Keeprite furnace reverse polarity - Heating & Cooling
4 Suggested Answers
gear001
  • 59 Answers
SOURCE: reverse polarity
Its a simple fix. Follow the cord that plugs into the wall into the furnace. Or if its hard wire, follow the romex wire that goes into your furnace. Inside the furnace, switch the white and black wires that connects to the power cord. www.fastacservice.com
Posted on Oct 18, 2009
  • 27 Answers
SOURCE: How do you reset the furnace when it indicates the
To reset any furnace just unplug and plug it back in. If the polarity has been reversed open up the small box the power cord goes to, you'll see white, black and green wires. find the ones that are attached directly to the power cord and switch the white with the black and vice versa.
Posted on Oct 19, 2011
  • 16 Answers
SOURCE: Reverse Polarity Code
check the green ground wire, make sure it is connected
Posted on Mar 12, 2013
Bryant plus 80 furnace no fan/ operation , yellow constant flashing light code , power to furnace was rerouted during remodel and since then furnace stopped working. Any suggestions ?
You need to have/ know the "fault code" chart for that specific furnace. Count the number of flashes and refer to chart. Look on the inside of the furnace blower door or other panel. Also look up on internet and print it off. If the furnace was allowed to run during the remodel it voids the warranty automatically. Read the installation manual.
Try resetting the electronic board by turning the power off then back on.
Mar 29, 2017 | Bryant Heating & Cooling
Keeprite Mid Efficiency furnace. Why won't blower shut off?
The thermostat may be set for continuous blower operation.
Dec 17, 2015 | Heating & Cooling
How do I change the furnace filter in a Keeprite CC18?
there should be an access where the cold air return goes into furnace.
just slide filter out
Feb 11, 2015 | Filter Heating & Cooling
My gibson furnace geves the error L1 neutral polarity
This means the hot ( L1 ) and the neutral connections are reversed.check the 120 volt power to the furnace for the correct polarity also make sure there is a good ground connection. Hope this helps.
Dec 07, 2013 | Heating & Cooling
I keep getting a reversed polarity signal on furnace.
Either you have a bad board, or current leakage between ground and neutral on the ac line. I have reversed the polarity on the black and white wires before and fixed it, but it's been rare.
Nov 21, 2013 | Goodman Furnace Draft Inducer Blower ...
Keeprite furnace
Is the furnace sitting directly on a concrete floor? If it is, it is taking up moisture from the floor. You need to get it up on blocks or some very solid base.
Oct 26, 2013 | Tools & Hardware - Others
How do you reset the furnace when it indicates the polarity has been reversed
Oct 02, 2011 | Goodman GMS90703BXA Heater
Keeprite furnace will come on heat up but the fan or blower doesn't blow but creat noise. please tell me how can I fix it. Regards Andre
Blower motor is either burnt or Ihave also seen the fan relay on the board burnt..test for 120v power out of the board at the blower leads if so replace motor, of no replace board
Feb 06, 2010 | Omega Keeprite Furnace Flue Exhaust Venter...
Heater not working after new uniot installed
you might switch polarity on the plug going into the furnace. Reversing polarity consists of taking the 110 volt line going into your furnace and switching the two plug wires aroung leaving the green connected. This may help since some furnaces run with the electricity going into the furnace a certian direction. Good luck on you repairsDave
Dec 02, 2009 | Heating & Cooling
Reverse polarity
Oct 18, 2009 | Heating & Cooling
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
