Question about HP 2710P Series Docking Station
Cd/dvd and usb ports not recognized on hp2170p series docking station
    Problem Solver:
  • 5 Answers
How can i update dell dock?
A docking station is an extension or addition of ports for a laptop computer. Once the portable computer is docked, you can access the docking station's ports, such as PS/2 or USB 2.0 ports, through your computer. Some docking stations have monitors that you can connect your computer to, placing your video on an external screen so you can turn off your computer's monitor and conserve some of your computer's energy. All Dell docking stations will have the same general troubleshooting steps.
Plug your laptop's power adapter into the docking station and dock your laptop onto/into the docking station. If there is no power going to your laptop from the docking station but it works when the power adapter is plugged into the wall, the docking station is bad and needs to be replaced. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power goes on but your computer doesn't recognizes accessories such as a USB mouse--plugged into the docking station, try a different port on the station. If it works in a different port, the previous USB port is burned out. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized, you might have a corrupted docking profile. Undock the computer and dock it again once it has fully started up to reset the docking profile. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If you have an external monitor and it is not working, completely close the lid on the laptop so the image will move to the external monitor. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized and resetting the docking profile fails, update all drivers through Dell's support website and then re-dock the computer. Some of the software that runs the hardware may have become corrupted. Hope this helps
b>
Jan 16, 2013 | Dell Inspiron 1545 Notebook
Dell 6420 laptop not recognizing USB ports while on docking station
Hello Jackie.
2 of youre USBs are USB 3. so you need to install the right drivers for USB 3.
Also you should check youre BIOS settings, if there is an option to enable "XHCI" support so enable it. (USB 3 needs this to work ).
regards Gue.
Apr 21, 2017 | Microsoft Computers & Internet
Will not print when docked
I would recommend that you undock the laptop, go into the Printers and Faxes console, and delete the printer. Then, dock the laptop, connect the USB cable to the dock and then re-install the printer through the dock. The USB ports on the laptop are assigned different hardware values than the PCI interface of the dock, and if the laptop is trying to print to a local USB port, it may not find the printer if it's connected through a PCI interface like the dock. That'd be my next move.
Mar 04, 2010 | Dell D/Dock Expansion Station Docking...
MY D630 LAPTOP DOES NOT WORK IN DOCKING STATION
When powering on the D630 from the Docking Station, press F2 to go into Setup. Scroll down to the Docking Section, and check the Dock device info for the status. If it shows undocked, then try changing the below settings to: Hot Undock, Enabled Silent, and Universal Connect Enabled. Save these settings. Make sure you update your BIOS to A16 from http://support.dell.com under drivers and downloads section. If still not recognized after this, check the dock port on the D630 for obstructions or burn markings on the pins. try cleaning with rubbing alcohol and qtip swab. I have seen a few cases like this and ultimately the motherboard was the issue and needed to be replaced.
Dec 20, 2009 | Dell D/Dock Expansion Station Docking...
The ethernet cable port on my docking station is broken.
It is hardly possible that anyone will even try to repair it. And believe it or not, it is cheaper to buy a new one then to repair the old one
Nov 17, 2009 | HP (EQ773AA ) Docking Station for nc2400...
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
Nov 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
The C V H T and B keys on my other Dell laptop, an Inspiron 1545 have stopped working
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Reseat the Keyboard Connector to the Motherboard Caution: Before performing any of the procedures in this section, read and follow the safety instructions in Dell Knowledge Base Article: "Precautionary Measures for Personal Safety" Article ID: 339031. Reseat the keyboard connector to the motherboard. Be sure to handle only the connector and not the cable. For information about how to open the chassis and remove, reseat, and replace components, please refer to your Online User's Guide and browse to the Replacing and Removing Parts section. Remove All Power Sources and Reset the Computer Remove the battery and disconnect the AC power adapter from the computer. Note: For information about how to open the chassis and remove, reseat, and replace components, refer to the Online User's Guide. Click Systems, then the make and model of the computer. Download the Owner's Manual or User's Guide and refer to the Adding and Replacing Parts section. Press and hold the power button for 10 seconds. Reattach the AC power adapter to the computer. Power the computer on. Replace the Internal Keyboard
Nov 07, 2009 | Dell 0Y3740 Keyboard
My kensington docking station has stopped working
try plugging in any other USB device at the port wherer the Docking station was connected ,... if this device also doesnt work Then update the USB or CHIPSET drivers and also BIOS form the Vendors website also reinstall the appliction from the cd tat u might have got wit the Docking station... take care..
Sep 21, 2009 | Kensington (1500100) Networking Hub
Viewsonic VX 1945-wm-3 not detecting iPod Mini 4GB 2nd gen
USB device not recognised" - means windows needs driver to function. As soon as you connect USB device it check driver in cache it is available it detect smoothly you can perform else it generate errors.
first to instal driver from CD
May 24, 2008 | Gateway FPD2275W LCD Monitor
HP 2710P Series Docking Station Logo
51 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
