Question about Westinghouse Dishwashers
Inlet water hose leaking into cupboard on Westinghouse SB915, can this hose be replaced?
  • peaceofmi202
    peaceofmi202 Oct 21, 2013
    Thanks Stretch ;)
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,554 Answers
Posted on Oct 21, 2013
Testimonial: "Awesome, thanks Mate"
  • 5 Answers
SOURCE: Westinghouse sb915 will not heat
Westinghouse SB907 had same problem, which I had thought might be the heating element. Fixed relay soldering on PCB where it was burnt/melted, now works! This probably applies to the Westinghouse SB925 also.
Posted on Aug 25, 2008
rylee_smith
  • 8619 Answers
SOURCE: Bosch dishwasher is leaking fresh water from water inlet assembly
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. you should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Nov 11, 2009
SOURCE: Westinghouse SB915 wont heat up water
found the 2 large lugs mounted on the circuit board had been hot and had dry solder joint's removed solder cleaned with sand paper then re soldered and tested it now heats up .
Posted on Feb 04, 2011
  • 10 Answers
SOURCE: runs through entire cycle fine but water is cold
you need replaced the control board its very popular with this dishwashers cost around $220 as i have replaced mine
  • 10 Answers
SOURCE: Hi, we haven't got a
press hold in for few seconds if not get unlocked you have to get new on and of switch due to this dishwasher switch burns out its popular with this dishwashers power switch burns out
Water not heating
water not heating I need some ideas to fix the problem.
Nov 18, 2012 | Westinghouse SB915
Want to take water hose off from back of the machine so I can feed it down the holes in the cupboard then put it back on can this be done easly or do I have to cut a big hole in the cupboard. cheers
Hi there Larry which hose are you refering to the inlet or the waste. You can take the inlet hose of very easily, However the waste pipe is conected to the waste pump inside the machine. If this is the pipe you wish to remove I would drill a bigger hole in the cupboard. let me know if this helps at all. Regards Gary.
Jul 02, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
I just had a Haus slimline dishwasher delivered and have tried to set it up. I have followed the instructions to the letter but the water inlet hose keeps leaking out water when you move the dishwasher...
It is possible the dishwasher inlet is set for low water pressure.
Check the water pressure setting matches your inlet water pressure.
It might help if you provide the model number of the dishwasher.
May 31, 2011 | Dishwashers
I have a Westinghouse washer model # WWS833ES0. It will not fill with cold water.. only hot. And it does not fill any water on any rinse cycle. Any ideas as to what parts I will need to fix this? Thank...
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. Here is a video at that will walk you thru the testing a water inlet valve. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available. All parts come with installation instructions.
Sep 27, 2010 | Westinghouse Washing Machines
Runs through entire cycle fine but water is cold
Apr 07, 2010 | Fisher DD603FCSS Dishwasher
Westinghouse sb915 - draining too early.
1. Is your drain point higher than the bottom of the dishwasher? (ie, does it drain into the garbage disposer or does the drain line drop down below the floor into house plumbing?) Did you just install the unit? You may have to install an "air gap" to prevent syphoning.
2. Did the dishwasher work then suddenly stop working? (asking for clarification)
Dec 13, 2009 | Westinghouse Dishwashers
Water is leaking out from the bottom
If the washer leaks all the time, check these:
  • Water inlet valve: If water drips even when the washer is off,check the water inlet valve. It is located inside the washer at the back of the unit. The fill hoses are attached to it. Replace if deemed necessary.
  • Water fill hoses: Check the water hoses from the household plumbing. Tighten it or replace it as necessary..
  • Main tub seal: It is located between the transmission and the outer tub. To see the leak, fill the machine with water with small amount of detergent then open up the machine's main access panel.. The leak appears at the underside of the outer tub, at or near the center. The seal is difficult to replace and you probably should call a qualified appliance repair technician.
  • Pump: You can spot the leak when the tub is full of water if the pump leaks. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. Replace it as necessary if it leaks.
  • Outer tub: The outer tub can rust, split, or be punctured.You may have to replace the entire tub but its not economical repair to do. Consult a qualified technician for details.
If the washer leaks only during the fill cycle, check these:
  1. Air-gap device: It is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It is located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. It is usually made of translucent plastic. If one of the air-gap components deforms or cracks, you have to replace it.
  2. The tube: It is a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  3. Inlet spout: It is a plastic spout found on most washers near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
Oct 26, 2009 | GE WBSR3140DW Top Load Washer
I have a ge washer wpsr3120w0aa that leaks water when rinsing
Servicing Water Inlet ValvesIf the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced. To check the valve assembly:
©2006 Publications International, Ltd.
If an inlet valve is faulty, check the water connection and the
valve screens. Try gently tapping the solenoids;
if this doesn't work, replace the inlet valve assembly.
Step 1: Remove the back service panel and disconnect the hot-water and cold-water hoses to the valves.
Step 2: Remove the hoses connected to the valves inside the cabinet. Also disconnect the wires from the terminals. Back out the screws holding the valves to the machine. The inlet valves have solenoids (a coil of wire that carries a current) inside the housing. These can be tested, but chances are the valves are simply worn out.
Step 3: Tap the solenoids with a screwdriver handle. If this doesn't work, replace the entire inlet valve assembly. Repairs usually cost more than a new part. Make sure the replacement valve assembly is exactly the same type as the old one. Install it in reverse order of the way you disconnected the old one.
Troubleshooting Water Leaks
Water leaks in a washer are often difficult to trace. There are many possibilities to look for. The problem could be a loose connection, a broken hose, a cracked component, or a defective seal. It could also be a hole in the tub. If a hole in the tub is the problem, it's usually best to replace the washer.
Most leaks can be eliminated by tightening water connections and replacing deteriorated components. To stop a leak:
Step 1: Check the lid seal. If faulty, replace with a new gasket.
Step 2: Check the hoses at faucet connections. Tighten connections or replace hoses.
Step 3: Check the hoses at water valve connections. Tighten connections or replace hoses.
Step 4: Check the drain hoses. Tighten connections or replace hoses.
Step 5: Check the inlet nozzles. Tighten connections or replace nozzles.
Step 6: Check the splash guard. Tighten connections or replace.
Step 7: Check any plastic valve. Tighten connections or replace.
Step 8: Check the outlet hose to drain. Tighten connections or replace hose.
Step 9: Check the water pump, using the procedures that follow.
Aug 29, 2009 | Washing Machines
Jul 26, 2009 | Westinghouse Dishwashers
Westinghouse 906 leaks from front door
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Oct 05, 2008 | Westinghouse 24 in. MDP531 RF...
Dishwashers Logo
100 people viewed this question
Top Westinghouse Dishwashers Experts
Denis FixYa...
Denis FixYa...
Vouharas Vasilios
Level 1 Expert
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
