Question about Patton Electric Patton U2-2003UC 20" 3 Speed, High Velocity Multi Room Air Circulator Fan
My Patton fan sometimes wont start when turned on. Can it be oiled?
    Genius:
  • Patton Electric Master
  • 1,617 Answers
No! Try checking the capacitor to see if it's bad.
Posted on Oct 22, 2013
When I plug my patton streamline fan up, the and timer comes on but the fan doesn't turn
it would be helpful to clarify if the fan doesn't turn ON or if the fan in fact does not turn, like on oscillate mode. has it worked for you in the past? or been defective since you purchased it?
Jun 06, 2014 | Patton Streamline Window Fan
Where do i find a replacement motor for my patton model u-2-1887 fan? 120v/60hz/270w/2.6 amps. or where would i get the motor rebuilt?
Before you replace it, try oiling it -- look at the little oil hole on the back of the motor housing. Or try taking it apart and cleaning it, then oiling.
Did it work before, but gradually slowed down and then refused to start? See other threads on this topic for that fan model.
Jul 15, 2010 | Patton U2-1887HO Floor / Box Fan
Patton 1887 fan blades wont turn
I've had an 1887 since the 90s -- great fan. I have to say that FixinFax (Solution 1 above) probably didn't try to take his unit apart. My blade has stopped rotating several times over the years and I always got it going again by myself. I'm no whiz, just your average amateur handyman. In fact I am fixing the motherbleeper right now because in a week where the heat is 100 degrees it chose to slow down and stop.
Eventually it sucks enough dust into the axle housing so you have to take the motor mechanism apart and clean it. It's not terribly complicated, but you have to note how the electrical and mechanical parts go back together before disassembling. It's a little tricky to get all the housing parts to line up level again, you may have to try a couple times till the blade rotates freely. Wipe out all the dust and gunk buildup. Lubricate the axle with oil, or I just spray with WD-40. Then reassemble.
The only thing I have had to replace is the on-off knob, since it's plastic and it split. Just get a universal knob from your local hardware store.
Aug 19, 2009 | Lakewood HV-18 Floor / Box Fan
Bad motor bearing?
If you know how (and have the tools;PULLER,nut drivers,slotted and phillips screw driver,hammer,deep socket set,dikes,vise,work bench,and some high temp bearring grease) to take things appart in general, you should be able to disassemble the fan motor and either pull bearings off shaft and replace or repack w/high temp grease if not sealed bearrings. If cannot aquire a puller for removal then attempt to blow all dirt/dust off bearring and try thumbing some motor oil (or vegetable oil if no motor oil available) while turning bearing on shaft back and forth till bearrings free up.Then reassemble electric fan motor reverse disassembly(be sure to keep parts staged as they come off for reassembly in area off the work area) "NOT" over oiling the bearrings into electrical/copper areas.
Aug 12, 2009 | Patton (HASF1016UC) Stand (Pedestal) Fan
Patton POH2520-U heater not working
I have a RD125T heater. At first it would run for a while and shut down. Turn it off and back on it would do the same. Now when it is turned on it acts as if the switch was being turn off and on. Sometimes the heater will fire for a second then shuts down. Most of the time it just shuts down, Forest
Jan 30, 2009 | Patton POH2520-U Oil Filled Radiator...
Space heater will power up, but not start,
These fans have a safey feature (sensor) that shuts the heater off if it is tipped over. It sounds like this component is not functioning correctly - may be set wrong and will not allow the heater to turn on unless you shake it to reset the sensor. If it is still under warranty return heater, if not call Patton and ask for help.
Mar 28, 2007 | Patton PUH9000-U Heater
Dryers Logo
276 people viewed this question
Top Patton Electric Dryers Experts
Darrell
Vernon Taylor
Andrew Taylor
Andrew Taylor
Are you a Patton Electric Dryer Expert? Answer questions, earn points and help others
