Question about Briggs & Stratton Garden
Working on a Briggs and Stratton 10T502-1457-B1. Runs rough and has black smoke coming from exhaust. This engine has no float to stick so that is not the problem. It does have a fuel primer bulb that works good. I have done all the usual things...cleaned air filter, put in fresh gas, installed a new appropriate spark plug, ensured valve/tappet clearance is correct, cleaned carburetor, tank, and screens, cleaned magnets on flywheel and magneto and checked air gap. It is obviously getting too much fuel. Why and how can it be corrected?
  • 71 Answers
Only think I can think of that would cause it to run rich is you may have left the springs out of the carburator body when reassymbling.
Check this diagram out page C
Carb diagram
Posted on Oct 22, 2013
Testimonial: "Spring is installed. It was running poorly before and after cleaning. There is no problem cranking the engine...it just runs rough and puffs out black smoke when running."
  • Behind_Blue_Eyes
    Behind_Blue_Eyes Oct 22, 2013
    there is only one and this is the spring for the fuel pump... if it wasn't there it wouldn't run without spraying something into the carb...
  • eyekiltit Oct 22, 2013
    You're right. Well maybe he can use the diagram to order new gaskets if needed. :)
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
If you replaced the diaphragm and gasket below the carb and are completely positive they are installed correctly and not damaged, then the carb is defective and they usually warp or the primer system goes bad
I need help with my B/S Engine. Lack of power and black smoke coming from the exhaust.
If the plugs are ok and your engine is not smoking after starting and running ..Sounds like either of three things..all with the carburetor .First the carb has a adjustment screw for air/gas mixture on the side if the carb where it attaches to the engine..try this start the engine and at about half throttle..now adjust the screw clockwise until the engine starts to miss and bogg down then back the other way until it starts missing and bogging again. Then slowly adjust back and forth until you hear the engine run the smoothest..give it more throttle if it starts to run rough do the same procedure until you get the results you want..if it is the mixture problem this will take care of it..if this doesn't it it may be your fuel jet in the bowl dirty or the blow float sticking..if you are not familiar with carbs best to have a professional look at it..you can drop the bowl by removing the bottom bowl and clean it out...check to see if the float easly moves up and down..replace the bowl and go from there..worse scenario new or rebuilt carb...good luck..
Jun 07, 2014 | Briggs & Stratton Garden
Mower will start but runs rough & stops
Is the carb flooding?is there black smoke coming from exhaust when running, if so it could be the carb over filling with fuel. Is there petrol leaking out of the carb? If not check the fuel pipe is in good condition
Jul 22, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
22hp briggs and stratton intek v-twin model number 470577-0284-e1
to much fuel either the needle valve is stuck or the float is bad tear apart the carb acid dip and clean take float submerge in gas for 20 min pull out shake next to ear if you hear liquid inside its bad
Jul 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Vertical OHV Engine 18 hp blowing white smoke engine run great but a lot of smoke and also have oil being spit out of the black hose that come from engine to the carb.
Check your oil.
If it is overfilled, milky, or smells like gas. Your going to need to change that ASAP. It sounds like the float has stuck in the past or is still sticking, and it has flooded the crankcase with gas, which has mixed with the oil. And because it is overfilled it comes through the breather hose into the carb. This also explains the smoke most probably because the oil is spewing in the carb through the breather and being burned.
Jul 05, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton twin with overhead valve engine.
Hi, check the engine oil level. It will be most likely over full as it has become contaminated with fuel, if so you will be able to smell fuel on the dipstick. If thus is the
May 05, 2011 | Garden
I have a Craftsman Yard Man 6.5hp push mower with a Briggs & Stratton engine. The engine starts and runs fine for about 30 seconds or so then slowly dies out. It turns over slower and slower until it...
Have you checked the choke that it is off after you get the engine started,the black smoke is definitely from the choke, if you take the carb off and check that the needle closes when it should,as one can easily do an adjustment by bending the float/tab,rgds
Sep 25, 2010 | Briggs & Stratton Garden
I have a sears lawn tractor with a 25 hp ohv briggs and stratton engine. The problem is that it runs very rough, black smoke and has no power when the deck is engaged. I have replaced the air filter,...
So have you actually checked spark to both plugs? If so then inspect valves to be sure valves are operating. Sounds like running on one cylinder. A quick check would be to unplug one spark plug at a time. You may find if you remove the dead plugh wire, there is no change. If you unplug the running cylinder it probably won't start. Sometimes the compression release mechanisms can come apart or come loose. Download your manual for you engine model at www.briggsandstratton.com
Aug 10, 2010 | Briggs & Stratton Briggs Stratton Intek V...
No power/rough idle/black smoke
either the choke is closed or the float is stuck open..if the float is stuck open, normally it will leak gas
Jun 23, 2009 | Garden
Garden Logo
190 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
