Question about Ricoh Aficio 450 Copier
Opc drum Im planning to put up a copy center in our place and panning to use surplus Ricoh Aficio 450. I just want to ask if these machine could be give headache in the future? How many copies could give the opc drum before i replace for a new one? What is the common trouble of Aficio 450? Thank you very much. Howe hope you can reply soon. Thank you very much, Nestor Dela Cruz
  • Nestor Dela Cruz
    Nestor Dela Cruz Nov 21, 2007
    I have 1 canon 6050 i cannot use the ADF coz of the miss feed error in the platten glass i already remove this misffed but still it indicate that there still missfeed in the glass. How i can remove this error so that i can used my ADF. Please help me.
    To Mr. Lechu thanks on your reply but idont get the figure you gave 1,200,000 or 120,000 life or copy of aficio 450 drum.
  • 4 Answers
The OPC is factory rated at 120,000 and developer at 200,000 copies. I own a copier company and for (29 years) have repaired all brands and models and still repair this 450 model. I have seen the 450 drum go to 200,000, anytime the OPC is replaced I always replace the developer, and drum blade is a must also. The 1045 aficio is the model that followed the 450 and is an upgraded duplicate. Toner leaks are the biggest pain i find inside the front door cover, but its overall, a well built workhorse and i have seen meters as high as 800k and 900k still running.today. I overhaul these Ricoh units and resell them with a year warranty, and if they werent tanks, then I would get killed on the 1 year parts warranty I give.
Posted on Dec 01, 2007
  • 62 Answers
How many copies does it show on the counter. (user tools-counter) More than 600,000....stock up on the Advil.
Use the correct supplies from Ricoh, not some other stuff and it should run pretty well for you. Upper fuser roller wear and jams are the most common problem.
Posted on Nov 17, 2007
  • 24 Answers
Average drum life is 1,20,000 copies .you may get more than that.use good quality spare and consumables(I will prefer the original Ricoh).Machine will not create much problems.
Posted on Sep 28, 2007
  • Swaroop js Sep 29, 2007
    The most common problem with this machine is toner spillage because of the poor quality of the toner.This will create a lot of other side effects like fusing problems, error codes etc. Try to use at least good toner.If you cannot use original use only the toner for this particular model by other manufacturers
There is a Black line on the Ricoh Aficio 3045 Drum Help for Remove ????
if you can clean the black line with a cloth, than you need just to replace the cleaning blade, but if the black line is not removing without a cloth, then you need to replace the opc drum and the cleaning blade or both blades, some machines of this type have only one cleaning blade but some have two cleaning blade.
Sep 28, 2016 | Ricoh Aficio Office Equipment & Supplies
Aficio 1018 dirty copies
Remoe the image unit,remove the OPC drum ,clean the opc drum cleaning blade(if necessarry change),remove the transfer unit clean the transfer belt cleaning blade,and clean the polygon glass.
Jan 31, 2013 | Ricoh Aficio 1018 Printer
Sc990
sc 990 relates to the nv ram chip on the main board also check the values of the lazer unit are correct and not changed
Jun 16, 2010 | Ricoh Aficio 450 Copier
RICOH Aficio copier is giving error code SC320, what is the problem?
i have a ricoh aficio 450 copier.it pick the paper from the tray and after afew seconds the paper will come without coping.(plain paper)
Jun 14, 2010 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 back side is dirty?
Problem on charge roller,Upper drum unite,please clean or change it then solve your problem.
With the best luck.
Jan 20, 2010 | Ricoh Aficio 450 Copier
I have ricoh 1035 & eror sc990. without hdd ,i can print and copy one side and by hdd i have error. i do . & # toghter for 10 second for soft reset and nothing happend. in code menu: 5801 - 2109 -...
If you use Katun OPC drum in your machine and is work more 80000 copies you need to replace the OPC drum and the drum cleaning blade.After replace the drum perform the process comtrol and the SC990 disipaire.Whenever use other genuine parts and not original Ricoh parts appair SC codes to refer HDD parts.100% this method is working.
Nov 21, 2009 | Ricoh Aficio 1035 Copier
Black spots in the dram ricoh 450
Are the black spots on all copies. if they are only on teh copies done from teh glass scan then it could be dirt on the g;*** plate. if from all copies it is the dev or drum area.. are the dots moving across the page in the same place if you do lots of copies this means it is the drum that is damaged.. if they are blotchy marks it could be toner build up.. if the marks are in a line across the page open up the side door adn look at the hot roller in the fuser the coating could be damaged and the roller need replacing..GOOD luck A
Sep 29, 2009 | Ricoh Aficio 450 Copier
Developer....
When developer goes bad you use more toner for one thing, but the main sign is a gray background in your copy. The print should be black but appears to be gray. The ricoh 350/450 was always noted to leak toner and developer as it runs. Check your machine and see if you see any small piles of toner, which also has developer in it, in the machine. Ther are small seals made of felt that need to be replaced if you have this problem. These seals rub against the drum sides....Good luck.
Jul 20, 2008 | Ricoh Aficio 450 Copier
N 450 aficio
Have you replaced the opc drum lately?? The toner density is looked at on the drum with the ATDC sensor. It seems like your tring to adjust the toner density. That is just a band-aid. try to replace the developer and if needed the opc and clean the drum unit and the ATDC sensor. You shouldn't have to readjust in the service mode.
Jul 10, 2008 | Ricoh Aficio 450 Copier
Ricoh aficio 450
hi im jules_09,the average copy life as we call it is 60,000 copies after that you will replace the drum,cleaning blade and the developer.see first if the copy meter is already above 60,000 copies then about the print i think it time for you to replace all that is mentioned
Oct 11, 2007 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
196 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Inky Fingers
Inky Fingers
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
