Question about Refrigerators
Zanussi ZKR 59/39 R fridge freezer: No sound. Fridge appears to have stopped running. Power supply okay (light on).
eagle338
  • 4889 Answers
SOURCE: Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Posted on Oct 09, 2007
eagle338
  • 4889 Answers
SOURCE: zanussi fridge freezer frostfree ZX 57/3 W not working
It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube.
Hope this helps,
Sai.
Posted on Jun 13, 2008
SOURCE: Hotpoint Mistral Frost Free Fridge freezer - fridge not getting cold
We have just had to call out an engineer to get our 1 1/2 year old Hotpoint Graphite Frost Free Fridge Freezer repaired. The fridge had almost entitely stopped cooling even when on high. I was amazed at how easily the problem was sorted. The engineer removed all the basktes from the freezer to access the screws on the inside backpanel of the freezer. Once this panel was removed it was clear that the so called Frost Free doesn't really mean what it says. The ice need to be melted with a bit of simple care. It is obvious that with a bit of care it is easliy a diy job BUT PLEASE BE CAREFUL AND READ THE NEXT PART BEFORE YOU BEGIN TO REMOVE THE ICE> The ice forms around variouys pipes etc and he usecd a screwdriver to help release the ice quicker than waiting for it to defrost and he also used a simple hairdryer to help speed up the process. He had a ntowel and a basin to take care of the water. Next time I would have no problem doing this myself but I would need to leave it a little while to defrost and NOT USE A SCREWDRIVER as I am sure somehow I would puncture a pipe or the wall of the freezer itself and I am quite used to doing the odd bit of DIY. On a difficulkty scale of 1 to 10 with 10 being difficult I would rate the job as about a 3. Hope this helps anyone who reads this about £70.
Posted on Dec 27, 2008
SOURCE: Fridge and freezer stopped working.Power still on
The double dashes in your display are for one of two reasons. First situation would be would be "you turned the unit off". Press the up arrow on the feezer or fresh food control until a 4 is in each display. Second, if the control is locked out, the board has been scrambled or failed possibly from a power surge. Unplug unit for 30 seconds, and plug it back in and try to set control's for "4". If controls are still locked out, the board (12868513) needs to be replaced.
Posted on Jun 05, 2009
woodchuck789
  • 4070 Answers
SOURCE: zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Aug 24, 2009
Sounds like a bad solder joint causing intermittent power issues...
Jun 19, 2016 | Zanussi Refrigerators
Zanussi zrb324nwo fridge not chilling.freezer forming ice/frost
Sounds like a defrost component Dave Start by turning the defrost timer slowly clockwise until refrigerator stops running and then stop. Open freezer and look and feel. Is defrost beginning to melt the ice?
Fridge Freezer Timer
Genuine spare part for select models of Electrolux, Faure, Zanussi and Zoppas fridge freezers.
Defrost Thermostat
or the
Fridge Freezer Defrost Heater
If you have questions please let me know, Thanks John Tripp Appliance 911
Contact Me Here
Sep 22, 2014 | Refrigerators
Zanussi fridge freezer wont stop making a whirring noise
Sounds like the unit is goosed and is trying none stop to get the temperature down in the fridge.
That is of course unless the ice is building up like an iceberg inside the cabinet in which case the thermostat has gone
Dec 06, 2009 | Freezers
Zanussi fridge freezer not cooling
no, its probably weak capacitors which provide power to switch the relay. Take the control board out and ask a friendly TV repair tech to change the capacitors
Jan 22, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge making a purring sound then stopped working
Yes, I think you have a problem that can be fixed easily by a repair technician. The sound as you described it could have come from the air circulation fan in the freezer compartment striking ice. As the ice builds up it could have stopped the fan from rotating and air flow to the refrigerator compartment.
Nov 27, 2008 | Zanussi Freezers
I have a zanussu fridge
Re. Zanussi ZK87/46EFS Fridge Freezer
The same symptom occurred in our fridge freezer. The fridge compartment warmed up whilst the freezer compartment continued to keep temperature.
The cause of our problem was diagnosed as a frozen sensor that controls a flap, that controls the flow of cold air from the freezer compartment up into the fridge compartment. We were advised to power off the fridge freezer (removing all food and trays from the freezer unit first), and to leave it to defrost for 24hrs. We needed to place a few towels on the floor of the freezer compartment to soak up the melt water. After 24hrs we followed the power up instructions in the manual (versions are available online if you have lost yours). Within a few minutes it was obvious that the fridge compartment was being cooled – Problem solved :)
Apr 13, 2008 | Zanussi Refrigerators
Oct 09, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
sounds like the freezer evaporator has iced /frosted up and you will not get cold airflow through it. try a 24 hour defrost to clear it. then check fridge cooling.
Jun 03, 2007 | Zanussi ZEBF250W Bottom Freezer...
Fridge not working
Sounds like the refrigerant has leaked out of the system.
Jul 28, 2006 | Zanussi ZSS7 / 5W Compact Refrigerator
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
