I have a 2004 Kitchen Aid Superba Oven and I'm trying to figure out if there is a way to lock the oven door. I have a toddler.
SOURCE: KitchenAid Superba Microwave/Oven, Microway Door message
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
SOURCE: Kitchenaid Superba microwave oven combo close door error
turn off the main power outlet it will work.
SOURCE: can we light a gas oven manually, it is a kitchenaid superba
No, You have to replace it. When the ignitor grows weak, it does not allow enough voltage through it to open the gas valve. Very common problem. Good Luck, Appliance Specialists
SOURCE: Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
SOURCE: MY Kitchen Aid Superba Oven door KERC507Y will not
The only real fix is to replace the springs on the door closer. Sounds like they got stretched or bent. Usually you can replace the whole hinge in about 30 minutes and that should help.
[email protected] and type 'Attention: Audrey' in the subject line. Please include your full name, phone number, and model and serial number, and I would be happy to try to help resolve the situation with your appliance.
