Question about Boss NEW BV8963 7 TOUCHSCREEN MONITOR W/ BLUETOOTH DVD AM FM TUNER AND REMOTE
Pairing Code - Boss NEW BV8963 7 TOUCHSCREEN MONITOR W/ BLUETOOTH DVD AM FM TUNER AND REMOTE
Uhuru Bluetooth 3.0 pairing code default
try 0000 or 1234 what are you pairing to Macbook ?
Pairing Code will be for device pairing to Macbook
Sep 23, 2016 | Computers & Internet
Pairing Code for ASUS r503c?
If you are talking about connecting a Bluetooth device to your laptop the laptop would not typically have a paring code. The device however may.
For example you would not be able to enter a code into Bluetooth headset as it does not have a keypad, so a code is pre-set into the device. Whatever the device you are trying to connect with see the manufactures manual or try 0000 as the code.
If however you are trying to pair with something like a mobile phone (providing both Bluetooth devices are set to "Discoverable") then you should be able to start the pairing from either the laptop or phone. Once the 1st device (That you has started the search/pairing from) asks for the pairing code you may enter ANY 4 DIGIT CODE OF YOUR CHOOSING. Once the is done you should be prompted to do the same on the 2nd device and you simply need to enter the SAME 4 DIGIT CODE.
This should complete the pairing.
Nov 22, 2013 | Computers & Internet
Bury car kit for 9320 pairing code
the pairing code is written in ur car guide. if there is no code there then when pairing u can put any number and write it on ur device to complete the pairing.
(some cars have their pairing codes in their guides so check it)
good luck
Feb 17, 2013 | Research In Motion BlackBerry Curve 9320 -...
I dont know where to find pairing code
If you are connecting to Bluetooth headset, check the manual of Headset to find default pairing code.
If you are connecting to other mobile phone or laptop, you have to enter any pairing code you want and then enter the same pairing code to other mobile or laptop and both devices will be paired.
May 25, 2011 | Cell Phones
Describe your pairing code for nokia ck 7w Problem i just need the pairing code
There is no default pairing code for the phone. You have to enter any pairing code and then enter the same pairing code in other device.
However, if you are trying to pair Bluetooth headset, check the headset manual to find its default pairing code.
May 24, 2011 | Cell Phones
What is the numeric keycode for pairing bluetooth? Jabra BT2035
As you pair the bluetooth in your computer and a bluetooth device, it gives you a pairing code, only if needed so, like the keyboard. The pairing code is seen in the computer, and is generated by the computer as you click on "create a pairing code". For other devices, a pairing code is NOT required.
Thank you for visiting FixYa!
Apr 25, 2011 | Computers & Internet
I have forgotten the pairing code for my samsung nc10, I've tried 0000 and 1234 also abcd. What would the default code be.
Usually default pairing code is 0000 but most times the code is whatever you set it up as. if you cant remember the code and the unit are requesting for a code simply delete the previous pairing and do a new pairing this should solve the problem instead of trying to remember a code which could be any 4 digits in the world.
Hope this solution has been helpful?
Apr 13, 2011 | Samsung NC10-14GW Notebook
I need need pas key for plantronic 220 pairing to a blackberry 8300. jguyden@ccny.cuny.edu
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 14, 2010 | Cell Phones
How to put a hbh705 into pairing mode
Take care.
Aug 06, 2010 | Sony Bluetooth Headst HBH705 Sandcolor...
I need to know the Bluetooth pairing code for a Samsung SGH-E900 Cellular Phone
When you are pairing with another phone, you set your own code, which is then requested from the other phone user.
If you are pairing with headphones or a handsfree unit these sometimes have their own pairing code which will be defined in their user manual.
The defaults are usually 1234 or 0000. Try these, if you have no luck consult the documentation for the device you are pairing with.
This code isnt defined by the phone
hope this helps
Dec 23, 2009 | Samsung SGH-E900 Cellular Phone
Boss NEW BV8963 7 TOUCHSCREEN MONITOR W/ BLUETOOTH DVD AM FM TUNER AND REMOTE Logo
46 people viewed this question
Top Boss Audio Players & Recorders Experts
J.D. Browning
J.D. Browning
Ron Jeremy
Sam Piasecki
Sam Piasecki
Level 1 Expert
Are you a Boss Audio Player and Recorder Expert? Answer questions, earn points and help others
