Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
DS603 has power but no light coming on panel - Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
  • Fisher and P... Master
  • 3,247 Answers
If you can operate the dishwasher but the display is blank then it is likely the LCD panel is faulty. Needs to be replaced. see below.
http://spares.bigwarehouse.com.au/product_info.php?cPath=64658_64876_68136&products_id=1653549
Posted on Apr 03, 2014
Ds603 has no power coming to it - no lights, no sounds. It is not the power point. Can you tell me which part maybe affected?
Your control board is definitely dead and the likely cause 8 times out of 10 is because the heater plate blew (when the heater shorts out it often back feeds to the board and fries it, can be a little pricey to repair over 300 easily, but the control board can die for no specific reason or can be caused by power surges, you will first need to work out whether the heater plate is blown or not, this riquires a bit of electrical skill
Jul 27, 2014 | Fisher and Paykel DS603SS Stainless Steel...
Ds603 flood switch has been activated
The flood switch is at base of dishwasher housing under the drawer. Water leakage has occured to trigger this. Turn power off to dishwasher and take the power chord out. Pull the drawer out and use towels and hair dryer to dry the base. Put drawer back in and reconnect. Should work. Need to find the cause of leak. Either damaged lid seal or leaky hoses. Sometimes too much foam in detergent can cause it. Use recommended detergent and appropriate quantity per user manual.
Mar 14, 2014 | Fisher and Paykel 24 in. DS-603 Built-in...
Ds603
Check if the delay switch has been pressed. Press the delay switch to override any previous delay cycle.
Apr 19, 2013 | Fisher Dishwashers
The top dishwasher of my Fisher&paykel Paykel DDd603 &DS603 model ontinuallly beeps. I tried unplugging the power for several hours and it still beeps. Any recommendations ??
Assuming the bottom dishdrawer is working ok, it is likely the controller on the top drawer is either faulty or sensing some incorrect signal. If pressing any of the panel buttons makes no difference, then most likely the controller is faulty.
By the way I am unclear why you mention two models in your problem description. DD603 is a double drawer dishwasher and DS603 is a single drawer unit.
Apr 10, 2013 | Fisher and Paykel Dishwashers
U1 Error on DS603 Fisher & Paykel dishdrawer
have u checked if water is coming out of tap that supplys water to unit. if water is ok then either your water valve is faulty or the control module is faulty.the water valve is located under draw and the control module is located right hand side top of draw, behind front panel. check both of those i'm pretty sure one is faulty.when u had a leak did the water short any thing out.please reply if u need more help. please turn off power b4 you work on it. dont want any accidents
Apr 10, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 fault on a ds603
The reason for your F1 fault code in your dishwasher is due to the flood switch that has been activated in your unit. The best way to solve your problem is to turn off the water supply and power supply to your unit and call an authorised service centre. These problems cant be fixed on your own.
Apr 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
"F1" Flashing on Control Panel on my Fisher Paykel Dish drawer DS603. User manual says Flood switch has been activated and to call Authorized Service. Can I fix it instead myself? If so, how?
Thanks - your expert pointed me in the right direction. Never found a leak, but I dried up the water in the tray, which may have been from condensation, and dishwasher seems to work fine now.
Jan 03, 2010 | Fisher and Paykel Dishwashers
Beeping fault code Fisher and Paykel DS603
Stop the unit and check to see if it's heating when it's beeping at you. eg is it warm water inside at the time? if not you may have a faulty element.
Mar 09, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
Fisher & Paykel Dishdrawer DS603
2 quarter sized circles on either side of drawer will release the drawer fronts and allow acess to the electronics, behind the bottom drawr taped to back wall of unit is a troubleshooter/techsheet which might prove to be very helpful
May 02, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
