Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
My 1995 silverado ignition will not turn on I have jiggled the wheel and tried all that i know. I cant get the ignition switch out because the switch will not turn
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 29 Answers
First have new key cut by code at locksmith if doesnt work pop switch out with large screwdriver and have replaced
Posted on Oct 21, 2013
Ignition key does not turn
Jiggle steering wheel while trying to turn it. If that doesn't work there should probably be a little piece on your steering counsil that you can remove with a small flathead screwdriver remove and press the switch try turning key
Dec 08, 2011 | 1995 Ford F150 Styleside Regular Cab
WHEN I PUT THE KEY IN THE IGNITION IT WONT TURN BACK NOR FORTH SPRAYED W D 40 IN IGNITION HOLE AND STILL WONT TURN
is the steering wheel locked? is the the gear shifter all the way in the park position if its an automatic that is...try moving the steering wheel back and forth while trying to turn the ignition it may help but not always the case.. spraying wd 40 in the ignition may cause more harm than good so be careful what you spray.. also check the key is it damaged in anyway? is it the same with all the keys meaning spares? in some vehicles it was a safety messure to lock the ignition if the shifter wasnt all the way in the park position or if the steering wheel was locked with pressure applied to it so try to jiggle it, so if its not due to a locked wheel then most likely the mechanical portion of the ignition may have broke the best thing to do at this point would involve getting the ignition replaced it will save you lots of head aches
Feb 08, 2011 | 1995-1997 Chevy 1500 Truck Ignition...
The steering wheel has locked up and the battery light came on. The car won't start. What is the problem?
I need more info. Are the keys in the ignition and is the switch turned on. Check to see if you have the car all the way into park. Jiggle the gear selector around and see if it will start while you turn switch.
Nov 09, 2009 | 1995 Buick Regal
Key dont turn
try turning the steering wheel hard both ways while jiggling the key (gently, you don't wanna snap it off) in the ignition. usually it just gets hung up on the steering wheel lock.
if that doesn't do it, try the same but with a spare key
Sep 30, 2009 | 1995 Chevrolet S-10 CA Edition
My son needs help. The 2000 Land Rover Range Rover was running fine but was low on fuel. Stopped and filled up tank and then after unlocking could not get the key to turn in the ignition. Wheel column...
have to jiggle the steering wheel while gently trying to coax the key back. i have had this happen to me on a couple of occasions. finesse. don't try to force, just nice and gently back and forth and it will free up the internal locking mechanism which is preventing you from turning the wheel.
good luck, hope this helps
Sep 28, 2009 | 2000 Land Rover Range Rover
1995 Honda Civic won't start
U will need to replace the ignition electrical switch, it is attached to the other end of the ignition key cylinder,de-trim the steering wheel for access to the switch, about 4 screws hold the **** shell covers on.
May 26, 2009 | 1995 Honda Civic
Changing the ignition in a 1995 Nissan 200SX
this is not a job a novice really should tackle as you can do a lot of damage to all the other switches located in the steering column. You should call a locksmith or have the car towed to an auto repair shop and have them change the switch.
May 04, 2009 | Mercury Cougar Cars & Trucks
Steering ignition switch lock
Jiggle the steering wheel back and forth while trying to get the key back in. Keep jiggling the wheel while turning the key until it all works out.
Apr 06, 2009 | 1995 Buick Regal
Ignition switch locks and it cant be cranked
your key may overly worn and replaced, try jiggling the key and steering wheel at the same time. if that doesnt work try sraying a penetrating oil, like WD40 or PB Blaster, into the lock cylinder. it could also be the shift knob safety switch not disengaging or a faulty ignition switch
Nov 30, 2008 | 1999 Jeep Cherokee
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
46 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
