Question about Microsoft Windows Vista Home Basic Edition for PC
Turn of filter keys in xp - Microsoft Windows Vista Home Basic Edition for PC
    Sergeant:
    Champion:
  • 272 Answers
XP ONLY:
  1. Press windows button + R
  2. Type "access.cpl"
3.
Open Accessibility Options
4.
On the Keyboard tab, under FilterKeys, select the Use FilterKeys check box.
To turn off FilterKeys, clear the Use FilterKeys check box
Posted on Oct 21, 2013
The.spacebar.stopped..working.
If your space bar isn't responding when you press it, or if it responds sluggishly, it's possible that you have inadvertently enabled the "Sticky Keys" or "Filter Keys" accessibility option in Windows.
When these options are enabled, your keyboard response time will be dramatically slowed and may require more than one tap to register a keystroke.
Fortunately, it's easy to disable these functions and return your keyboard to normal working order.
Click "Start" and select "All Programs."
Click "Accessories" and select "Ease of Access."
Click "Ease of Access Center."
Click "Make Keyboard Easier to Use."
Click "Set Up Sticky Keys." Deselect the checkbox that says "Turn on Sticky Keys When Shift is Pressed Five Times." Make sure the box that says "Turn on Sticky Keys" is not checked. Click "OK" to save your changes.
Click "Set Up Filter Keys." Uncheck the box that says "Turn on Filter Keys."
Click on the checkbox next to "Turn On Filter Keys When Right Shift Is Pressed For 8 Seconds" to deselect it. Click "OK" to save your changes.
Click "OK" again to save all of the keyboard accessibility changes you have made.
Hope this helps
Oct 29, 2012 | Gateway LT2021u Netbook
How to turn off filter keys on a Eee pc and what
Filter keys was introduced by the windows operating system its function is to filter out quick repeated keystrokes.
To toggle filter keys on and off hold the shift button down for eight seconds until you receive a pop up asking if you wish to turn filter keys on/off. In that pop you you will also be given the option to disable the function all together.
Mar 01, 2011 | ASUS Eee PC 900 Notebook
My keyboard will not type a double letter or backspace more than once without stopping first? Do you know why?
Disable Filter Keys in Windows 7 and Work.If Filter Keys has turned on in Windows 7 and your keyboard is no longer responding as you would like, follow these directions:
  1. Click Start
  2. Click Control Panel
  3. Click the Ease of Access heading.
  4. Click Change how your keyboard works.
  5. Remove all the check mark in the box next to "Turn on Filter Keys".
Enjoy :)
~ Vikrant (India)
Dec 09, 2010 | HP Computers & Internet
I can't turn off Filterkeys. Somehow Filterkeys got turned on and now I have to hold down each key for about a second to get a single letter.
Since you didn't post what operating system you're using I can't give a specific answer. You can go here to find out what the sequence is for your OS
For xp sp2 hold down on shift key fo about 8 seconds to turn on filter keys, then click cancel. Should turn them off. Otherwise search this database. Good luck
http://support.microsoft.com/search/default.aspx?mode=a&query=filterkeys&spid=global&catalog=LCID%3D1033&1033comm=1&ast=25&ast=28&res=50
If I have helped you resolve your problem, please
consider giving me a good rating. Thank you.
Oct 22, 2010 | Computers & Internet
Fn key that turns off the tracking pad in xp and Laptop Gateway
Some laptops have this function and some don't. If you don't see a picture of the touchpad (maybe with a circle and slash) on the special function keys, then you don't have a Fn key combo to turn off the touchpad. Note that some touchpads have a little switch just above them to turn them off.
Jul 17, 2010 | ASUS 90-A4C1K1000 Keyboard
I have a proform xp 580. when I turn it on,
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
After completing calibration of incline, press the Stop key and then remove the safety key.
Jun 12, 2010 | Proform XP 580 Trainer Treadmill
My xp-50 is emitting a noise when the keys are pressed
If the level is very low, this is what is known as "digitizing noise".
The waveforms from synths being digital in nature, have sharp edges that are filtered. There is a fine line between filtering too much and too little.
There is ALSO the statistical noise that is present in electronic devices that you can notice when you turn the volume way up.
These are all NORMAL and the nature of the beasts.
Nov 28, 2009 | Music
You answered my last Question.
The XP fix is the same for Vista
Click the start button, type Regedit, Registry Editor should appear on the program menu above, Right Click Registry Editor, Click RUN as ADMINISTRATOR
Once registry editor opens, navigate to the key indicated in the XP article and Delete the listings for upper filters and lower filters (There may be only one listing and only remove the filters from that one key)
The close registry editor, and reboot the system
Jan 26, 2009 | Computers & Internet
How to install windows xp
Enter BIOS Set CD rom drive to first bootInsert your CD reboot
folow the on screen instructions be patient, it may take up to an hour,  and then two houers to install drivers,
-> if you want me to find the drivers for you, plz state your computer name and model.
regards /Teis
Jan 11, 2009 | Microsoft Streets and Trips 2008 for PC
Keyboard doesn't work properly
Turn on your computer, go to the control panel, if you are using Windows XP, click on switch to classic control panel" and then go to Accessibility Options. There is a keyboard tab that the settings can be changed to help people with disabilities operate their keyboards better but if you hold down certian keys for more than a few seconds, Windows XP will activate these settings. Sounds like your son accidently turned on "FilterKeys" There is a check box on the Keyboard tab of Accessibility Options that turns off FilterKeys. If "Use FilterKeys" is checked, uncheck that box and then click "OK" and see if that helps.
Good Luck!
Nov 13, 2008 | E-Machines eMachines Desktop PC
Microsoft Windows Vista Home Basic Edition for PC Logo
23 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
