifier in the TV is bad. This will prove that the stereo decoder is ok.
Feb 01, 2007 | Zenith C27A24T 27" TV
TV has green sceen and turns off by itself
you have the famous zenith shorted picture tube
Aug 07, 2006 | Zenith C27V22 27" TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
