Question about Microwave Ovens
Sharp carousel microwave
Stopped working without power. Unplugging and replugging as recommended to reset the microwave allowed to set the clock. When opening of the door or starting the microwave, the display disappears with no buttons responding. Is the problem with the fuse?
  • Microwave Ovens Master
  • 2,113 Answers
You may need your main control panel repaired
Posted on Oct 22, 2013
MicrowaveSvc
  • 9085 Answers
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 18, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: R-4H84 Sharp Carousel II microwave oven stoped working
A microwave can be dead for many reasons.
The fuse is normally located on the floor of the chassis behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Jun 23, 2008
  • 176 Answers
SOURCE: My sharp microwave just stopped working. It
IT IS POSIBLE TO HAVE A BURNED FUSE ON THEI Main boARD OF THE OVEN
Posted on Feb 14, 2010
SOURCE: how to set the clock on my sharp carousel
Touch STOP/CLEAR pad.
Touch TIMER/CLOCK pad.
Enter the correct time of day by touching the numbers above in sequence.
(for example: for 12:30, touch 1 2 3 0)
Touch TIMER/CLOCK pad again.
Posted on Mar 11, 2010
SOURCE: sharp carousel R1754 microwave...display screen keeps scrambling
Stay away from Microwavedisplay.com and William E Miller. He will take your money and will not return your display unit let alone repairing it. Do your research. There are a lot of us out there!!!
Posted on Aug 31, 2010
I cannot reset clock
Touch Timer/Clock pad and number 2 pad.
Enter the correct time of day by touching the numbers in sequence.
Touch Timer/Clock pad again.
Aug 15, 2015 | Sharp Carousel R530EST Microwave Oven
Stopped working without power. Unplugging/re-plugging did not work. No display, no buttons responding. Is there re-set option?
there is a fuse inside,take it to someone that knows how to repair,if you use the wrong fuse,you could cause a fire or health problems
Mar 14, 2015 | Sharp R-820BK Microwave Convection Oven,...
Sharp Carousel II (R-9H83) loses clock, digital display dims
I think there are some electrolytic capacitors in the power supply to be replaced.Because there are relatively few, it would be good to change them all for more safety
Jun 02, 2014 | Microwave Ovens
I have a 1995 Sharp Carousel R-1440. Our power went out then when it came on our microwave it no longer working properly. the clock works but when the door is closed the cooling fan starts running- it...
Yes your oven's controller is probably malfunctioning you need to replace the SYSTEM BOARD but I personally suggest to buy an other oven.... the system board will be hard to find and expensive...
See if other electronics is acting funny since the power loss... you could CLAIM the damage from the insurance company
Good luck!!
Feb 28, 2011 | Sharp R-1460 Microwave Oven
I have a sharp carousel microwave model r-120D. It is flashing all 8's like so 88:88 and i cant get it to reset or work at all. Can you help?
usually does this after power outage. reset the clock. go to sharpusa.com and select PRODUCT DOWNLOADS under the CUSTOMER SUPPORT menu...select product not listed in drop down list, then enter R120PK in box....this should be the manual for your microwave
Dec 10, 2010 | Sharp R-120D Microwave Oven
My sharp 1214 won't heat anything. power is good - timer and clock are fine. stopped working in the middle of heating something. we use often. carousel is not rotating anymore either.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Aug 10, 2010 | Sharp R-1214 Microwave Oven
Unable to set microwave clock
sometimes the clock resets after unpluging for a short period. when you restart / power up note the time it starts at generally 12:00 miday good luck gbw
Feb 07, 2010 | Sharp Microwave Ovens
Does model, R 4A94 sharp carousel microwave oven have reset butto
I don't know of a reset button but there is a fuse that you have to remove the outer cover to get to that has a habit of blowing
Oct 14, 2009 | Sharp Microwave Ovens
Cant set the clock
hi
In most brandsof microwave oven, you set the clock by one of these combinations of key presses:
Clock > time digits > Clock
Clock > Clear > time digits > Clock
Clock > time digits > Start
If that doesn't work, please reply back with your brand and full model number.
All the best and do rate this answer if u r satisfied.
thankyou
May 10, 2009 | Microwave Ovens
Microwave Ovens Logo
138 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
